Question about Garden
Despiece stihl ts400 - Garden
VtToolMan
  • 704 Answers
SOURCE: Were can I get a free Parts manual for a TS400
The Stihl website has the manuals available for free. You can copy the link I've provided for you and download or print out a copy for your use.
I recommend creating a computer file folder to put all the electronic copies of user manuals, etc. in, to make it easier to find, should you need another copy in the future. I've done this with all my home appliances, tools, and lawn equipment. It comes in handy as these items get old since the manuals might not always be available online in the future.
http://www.stihlusa.com/stihl_ownersmanuals/TS400_Manual.pdf
If you need further assistance with getting replacement/repair parts for your Stihl cut off saw, just fill out their customer service form and they'll be back in touch pretty quickly!
http://www.stihlusa.com/contact.php
Hope you find this information Very Helpful and best regards!
Posted on Oct 22, 2009
rwvanlue
  • 486 Answers
SOURCE: how do I wind a stihl ts400 pull cord
1) remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope. This is the area that causes so many guys a lot of extra trouble
2) locate the string that is left and the hole it is threaded thru
3) determine how much string has broken off of the rope that came out
Note: if more than 1 inch is left, then the rope needs to be replaced
4) after rope is obtained, make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
6) with the rotor free of tension, route the rope from the groove toward center and up thru the hole. Tie a knot in the end of the rope, leaving a 3/8" tail free.
7) wind the rotor in the direction of what the rope would pull (this will tighten the spring) until the spring is completely wound. remove 1/2 to 1 revolution, and then allow rope to wind onto the rotor until all rope is wound.
8) Pull the rope several times to position rope properly into rotor.
*note : there should be NO droop in the handle after released
If droop is evident, wind the rotor and rope 1 revolution tighter so there is no droop of handle when released
9) when unit is functioning proplerly, re-install housing onto unit
Posted on Nov 21, 2009
  • 40 Answers
SOURCE: No problems yet, I would
have you tried to search STIHL online, try
www.stihl.com
www.stihl.ca
hope this helps
Posted on Dec 18, 2010
  • 127 Answers
SOURCE: Stihl TS400 instruction manual
here's the link
http://www.stihl.ca/manuals/0458_338_8221_0_01.pdf
Posted on Dec 27, 2010
philwalker78
  • 608 Answers
SOURCE: Hi, My Stihl ts400 saw
First try a new sparkplug. If no spark disconnect the single wire off the stop switch and trace it back thru the saw and make sure its not chafed anywhere. Do the same with the high tension lead off the sparkplug. If both these are ok the saw has a one piece cdi unit which unfortunately will have to be replaced. Hope this helps, Phil.
Posted on Apr 21, 2011
Original parts diagram for stihl ts400
I found a parts diagram for a Stihl TS400 CutQuick concrete saw here: http://www.sawagain.com/stihl-concrete-saws-1/ . The direct link to the parts diagram is http://www.hellumdiamant.com/filarkiv/File/Sthil/ts400.pdf . I found some of the parts shown in the user manual as well. The manual is available here: https://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/TS400_Manual.pdf . See page 44 for that parts diagram.
I hope this helps.
Jul 18, 2017 | Stihl Saws
Which way does the arrow point on a stihl piston ts400
the arrows on all pistons face to the front of the engine
Apr 19, 2014 | Stihl Ts400 Cut Off Saw Piston Cylinder...
Whats the fuel oil mix of sthil ts400
Stihl two stroke oil mixed ar 50-1, do not use cheap two stroke oil or oil for designed for out board engines.
Jun 29, 2012 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Instruction manual for a still ts400 saw
I just googled Stihl ts400 manual and it was the first hit!
Oct 21, 2010 | Garden
Need to know belt size fo the stihl ts400 concrete cutoff saw
You should go to a Stihl dealer and ask for the belt for a TS 400 Cut Off Saw. The belt is ribbed, you should only put on a Stihl part to replace the belt and make sure the belt is under the correct tension. When you go to the Stihl dealer you can ask them to show you how to make sure the belt is under the correct amount of tension.
Aug 31, 2010 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl saw TS400 will not get fuel through,NON START
how much fuel can be put into a stihl saw ts 400 and how long will the fuel last while in constant use
Mar 24, 2010 | Oregon Scientific Complete Carburetor for...
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
