Question about Abit VT7 Motherboard
Samsung r428 bios - Abit VT7 Motherboard
Samsung R428 notebook wont switch on
This problem, from your description, is very unlikely to be because of a change in your settings, if nothing happens when you try to turn your computer on.
If no power is being supplied to your computer - no lights come on - then
you might just have the combination of a flat battery and a faulty power adapter. You must test the power adapter (measure the output voltage with a voltmeter) or obtain another one (preferably temporarily/borrow) to see if your computer will turn on with that. If your power adapter has failed it must be replaced. If still in warranty, Samsung or your retailer/dealer should replace it at no cost. (you should not attempt to repair a power adapter)
Otherwise (or even as a first step) I suggest you contact Samsung support by email or Live Chat (details are on this
http://www.samsung.com/in/support/model/NP-R428-DA01IN
webpage.) Please have your computer's model number, serial number, operating system and other details to hand (the numbers
can be often be found on labels on the case of your PC)
18.April.2014
Apr 08, 2014 | Samsung New original R428 R403 P428...
I have samsung R428 laptop, backlight is not coming up. what should i do?
There should be a button to do this or a combination of buttons on your keyboard. Make sure you are pressing the function key if needed and then the increase brightness button. Best Wishes!
Mar 29, 2011 | Advent Netbook
Fix to issue where no output from fixed outputs but headphone output works
07e570b.jpgI took a picture of the board on my Lifestyle 5. Could someone point out which is R428? Thanks.
Nov 18, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Bose lifestyle 5
I cannot exactly solve this issue but I can make a comment based on investigation. Lots of people have this issue but there are very few comments to help solve the issue unfortunately.
I have the same issue and have been able eliminate various things because I have a second complete Bose Lifestyle 5 system.
It is clear the issue does not lie in the Sub and is related to the Music centre unit. I can use a second identical music centre to power my sub just fine and my broken Music centre cannot drive my second sub.
Now the issue is knowing where to track down R428 in the music centre which is the suggested fix to this issue. I have opened my unit and there are resistors various Resistors in the 400 range but no R428.
If anyone can help with the location of R428 in the Music Centre I would be very grateful.
Thanks,
Jeff
Nov 06, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Abit VT7 Motherboard Logo
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
