Question about Jacuzzi Pool & Spa
Voltage drop can you reduce pump speed by reducing power voltage
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 50 Answers
No you will have to change gear racial
Posted on Dec 19, 2013
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
What make and model pump?
Posted on Jul 18, 2013
Testimonial: "jacuzzi no sure model will have to get in daylight thankyou"
Malibu hybird 2008 /service traction /engine power reduced
Your best bet would be to take it to a qualified repair shop. Special tool's and knowledge are needed . Scan tools , electrical diagnostic , service information . Your vehicle has a bunch of computers (control modules) C.A.N. cantroller area network serial data communication networks . Hi speed , med. speed , low speed . The power steering is electronic ,computer controlled , sensors on the steering shaft .With those light's lit , DTC'S - diagnostic trouble codes are stored etc... Plus there is a real chance of being electrocuted. High voltage !
Dec 10, 2016 | 2008 Chevrolet Malibu
2002 trailblazer oil pressure drops when stopped returns accelerating
Usually means the engine bearings are worn out, or the oil pump is weak.
As the oil gets hot, it gets thinner, which reduces pressure. When the engine is at idle speed the pump is not pumping as fast as it is at highway speed.
Aug 26, 2015 | 2002 Chevrolet TrailBlazer
When i plug in the fuel pump on my 2000 Nissan xtera the voltage drops from 13.5 v. to 0 v. but can put direct to battery and it runs with a screeching noice
Sorry, your pump is bad. What you did was reduce the resistance in the wires. Full power with way more than full amps(you jumped it), will cause the pump to come on. The screeching is the pump. replace it.
Jul 20, 2015 | 2000 Nissan Xterra
Mig is not pulling enough amps. For example at 20V it is only pulling 85A.
With constant voltage, amps depends on wire speed. You would have to increase the wire speed (or larger wire) to increase amps. Also, any voltage loss between the machine and weld will reduce amps due to voltage drop.
Mar 25, 2015 | Welding Tools
Pump speed
Maybe. What make and model pump?
Jul 18, 2013 | Jacuzzi Pool & Spa
How can I control the presure of the water drain in the washer mashine
Only way to reduce pressure is to reduce efficiency of pump. i.e. reduce voltage supplying pump winding. Could reduce flow rate by restricting outlet hose diameter but not a good idea as could effect peformance of washing machine and overload pump, belt or brake.
Apr 02, 2011 | Ovens
Screen has shrunk and picture is now tripled
The projecction width has reduced with the three guns going out of alignment to give the three images.
It is possible that the power supply voltage has reduced which has made the projection drop down to give this reduced size.
Check for possible failrue of the filter capacitor or the fault in the SM pre driver circuit, possible redduction of value of some associated electrolytes.
Check for visible signs of capacitor leaks or use a multimetter to confirm.
Aug 22, 2010 | RCA R52WH73 Projection Television
Low fan voltage cr320?
MANY of the amplifiers have temperature sensors and REDUCE the fan speed at lower temperatures. This is usually done by reducing the voltage.
Be aware that sometimes the voltage is modulated by pulse width and reading it requires using an oscilloscope rather than a voltmeter.
Jan 20, 2010 | Peavey PV® 900 360W Power Amplifier
Voltage is high around 150 volts. I reduced the
The speed will change the 'frequency' too. You need to make sure you still have 60 Hz. You may have need a voltage regulator adjustment, not a speed adjustment.
Aug 01, 2009 | Coleman Powermate Powermate 5000W...
240v electric motor
Reducing the voltage is what you want to do -- this will effectively reduce the speed, without creating an annoying hum.
That said -- 110v is too low. Start higher. Half the voltage doesn't equal half the speed.
May 10, 2008 | Hampton Bay 24002 Ceiling Fan
Pool & Spa Logo
23 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
