Question about Refrigerators
Dometic rm2352 A76418
Is there an owners sequence of troubleshooting steps to try? Does not cool much, lights well on propane. In a 2003 RV, has worked well until this season.
  • 10865 Answers
SOURCE: will not cool on electricity
Hi there. There are actually a few causes of your problem but I would begin by checking the fuse. here is the Dometic troubleshooting manual for your model. It should help.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Posted on Jun 04, 2009
  • 62 Answers
SOURCE: Dometic Rv fridge will get cold on a/c power but
does the flame ever got out if not ,the tsat is not the problem. It could be that the flame is not hot enough or the flue has a restriction
Posted on Jul 25, 2009
VtToolMan
  • 704 Answers
SOURCE: Just bought a tent trailer with a Dometic Fridge.
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Hope you find this helpful and will resolve your issue.
Posted on Jul 30, 2009
motor1258
  • 6674 Answers
SOURCE: 3 way dometic RV fridge RM2612 won't work on propane or 12 V
Check any fuses/circuit breakers in harness from battery. That battery should supply 12 volts dc to fridge lugs/terminals at bottom of fridge on outside behind vent.
If battery is good and hooked up properly but no 12 volts to fridge, then you will have to trace back to battery for broken /bad wire. If you want to test quickly, just run 2 jumper wires from battery to those 2 lugs marked + and - Battery + to + (pos)at fridge, and - battery to -Neg at fridge. That should allow you to run it on propane or 12 volt. Remember, running it on 12 volts will kill that battery pretty quick, unless it's being charged. When you are plugged in, the converter supplies the 12 volts to your fridge, as well as should be charging your battery.
Posted on Jun 22, 2010
SOURCE: i have a dometic dm2652 rv fridge. its new and is
The DM2652 comes with an optional cooling fan to help with cooling the amonia. The fan cycles on and off as required as it has a tempeature sensor (thermistor). We turn ours off at night by removing the inline fuse (glass tube fuse 3 amp) located in your outside acces panel. The fuse is located in a black fuse holder with a re wire connecting both sides.
Posted on Aug 18, 2010
How to troubleshoot no power to dometic 2562 rv refrigerator
disconnect thermistor let run if cools bad thermistor if not bad board or cooling unit
Jul 12, 2014 | Dometic Refrigerators
Rm2352 will not work on AC, pilot will light, but then will go out. No cooling
LP check for cobwebs in lines and good gas pressure ac check heater element if ok disconnect thermistor from back board run overnite if ok replace thermistor if not bad cooling unit replace
Jan 29, 2014 | Dometic RM2652 Refrigerator
My dometic rv refridgerator is not cooling at all on propane or electric?
disconnect thermistor let run if ok replace if not replace board
Dec 23, 2012 | Dometic Refrigerators
I have a 2009 pop-up camper with a Dometric 2193. The previous owner stated they never used the unit. They only had the camper for 5 months. I cannot get the unit to cool with gas or electricity. I The...
One of the first things I advise a new owner of any RV is to have the propane system checked by a certified RV technician. I have seen brand new units from factory with propane lines left unattached to appliances, as well as past owners of used units who have decided to try a few things of their own that were extremely dangerous. This unit apparently has sat for approx. 2 yrs, and spiders etc can build nests, bees can build nests that will block ventilation etc, which all can create a situation for a fire or worse. PLEASE, spend the $60, let them clean and inspect the system to give you piece of mind and know that it is safe for your family and friends as well as you. My guess is that it is not a serious problem, and good chance still covered on 3 yr. warranty.
Mar 10, 2011 | Dometic RM2193 Compact Refrigerator With...
MY dometic AC with anolog tstat will operate fan but does not cool...does not sound like compressor is kicking on ..can anyone give me a troubleshooting sequence on what to do step by step
Hi, just a few thoughts that may help, depending on your level of expertise, I suggest checking the start and run capacitors for the compressor. Then check the coil of the start relay, (usually on the side of the compressor). Can you hear whether the start relay is clicking on. Does the compressor hum or is it dead. Check for continuity between thermostat and compressor start relay
Feb 24, 2011 | Dometic Rooftop RV Air Conditioner
Dometic RM 2652 Refrigerator/Freezer is not working. Light works, 110 and propane are fine. Are there steps in trouble-shooting problems with this refrigerator? No visible leak or obvious problem. It's in...
Dometic refrigerator lp gas electronic Model # 3662. Same problem. gas works fine and power is there. as lights on top of frig work.... not even trying to be cold. Same suggestions as 2652? How to bypass thermostat? and will try relay after... thanks.. Bob in Canada<input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" /><!-- from fixya rte -->
Aug 02, 2010 | Dometic RM2652 Refrigerator
RM2652 Refrigerator: I have a DM2652 model Dometic RV refer. It is leak...
Dometic Voluntarily Expands Refrigerator Recall
Dometic recently expanded its recall on a population of two-door refrigerators. The original recall included some two-door refrigerators manufactured between April 1997 and May 2003. The new recall focuses on models manufactured between June 2003 and September 2006.
To see if your unit is on the recall list & what to do, try the link below.
If your unit is on the list, DO NOT run your refrigerator on propane until the kit is installed
http://www2.dometicusa.com/recall.php
May 18, 2010 | Dometic RM2652 Refrigerator
Unit cools fine on 120V, selecting GAS CHECK light on.
Do you hear a clicking sound If not. there is a black box inside the out side door. Check the fuses in it.
Ken
Sep 23, 2009 | Refrigerators
I have a rv with the Dometic RM2852 refridg. It works fine on gas, but when I switch to AC input the gas turns off like normally should but the refridg does not cool. The Auto light is on, 120VAC is OK at...
First thing to check is that the control switches are in the proper position, since some RV fridges require a particular placement for the fridge to operate on different power souces.
Check your owner's manual for troubleshooting steps for your specific fridge, beyond that, here's link to a site that provides a step-by-step troubleshooting guide complete with active links for each potential issue.
http://gasrefrigeration.net/works_on_gas_but_does_not_work_o.htm
Here's a copy of the manual for your fridge model that you can download and print for free, just in case you don't have yours handy.
http://gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Hope you found this very helpful and best regards!
Aug 08, 2009 | Dometic Refrigerators
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
