Question about Remington S6500 Sleek and Curl Ceramic Pearl Multi styler Hair Straightener, 1 Inch
Remington s2014 where to return when broken
Is my Remington Model 700 Serial Number RR86406B subject to recall?
Identify the serial number and provide it to Remington's recall support team, either by entering it at xmprecall.remington.com or call 1-800-243-9700 (Prompt #3 then Prompt #1) Monday through Friday, 9 a.m. to 5 p.m. EDT. You will be informed if your rifle is affected by this recall and supported with free resources to return the rifle for inspection and specialized cleaning.
Jan 05, 2016 | Optics
While driving in camper van de-humidifer fell and bange to the floor.
I do not know but I would let it set upright for 24 hours to allow the oil in the compressor to return to its normal place. Check if the fan etc are clear and then try it.
Apr 26, 2014 | Remington Model 365 Mini-dehumidifier
Remington hc 600
You will find a replacement charger for model HC-600 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/cords-chargers-and-stands/remington/remington-hc-600-charging-cord.html
Dec 30, 2013 | Remington HC-600 Hair Trimmer
Took remington branch wizard out of box and it will not work
It could be a broken power cord, defective switch, or motor brush damage. Remington saws have gone out of business, so no warranty anyway. Procuring parts for these things is a hit or miss proposition at best--good luck!
May 29, 2010 | Remington Polesaw Wizard
Need an owner's manual for remington pole saw-- model #106890-02
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
When your model number is input above, this returns; even though your model is not listed it is the correct OM.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/RPS96/RPS96_OM.pdf
There are 2 model listed, both return this OM.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 10, 2010 | Remington Polesaw Wizard
The cablecoming out of the charger has broken
If you need a new charger cord, you can purchase a replacement from shaveroutlet.com. See link below
http://shaveroutlet.com/remington-hc-600-charging-cord.html
Apr 07, 2010 | Remington HC-600 Hair Trimmer
Pop up trimmer stopped working Remington R830
Make sure you are using the trimmer with the shaving heads on the shaver. With heads removed, the trimmer on the back will not work properly. If thats not the problem, the trimmer is broken or jammed. clen the blades really well with a toothbrush and rubbing alcohol. If they're jammed, this will probably free them up. If that doesnt do it, the trimmer is probably broken and that part is no longer available from Remington. If you really like this model, you can find a replacement at shaveroutlet.com
Jan 10, 2010 | Remington Health & Beauty
Broken extractor housing on Remington 870
http://www.brownells.com/.aspx/pid=653/Product/REMINGTON_870_RIVET_STAKING_TOOL_SET
Dec 29, 2009 | Remington Sport & Outdoor - Others
Remington S6500 Sleek and Curl Ceramic Pearl Multi styler Hair Straightener, 1 Inch Logo
16 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
