Question about Microsoft Presenter 3000 Mouse
What are 2 elements of "setting'' in preparing a presentation
Whirlpool duet dryer GEW9200LW1 heats
If the element was replaced, and now verified that it is not presently shorted to ground, your next diagnostic would be to to test the timer connections per the schematic lookiong for a fused contact that energizes the heater, while set to air fluff setting.
Apr 08, 2014 | Whirlpool Dryers
Tip
How to recover PowerPoint 2007 password with PowerPoint password recovery...
How can I password protect PowerPoint 2007 Presentation? Many people ask how to add password to the PPT file . Meanwhile, else people ask how to remove or recover PowerPoint password in case they forgot it. Follow these tutorial to get to know how to add password to PowerPoint Presentation, remove PowerPiont password and recover PowerPoint password.
Set a password to open or modify Powerpoint 2007 password
Set a password to open a PowerPoint presentation
  • 1. Click the Microsoft Office Button office.gif , point to Prepare, and then click Encrypt Document
  • 2. In the Password box, type a password, and then click OK.
  • 3. In the Reenter password box, type the password again, and then click OK.
  • 4. To save the password, save the file.
Set a password to modify a PowerPoint presentation
  • In addition to setting a password to open a PowerPoint presentation, you can set a password to allow others to modify the presentation.
  • 1. Click the Microsoft Office Button office.gif , click Save As, and on the bottom of the Save As dialog, click Tools.
  • 2. On the Tools menu, click General Options. The General Options dialog opens.
  • 3. Under File sharing settings for this document, in the Password to modify box, type a password.
  • 4. In the Confirm Password dialog, re-type the password. Click OK.
  • 5. Click Save.
Remove password protection from a PowerPoint presentation
  • Use the password to open the presentation. (Note: If you forgot the Open password, you have to recover PPT password with the third Office password recovery tool)
  • 1. Click the Microsoft Office Button default.aspx?assetid=za100771021033 , point to Prepare, and then click Encrypt Document.
  • 2. In the Encrypt Document dialog box, in the Password box, delete the encrypted password, and then click OK.
  • 3. Save the presentation.
Recover PowerPoint password with Office password recovery Software
If you have forgot or lost PwerPoint password, the best choice to open the ppt slideshow is to recover PowerPoint password with the third part utility. Office Password Unlocker is a professional Office password recovery tool, which can recover PowerPoint 2007 Password with a few steps.
on Jun 02, 2010 | Computers & Internet
Why wont my machine get hot?
Please check the voltage on the heating element and if this is not present then trace the circuit for failure of the relay or drive from the control unit. If present then the Element is faulty and should be replaced.
Click ; Element.
Mar 08, 2013 | Washing Machines
My broiler doesn't work in my JennAir S136 range and I think the problem is the selector switch. How can I confirm this?
To do that you could check if the correct power is going to broil element.That can by TURNING OFF CIRCUIT BREAKER, remove door by opening to appx 30 degree position where is shold stay open,pull off door,remove broil element and attach a volt meter set to measure at least 240 volts ac and attach the meter leads to the wires on broil element, restore power set controls to broil and check for 240 vac at element. If 240 vac at element it's the element thats defective, if 240vac not present the selector switch is the problem, espically if bake works
Good luck,i hope this helps ya diagnose your oven
Gene
Jul 31, 2011 | Ovens
What is office
It is an software application package of Microsoft which has various applications like
  • WORD
  • EXCEL
  • ACCESS
  • POWERPOINT
  • OUTLOOK
These applicatons are mainly used in business offices for preparing documents(WORD) , having an mail setup(OUTLOOK), preparing presentations(POWERPOINT),making an accounts calculation sheet(EXCEL).
The above are only few uses of the applications.
Nov 24, 2010 | Microsoft Office Computers & Internet
Oven does not heat
Your problem could be in your control switches or a bad heating element. Using a voltmeter check for 240 AC volts at the heating element connection. If voltage is present your heating element is most likely the problem. If no voltage is present then something in the control circuit is malfunctioned. I had this same problem about a month ago. Using the above troubleshooting I determined the heating element was defective.
Nov 20, 2009 | Cars & Trucks
Top element only working
How they work. First you need to know that cold water goes into the tank near the bottom (because of the "dip tube" inside the tank) and hot water is taken out at the top. Also hot water naturally rises.
so... when the tank is full of cold water the top element will come on and heat up the top 1/3 of the water then the bottom element will come on and finish heating the rest of the tank.
so... set them both at the temperature you want the water to be... about 120^F.
Apr 02, 2009 | Water Heaters
Excel report
Depending on what you are doing, you either are presenting data or a chart, pivot table. Those have to be prepared within Excel to produce the report.
Jul 21, 2008 | Microsoft Computers & Internet
Electric range not heating
Remove back cover of control and check bake leads. Or turn power off. Remove element (bake) pull forward slowly to expose the connections to element, remove from element, make sure they do not retract back into cavity. Make sure they do not touch anything and turn on power set control to bake then check voltage on leads. 240 volt is what you need. If no voltage then replace control. If voltage is present replace element.
Jul 12, 2008 | GE JBP65 Electric Kitchen Range
Microsoft Presenter 3000 Mouse Logo
18 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
