Question about Nokia 3120 Cellular Phone
Cellphone no power and not charging
  • 89 Answers
This happens when you don't charge your mobile of a long time . the solution i am providing is bit tricky take out the battery out of your mobile phone and take to electric wires and one 8 volt battery the one has two terminal on the top and has rectangular shape . attach the two piece of wire with the batter terminal and then attach the two wire to the batter of the mobile for few second and then attach the battery to the mobile phone and charge it with normal mobile charge ... and its done .. and even then if the problem exist try to change the battery
Posted on Aug 30, 2007
SOURCE:
Will charge when plugged in, but will not come on. How do I fix this?
If your tablet or cellphone has not been used in a while, chances are, your tablet/cellphone has gone to a "hibernation" state. Hold send/on button down for 5 seconds. Hopefully, it will power up and operate properly.
Jun 25, 2015 | Tablets & eReaders
Charging hiting
what model of cellphone you have... and what heated up is it the charger or the cellphone.. we have two problem either the cellphone or the charger.. but i will tell you to look for another charger where we can check your cellphone. A charger must stop charging when the battery reaches its peak of charge... if the charger doesn't stop charging even the battery is charged then it will cause over heating to the charger or to the cellphone...
Sep 22, 2013 | Cell Phones
MY NOKIA CELLPHONE DIDNT WORK PROPERLY
Hi:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 03, 2013 | Nokia N76 Cellular Phone
My lg kp320 went off and can't turn it on again
is your battery old already? have you dropped your cellphone in anyway? is the battery full charged? first step: 1. replace the battery with a new one. 2.if you dropped you cellphone,look for a nearest cellphone repair shop and let it repair by the cellphone technician. 3.charge the battery full.
Jun 16, 2011 | Cell Phones
It used to be that i would have to push really hard on my charger for my phone to charge now it doesnt even charge. i push the on button and it wont turn on either! what do i do!
The problem is between the connection of your cellphone and the charger. I think the power has been drained from the battery already that's why it's not turning on.
I have two suggestions:
1. Check the hole in your cellphone where you put in your charger. Maybe, the hole has a problem or any sign of damages.
2. Buy a new charger. Check whether your cellphone works with the charger before buying it just to make sure that it's not your phone which has a problem.
I hope this helps.
Please rate this solution.
Jan 28, 2011 | Cell Phones
When i connect my mobile for carging it show (not charging(stop)). But it show after few second and make a beep. with this mobile show different status of charge level.
Hi, I too have this cellphone, when this happened to me I just bought a new charger and that fix my problem. I would suggest you try first a known good charge for your cellphone and if still you have the same issue, try to visit a cellphone repair center or from nokia care center, because there is already a problem with the charget socket on your cellphone. Hope This Helps
Jun 11, 2010 | Nokia 1110 Cellular Phone
My z6m cellphone won't charge and won't power up. the
This just could be a battery problem.Take the battery out and refit if it is still the same(doing this might give a small charge to the battery but will soon be lost..Try a new battery
Oct 28, 2009 | Cell Phones
Cellphone not charge
try to put your cellphone on charging for a longer duration say 1 hr or so...if still it doesn't pick up then you may need to replace your battery.
Sep 20, 2009 | Cell Phones
Phone wont detect bluetooth H700
Mine could be discovered when powered off/ on my cellphone and retried... Sounds like solution to M$ programs, eh? :)
Apr 18, 2007 | Motorola Mobility H700 Wireless Headset
Nokia 3120 Cellular Phone Logo
124 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
ASHRAF CA
ASHRAF CA
