Question about Toshiba DP2570 Printer
Trouble code uuuuuuuuuuuuuu - Toshiba DP2570 Printer
Auxilio tengo una copiadora DP8070 toshiba con el error UUUUUUUUUUUUUU, QUIEN TIENE LA SOLUCION
Posted on Aug 20, 2013
What is the number 12 trouble code on my 95 camry dx 2200 engine
1995 Camry 2.2L OBD1 Code 12
Trouble Code 12
Trouble Code 12 Definition:
Engine speed (RPM) sensor -circuit
Trouble Code 12 Meaning:
Wiring, RPM sensor, ECM
Diagnoses Time:
Voltage reading between Engine Control Module(ECM) and RPM sensor.
http://www.troublecodes.net/toyota/toyota-camry-cressida/
Mar 08, 2017 | 1995 Toyota Camry
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
What do these codes meen
Those a not OBD trouble codes. OBDII trouble codes start with a P and are followed by four numbers. P0305 would be a proper trouble code.
Jul 13, 2013 | 1999 Mercury Mystique
My '93 suzuki sidekick automatic transmission 4 wheel drive after warm up "overdrive off" starts flashing on and off and when on the drivetrain stops working
The O/D light's flashing means there is some kind of transmission trouble.
The codes are..
Trouble Code (1) Probable Cause
12 ............................... System Operation Normal
21 ..................... No. 1 Shift Solenoid Open Circuit
22 .................... No. 1 Shift Solenoid Short Circuit
23 ..................... No. 2 Shift Solenoid Open Circuit
24 .................... No. 2 Shift Solenoid Short Circuit
25 ............................. TCC Solenoid Open Circuit
26 ............................ TCC Solenoid Short Circuit
31 ............ Vehicle Speed Sensor Open Or Short Circuit
32 ................ Throttle Position Sensor Short Circuit
33 ................. Throttle Position Sensor Open Circuit
34 ................ Defective Park/Neutral Position Switch
36 .............. (2) No Signal-Both Vehicle Speed Sensors
(1) - Check listed component for probable cause. Also check wiring and connections of specified component.
(2) - No signal from both transmission and speedometer mounted vehicle speed sensors.
If a trouble code is present, OD OFF light will flash a trouble code. The number of flashes will equal first digit of trouble code. After a one second pause, second digit will be displayed. If more than one trouble code is present, next trouble code will be displayed after a 3 second pause. Smallest number trouble code will be displayed first. Trouble codes will be repeated.
Hope this gave you some insight on the issue.
Mar 08, 2011 | 1993 Suzuki Sidekick
My Toshiba e161 printer error code on E 7. what problem in my printer and how the solved the problem
what is the sub code?
main code sub code description
E7- 02 LSU trouble 10 Shading trouble (Black correction) 11 Shading trouble (White correction) 12 Shading trouble 16 Abnormal laser output
more details digivisionm@gmail.com BR
Mar 09, 2010 | Toshiba e-Studio 161 Copier Copier
Air bag sensor keeps flashing
If a concern is detected, the air bag control module will communicate by flashing the warning indicator. A diagnostic trouble code (DTC) is logged by the air bag control module in a nonvolatile memory. For additional information, refer to Diagnosis and Testing in this section.
Lamp Fault Codes (LFC)
Item Part Number Description 1 One flash cycle: Driver air bag trouble code 2 Two flash cycle: Passenger air bag trouble code 3 Three flash cycle: Trouble code common to both driver and passenger air bag circuit 4 Four flash cycle: Safety belt pretensioner trouble code common to both driver and passenger pretensioner circuits 5 Five flash cycle: Driver side air bag trouble code 6 Six flash cycle: Passenger side air bag trouble code 7 Not used 8 Not used
Apr 10, 2009 | 2001 Ford Focus
Airbag flashes 10 times misses a flash then repeats
Try clearing the codes & see if it returns. I do not see a code fault 10. Starts at 12.
Section 01-20B: Restraints, Passive — Supplemental Air Bag System 1995 Town Car, Crown Victoria, Grand Marquis Workshop Manual DIAGNOSIS AND TESTING Diagnostic Trouble Code Clearing Procedure to Clear Diagnostic Trouble Codes from Diagnostic Monitor Non-Volatile Random Access Memory.
Normal Operation
The air bag diagnostic monitor (14B056) continually checks the air bag system for readiness. When a fault condition is detected, the DTC associated with that fault is stored in the air bag diagnostic monitor's Non-Volatile Random Access Memory (NVRAM). After writing the DTC to NVRAM, the air bag diagnostic monitor signals the fault by flashing the appropriate diagnostic trouble code on the air bag indicator. The diagnostic trouble code written to NVRAM is permanently stored in the air bag diagnostic monitor until cleared by the diagnostic trouble code clearing procedure.
  • Upon each cycle of the ignition switch (11572) , the air bag diagnostic monitor checks for diagnostic trouble codes written in NVRAM. If any diagnostic trouble codes exist in NVRAM, the air bag diagnostic monitor will then check to see if these fault conditions are still present.
  • If the conditions of the diagnostic trouble code in NVRAM are still present, then the air bag diagnostic monitor will use the air bag indicator to flash out the diagnostic trouble code number that was written in memory.
  • If the conditions of the diagnostic trouble code are not still present (indicating an intermittent or serviced fault), the air bag diagnostic monitor will use the air bag indicator to flash out a DTC which is the sum of the diagnostic trouble code in NVRAM plus 40.
Example: Due to corrosion, high resistance develops on the driver side air bag circuit. The air bag diagnostic monitor stores a diagnostic trouble code 32 in NVRAM. Upon each cycle of the ignition switch , the air bag diagnostic monitor checks the resistance of the driver air bag circuit.
  • If the resistance is still high, the air bag diagnostic monitor causes the air bag indicator to flash out a DTC 32.
  • If the resistance falls within the normal range due to service or an intermittent condition, the air bag diagnostic monitor causes DTC 72 to be flashed on the air bag indicator.
Once a fault has been serviced, the associated diagnostic trouble code may be cleared from NVRAM. Only diagnostic trouble codes that the air bag diagnostic monitor sees as repaired or intermittent may be cleared (diagnostic trouble codes 52 and above). In no circumstances can hard fault conditions (diagnostic trouble codes 45 and below) be cleared.
  1. Follow the diagnostic procedures as outlined to service the fault condition flashing on the air bag indicator.
  1. Cycle the ignition switch to OFF and then to RUN.
  1. Observe air bag indicator prove-out (six ± two seconds) followed by diagnostic trouble code (52-85) flashing completely one time.
  1. Locate the Diagnostic "Trouble Code Clear" Connector located underneath the glove compartment (06010) containing Circuits 631 (T/R) and 57 (BK).
  1. Use a jumper wire to short Circuit 631 (T/R) to Circuit 57 (BK) or to another good ground. This short must be made after the diagnostic trouble code flashes completely one time, but before the warning light stays on continuously.
  1. Hold short until air bag diagnostic monitor tone sounds (approximately five seconds).
  1. Release short on Circuit 631 (TAN/RED STRIPE) to Circuit 57 (BLACK). This short must be released within 25 seconds after the diagnostic monitor tone sounds. Diagnostic trouble code is now cleared from NVRAM. Next highest priority diagnostic trouble code stored in NVRAM (if one exists) will begin flashing.
Feb 09, 2009 | 1995 Lincoln Town Car
Toshiba DP2570 Printer Logo
122 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
