GE top load washing machine GJSR3140DAWW leaking water, now will not fill
Our GE top loading washing machine GJSR3140DAWW was leaking water in the Super load level only so we just did smaller loads. Now it will not fill - just wants to go to agitate.
4 Suggested Answers
milten1
  • 1304 Answers
SOURCE: GE WBSE3120B toploader washer leaks only during agitation
knowing this is the only time it leaks helps
sounds like your suffering from suds leak
try cutting way back on your soap 1 tablespoon per load that should take care of your issue
Posted on Oct 06, 2009
j_alcaidinho
  • 107 Answers
SOURCE: My GE Washing machine appears to be leaking from the bottom
It sounds to me , you need the seal and bearing kit.. It is over 300.00 dollar repair, if it is an old washer I would say go get a new one
Posted on Jan 13, 2010
  • 949 Answers
SOURCE: kenmore top loading washing machine model 4021092, keeps filling
It is most likely siphoning out. Here is a link that will help explain it and how to correct the problem, let me know if this helps. Thanks
http://www.fixya.com/support/r4621172-clothes_washer_stop_filling_water
Posted on May 03, 2010
GE Hydrowave top loading washer is leaking around the top side and back of unit when filling.
check for the water outlet from the water solenoid control valve
it may be displaced or broken and not directing water to the bowl
Sep 29, 2016 | GE GTWN4250MWS 27" Top-Load Washer, 3.7...
Washing machine leaks at bottom left corner. Water still machine after drain/spin cycyle
My GE washing machine leaks while filling up in the first cycle in the left back corner. Need help!
Jun 16, 2010 | GE Profile WPRE6100G Top Load Washer
Washer machine is leaking water on the left corner
Hello my name is Heath it will be my pleasure to assist you. If the machine is leaking water on initial fill or when the machine is filling with water then the fill tube is the problem order a new fill tube and replace . You will have to lift the top to find exactly whaere the water is coming from.
Jun 15, 2010 | GE WBSR3140DW Top Load Washer
Our GE WSERR417FOWW washer is leaking (profusely)
Any solution to your problem? I am searching because mine started the same behavior tonight. I hope that you found a solution, and would be willing to share it!
Thanks.
Jeff jeffyr2@verizon.net
May 24, 2010 | GE WJRR4170E Top Load Washer
GE WBSE3120B toploader washer leaks only during agitation when super load selected. Is it the pressure switch for water fill level or another possible leak?
Oct 04, 2009 | GE WBSE3120B Top Load Washer
My GE washer wont stop filling with water or go to the wash cycle. my GE top load washer water will not stop and leaks out, overflows. model #GCXRPO9ODAWW.
You have a problem with the water level switch.  It is located in the base of the machine below the tub.  Replace it and you'll be fine.
Nov 20, 2008 | Washing Machines
Ge top load washer keeps filling with water
most common leak point for washers is the level sensor connector on the lower part of the tank, a small plastic hose.
Not a solution, something to check
Jul 23, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
I have a Ge Mod# WBSR3000G1WS Fills won't agitate or spin but will drain
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Jul 16, 2008 | GE Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
