Question about Electrical Supplies
Yale forklift wiring diagram
2006 1/2 yale, mazda 2.0. code 51-2 on dash. no others, replaced tps, same problem. idles fine will not accelerate
3 Suggested Answers
emissionwiz
  • 76673 Answers
SOURCE: chrysler 300 2006 v-6 tps light on dash
Whenever this warning light or any other stays on in the dash it is indicating that the systems control module (or the system sensor in the case of lights like low oil pressure, door open indicators etc.) has detected a fault, it then disables the system (this applies to ABS,TCS, TCM, SRS and BCM faults and others) as long as the light is on. You must now have the dealer hook up a special electronic diagnostic tool and "scan" the system for the fault code that is stored for the problem(s)
Legend of Abbreviations. ABS Antilock brake system.TCS Traction control system, TCM Transmission control module, SRS Supplemental restraint system, BCM Body control module
Posted on Oct 09, 2012
  • 2826 Answers
SOURCE: acceleration flattens out over 3,000rpm, won't go over 4,000. code 0121 TPS-tested fine, replaced it anyway still have same problem. It doesn't ****, buck, idles fine. No other codes or drivablilty
Hm. without knowing what car/engine, I'll be guessing. Could be a clogged air cleaner, partially blocked exhaust, partially blocked fuel line.
Posted on Jan 01, 2015
Testimonial: "I reposted it to include 2000 jeep cherokee sport, 4.0l, 5 sp manual."
Hi,when I turn the key over it automatically blows a fuse!! Please Help?
Check the entire engine wiring harness, somewhere there is a wire or wires that are pinched or have rubbed through and grounded to the metal of the chassis, pay close attention where the wires move a lot. There is no quick fix, just careful examination for damaged wires. Obtain a wiring diagram and trace down the circuit that the fuse powers would also be very helpful.
Dec 23, 2016 | Cars & Trucks
What does fault 108-1 mean on a Yale forklift
Troubleshooting Yale - Forkliftaction.com
www.forkliftaction.com/forum/threadbybrand.asp?brid=97
No Trans Braking Error code 524264-14. Discussion started: 5 .... Error code 108-1displayed. Discussion ... Yale forklift has perkins 4203.2 engine oil capacity?
Oct 23, 2015 | Cars & Trucks
Acceleration flattens out over 3,000rpm, won't go over 4,000. code 0121 TPS-tested fine, replaced it anyway still have same problem. It doesn't ****, buck, idles fine. No other codes or drivablilty
Jan 01, 2015 | Cars & Trucks
ERROR CODE P1961
P021 and p1961 throttle body sensor
Jun 01, 2014 | 2006 Mitsubishi Colt
2000 GMC Jimmy ran fine stopped at a light and went to take off but couldn't accelerate and sounded like timing was going way out as it was bogging.Vehicle will idle all day but randomly wont accelerate...
Hi there u dont mention if twhat is the right code. U must undrstand what is the really name of the code which is very important to know ..some codes explained like this TPS low voltage or circuit or TPS performance..or TPs circiut malfunction...one thing u should take note that Apps. .or acc pedal position sensor should be also one of the problem. U need to double check the electrical
Aug 10, 2013 | Cars & Trucks
Hi i have a 1995 mazda 1.8 auto protege when i select drive or reverse the motor at idle almost cuts out or some times cuts out it dose not cot out if you turn the aircon on so it seems to me that the ecu...
There should be a line connecting the solenoid of the transmission to the ECU. It could be the wiring is bad or the contacts need cleaning or the IAC valve may need cleaning or is not working.
Jun 03, 2011 | 1995 Mazda Protege
Electrical Supplies Logo
54 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
