Question about AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800)
Regarding External Hard drive
I am trying to attach external portable hard disk of 250 GB to my Athlon AMD PC. It shows the Hard disk in my compiter but when i try to copy any file from external disk it shows error related to BIOS upgrade i guess. Kindly let me know if any solution.
  • Abhineet Aug 31, 2007
    Hi Dyllan,
    There is no such error that is displayed on the screen. Actually when i attach the external hard disk and then try to copy some files from it to my local system, then a Blue Color screen appears on the monitor saying some thing related to BIOS upgradation. So kindly help me out how shall i upgrade BIOS on my PC> my PC is Athlon AMD 1000 MHZ. Manufacturer is American Megatrends Inc. and the serial number that appears on my screen when i start my PC is 62-1017-001199-00101111-071595-VIA_K7-GA7ZMMH1-F. How i can get the BIOS set up with the help of above information.
    Abhineet Jindal
Hi Dyllan, Thanks for your suggestions. I am able to get the complete information of my system by running BIOS scan. I am pasting the same below. Kindly have a look and let me know how can i upgrade BIOS. My motherboard is KM133, rest of the info is mentioned below Computer name: VOLVRINE Your Ticket #: 35WHKKZ BIOS Type: AMI BIOS Date: October 17th 2001 BIOS ID: 62-1017-001199-00101111-071595-VIA_K7-GA7ZMMH1 BIOS OEM: 7ZMMH F5 - 062710 Chipset: VIA 82C305 rev 129 SuperIO: VIA 686 rev 64 at pci 7 Manufacturer: Gigabyte Technology Co., Ltd. Motherboard: KM133 OS: Microsoft Windows XP Professional Maximum Memory: UnknownMB Installed Memory: 128MB Memory Config: Slot1:0 Slot2:128 Thanks Regards Abhineet Jindal
Posted on Sep 02, 2007
  • 279 Answers
Could you tell us the exact error message?
Posted on Aug 28, 2007
  • John Goodman Aug 31, 2007
    Looks like you have a MSI MS-6590 KT4 motherboard in that. The bios update is here:
    And it says it fixes some USB compatibility issues, which does sound promising.
Doesnt want to be read by the computer it lights up and instals drivers doesnt show up in my computer
Your external hard drive likely has no partitions so Windows has no drive to mount. Follow these steps to create and format a partition for your external hard drive.
1. Press Win+R to open the Run command.
2. Type "Control" into the dialog box.
3. Double-click Administrative Tools.
4. Double-click Computer Management.
5. Select Disk Management under Storage.
6. Find the 250 GB External Hard drive in the right pane.
7. Right click on the drive and select "Create new partition".
8. After the partition is created you will need to format the partition.
9. Format the partition as NTFS unless you plan on booting off the hard drive, in which case format the partition as FAT32. You can also create multiple partitions if you want.
10. Enter My Computer and you will now see your external hdd.
Good luck and thanks for using FixYa.
Dec 29, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
My toshiba 250gb external hard drive doesnt show in my computer (xp) but it is in device manager?
Click Start
Right-mouse click My Computer
Click Manage
Expand the Storage branch
Click Disk Management
Click Disk Management (local)
Click to create a partition on the drive, and to assign a drive-letter.
Oct 27, 2010 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
All of a sudden, my external hard disk gone blank, all my data in the external disappeared ,..... any solution plsssss
try this administrive tools computer management removable storage you might find something there good luck
Aug 20, 2010 | Western Digital WD Passport 250GB Portable...
230 gb drive with 100gb used and only 70gb of free space showing
please check if the files are hidden. just go to the explorer -> tools -> folder option -> view tab -> then on the Advance Settings click the Show Hidden Files and Folders. then try to navigate your external hard drive.
Jul 02, 2010 | Western Digital WD Passport 250GB Portable...
Can i make my portable hard drive an external hard drive?
It is already. Just connect it to a USB port and it should pop up as a new drive.
Jun 02, 2010 | Buffalo Technology 250GB MINISTATION TURBO...
How to I reallocate my 500 gb external hard drive so I have more space for my laptop - I have 250+GB space avilable for my destop but I am getting "disk full" for the laptop.
you should be able to connect the external hard drive to your laptop and the drive should show up under my computer. Then just drag and drop or cut and paste any files you want to move to the external hard drive.
hope this helps.
May 21, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
PC does not detect Seagate 500GB external hard drive
Try using the device on another PC & see if it works. if it does then you have a issue with your PC. whast the OS you are using? also try another USB port.
May 06, 2010 | Seagate Free Agent Go Small 12 GB USB...
Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off Power Mgt tab
Feb 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
External Hard Drive connected but hidden !!!
Connect it to your computer.
Right click on my computer and select Manage
On the left side click on Disk management.
Now on the right side, look around and see if you spot the external drive there.
What do you see there?
Also look into device manager, then look for anything with ! or ? yellow marks.
May 03, 2009 | Western Digital WD Passport 250GB Portable...
Hi, at bootup go into the bios settings and make sure you have enabled the drive, some bios settings need to have any drive over 160Gb enabled. Do an auto detect and see how that works. Regards mistyman
Aug 28, 2007 | Computers & Internet
AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800) Logo
106 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
