Question about Frigidaire FAP094P1Z Portable Air Conditioner
Carlton ac 9000
Does it need any maintenace at the start of the summer if it is working?
Car accelerates itself
Could be TPS sensor[RPM].
Jun 11, 2013 | Honda Civic Cars & Trucks
1999 VW Passat AC/heat doesn't work? The belt broke this summer? I was told should still blow heat even if no belt?
If you are talking about the belt for the ac compressor, yes the heater should still work.
If the blower is not working, you will need to have the blower motor checked for voltage and ground.
Dec 18, 2012 | 1999 Volkswagen Passat
Delta ac 9000 manual
I need user manual for delta ac 9000 air conditioning unit
Sep 08, 2012 | Heating & Cooling
My heat isnt working now but in the summer time my ac works. but last year my heat woulodnt work but then one day started working. then the summer time my ac wouldnt work then one day started working an...
what kind of air con is it. it would be a sticky reversing valve either from inside the valve or the solinoid pulling it siting on the valve. http://t3.gstatic.com/images?q=tbn:SMSfcwrA_p4i6M:http://www.daviddarling.info/images/reversing_valve.jpg&t=1
Nov 10, 2010 | Heating & Cooling
We have a Weatherking Heater/AC unit the heater works and the AC worked last summer when we tried the furnace this winter no heat found out it was the 24 volt transformer replaced it and heat worked fine...
I think you have a definite short and it's in the 24 volt circuit. The only problem is - 'finding a low voltage short' is not the easiest thing in the world to do - so - I would guess you'd need a Service Tech.
good luck!
Jun 28, 2010 | Heating & Cooling
Need guide bar and chain
Bailey's carries Carlton and may ship to Ireland (no promises). Please contact them (If not please reply to me below. TIA).
http://www.baileysonline.com/category.asp?catID=54
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 02, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Carlton ac 9000m air conditioner
Hey, give it back! or check the manufacture spec on the internet.
Aug 22, 2008 | Heating & Cooling
Frigidaire FAP094P1Z Portable Air Conditioner Logo
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
