Question about Coleman Grilling
Gas grill regulator - Coleman Grilling
Loringh
  • 185 Answers
SOURCE: sears gas grill
If it was me I would return it. You did the right thing by testing it on another grill. You should not have to accept a new grill that is not working properly.
Loringh
Posted on Nov 06, 2008
  • 492 Answers
SOURCE: Find Weber gas grill regulator
Try Home Depot.
Posted on May 06, 2009
SOURCE: Regulator doesn't allow gas to flow to grill
Shut off the gas at the tank and disconnect everything.
Unscrew the plastic cap on the regulator. Inside is a flat screw top that has a single slot or an X-shaped slot. This is the pressure adjustment. It controls the diaphragm that regulates gas flow.
Note where it's set. Use a Sharpie to mark the adjuster on its edge (place a dot there), and make a corresponding mark on the threads next to it.
Next, use a large screwdriver or a coin to spin the adjuster counterclockwise three or four times. Pay attention to the number of turns. Now, screw it back in (clockwise) the exact same number of turns, stopping at the index mark you made.
Next, turn the adjuster two turns clockwise, followed by two turns counterclockwise. The idea is to end up where it was originally set. This action unsticks the regulator's valve seat. Done.
Put the cap back on, hook it all up, open the tank valve, and make fire.
Oongawa!
-Peegoo
Posted on Jun 27, 2009
gcken
  • 140 Answers
SOURCE: gas regulator won't let gas flow
Replace the regulator it is bad
Posted on Apr 04, 2010
radar001
  • 1051 Answers
Turn gas tank off and disconnect connection fron tank valve. Re-connect and turn gas on. Check for leaks with soapy water solution. Tighten if needed. Some regulators will detect leaks and cut off gas.
Posted on May 14, 2010
My Uniflame grill may have a clog somewhere through the fuel delivery system, or at the the tank connection, how would I be able to find the culprit?
Hi boltbucrayfa...
I think your culprit is the gas regulator valve...
If it is not working properly then it will not deliver the proper amount of gas to the burners.
Check all your burners to make sure they are not plugged...
The when you are outside away from Flames and ignition sources.
Remove the hose from the grill...open the gas to the grill (you have the hose off the grill) and listen to the flow of gas...if it is very low then there is your problem.
You can shut off the flow of gas, then tap the gas regulator on the sides, top and bottom lightly with a hammer and then turn back on the gas to see if the gas flow increased...if it did, then shut off the gas and rehook up the gas line to the grill..and your good to go grilling again.
Some gas regulators have an adjustment under the removable cap.
If the gas flow did not increase, the replace the gas regulator
Please take time to rate me
Sep 26, 2011 | Uniflame FG2204C Grill
Gas very slow to come after valve opened - grill connected to natural gas. After waiting up to 1 hour gas eventually comes and the grill will light. Wait time becomes increasingly longer with each use
Unhook the regulator, and open valve momentarily to see if gas is present under any pressure.
DON'T BE SMOKING. If gas hisses out, Replace the regulator with a new one.
Regulator uses springs and diaphrams. Either the spring is weak or the rubber diaphram is stiff or (oil contaminated) swollen and sticky. DON'T try to repair it. Not worth the risk!
Either way, the only thing between the gas supply and the grill is the regulator. Have it replaced.
DO NOT OPERATE WITHOUT A REGULATOR
Jan 10, 2011 | Grilling
Gas regulator won't let gas flow
May 12, 2010 | Cal Flame 5-Burner
Mar 20, 2010 | Cal Flame 5-Burner
Have gas at inlet but no flow at burners
If your grill has a regulator on it and you get gas before the regulator, but not at the burners, then your regulator is probably bad. If there is no regulator, or you get gas flow after the regulator, then you may have a blockage in the orifice(s) in the valves or the venturis in the burners.
Dec 27, 2009 | Lynx L42PSR1N Gas Grill
Gas is not getting to the burners on my Sears Kenmore gas grill.
check if regulator fully screwed to tank, turn on tank,then last burner,should hear/smell gas. if not replace regulator
Jun 25, 2009 | Kenmore 16225 Grill
Grill with a full tank of gas will not get hot
Low flame, low temperature, yellow flame: This has become the biggest problem with many grills these days and it's almost always because of the regulator (the funny UFO shaped thing on the gas hose). Regulators seem to be stickier these days and when they stick you don't get enough gas to generate a good grilling temperature. To get your regulator unstuck you need to release the pressure on it. Follow these steps exactly:
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
To keep the regulator from sticking again make sure that you turn off the control valves first, then turn off the tank valve. Always open your tank valve slowly. If this doesn't work give it a second try. If you still have low flame then you probably have a faulty regulator that will need to be replaced.
May 24, 2009 | Char-Broil Patio Caddie 4654870 (LP) Grill
Heat is about low or just a little higher on high setting
May 24, 2009 | Kenmore 774 sq. in. Cooking Area Gas Grill...
Sears gas grill
Loringh
Nov 04, 2008 | Grilling
Grilling Logo
52 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Treefrog15
Treefrog15
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
