87m manual folder
When I place the paper in the feeder and press start, the papers are coming out with the corners folded in. Sometime only one side, sometimes both. I cleaned the rollers and adjusted the fold stops.
JayBlair
  • 328 Answers
SOURCE: my printer folds top lefthand corner intermittently? why?
Do you run labels through the unit? If so, ther is probably a little bit of the glue or label that is inside the feed asm. Hard to find it. Have you tried to open the top door when the paper has fed just under the toner cartridge to see if the bent edge begins at that point. Did the problem appear right after the new maintenance kit? Do you still have the old fuser asm? Reinstall the old fuser and see if problem goes away.
Posted on Jul 31, 2007
IB4G2008
  • 3587 Answers
SOURCE: Printer won't stop jamming
sounds like your printer wants to form it's own three piece band(kidding here).
sounds like you rollers are dirty or have something on one or both of them..like tires on a slippery road, these need to be clean and dry.
Posted on Mar 08, 2008
SOURCE: Paper jam in a Dell 1710
This is a terrible terrible printer. Aside from taking the printer apart it seems like your only option is to pick the paper out bit by bit with needle nose pliers.
Posted on Aug 18, 2008
SOURCE: HP LJ 4350 paper folding problem
It could be either the paper feed assembly, part # RM1-0012, or the registration assembly, part #RM1-1098. These parts can be bought at TSAworld, phone # 1-800-633-6626
Posted on Aug 20, 2008
DLBurkhart
  • 210 Answers
SOURCE: Magicolor 2300dl horizontal paper folding
I kept digging until I found some helpful, lucky people that stumbled across a solution. The cost of doing the repair yourself is about $1 for superglue.
I detailed the repair in my blog: http://dlburkhart.spaces.live.com/blog/cns!5BA5F950B86A8BE5!182.entry.
I don't know if that URL will work as a permanent link. So, just in case, the same information is on my business web site on the Tech Tips page: http://www.BurkhartTech.com/Tips.html.
I hope to have helped.
If anyone can use a custom web site, I can really use the work. I left work a couple of years ago to be a stay-at-home dad and to try to start up a web site business. Things started out okay. But the economy soured, all of my business dried up, and now I can't find full time employment.
Posted on Dec 15, 2008
Brother MFC-8480DN Printer jammming
try to clean the document feeder, i think there so many scratch of small piece of paper that why the printer is paper jam.
Feb 07, 2014 | Brother MFC 7840W Printer
I have an epson printer and when I hit print, the paper slides right thru & says paper jam
  • Carefully remove the jammed photo paper. Gently pull the paper up and out of the paper feeder tray.
  • 2
    Reload the paper into the tray. Stack the paper on a flat surface and then carefully slide the paper stack straight into the paper feeder tray---along and aligned with the right side of the tray. Secure the stack in place by sliding the left "edge guide" against the paper stack.
  • Sponsored Links
  • 3
    Press the "OK" button to resume printing. If you had a "Paper is jammed in the printer..." error message displayed on the control panel LCD, pressing "OK" should also clear the message.
  • 4
    Pull the paper from the printer, if the status message reappears and/or the printer doesn't print, and check the paper for folds, buckling and curled edges or corners. Also check the sheets for sticking. If any of your sheets stick or have damage, remove them from your photo paper stack and replace with new sheets. Reload the paper and press "OK" to try again.
  • Performance Chip
    May 22, 2012 | Epson NX415 All-In-One Printer
    The paper keeps jamming, I cant see anything in the way. any help is appreciated.
    If paper doesn't feed correctly when printing, remove it and fan the edges of the paper to separate the sheets. Reload the paper against the right side and slide the edge guide against it. Do not load too many sheets at once.
    If paper has jammed: 1. Press x Start to eject the jammed paper. 2. If paper is still jammed, gently pull it out from the output tray or sheet feeder. If paper is stuck inside, press the P On button to turn off the printer. Then lift the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the printer back on.
    If documents don't feed correctly in the Automatic Document Feeder, make sure the corners of the paper are not bent, folded, or curled up. Do not load more than 10 sheets of legal-size paper at a time. If documents have jammed: 1. Open the ADF cover and pull any paper out to the left. Caution: Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism. 2. Select Yes or press OK to clear any messages on the display screen. 3. Reload the paper.
    Feb 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
    Cannot clear paper jam
    Paper Jams in the Automatic Document Feeder
    If you're loading legal-size paper, insert only 10 sheets at a time to prevent paper feeding problems.
    If paper jams inside the ADF, clear the jam and reload the paper as follows:
    1.
    Open the ADF cover and remove any jammed paper.
    Caution:
    2.
    Press OK, then select Yes and press OK to clear any messages on the display screen.
    3.
    Reload the paper. Make sure the corners of the paper are not bent, folded, or curled up.
    Jan 11, 2011 | Epson WorkForce 600 All-In-One InkJet...
    WILL FEED PLAIN WHITE PAPER BUT WILL NOT FEED PHOTO PAPER
    Follow the steps:
    •1
    Turn on the printer and press the Paper Feed switch until the Auto Sheet Feeder indicator light turns on.
    •2
    Pull up on the paper sheet feeder on the top and back of the printer and slide out the paper support.
    •3
    Take a stack of no more than 10 pieces of photo paper and flatten the corners, if they are curled. Curled corners may cause jams within the printer.
    •4
    Place the paper in the paper sheet feeder with the printable side of the paper facing up. The printable side of photo paper is the shiny or whiter side of the paper.
    •5
    Print your documents as needed.
    Paper Cassette :
    •1
    Switch on the printer and press the Paper Feed switch until the Cassette indicator light turns on.
    •2
    Pull on the cassette on the bottom of the printer to slide it out of the printer.
    •3
    Flatten the corners of a stack of no more than 10 sheets of photo paper if the corners are curled. The paper may become jammed in the printer if the corners are curled.
    •4
    Place the stack of paper in the cassette so the paper is touching the right side and the printing side of the paper is facing down. Adjust the plastic paper guides so they touch the paper. The paper stack guides help facilitate the paper moving into the printer.
    •5
    Slide the cassette back into the bottom of the printer. The printer is ready for printing.
    Oct 20, 2010 | HP PSC 2355 All-In-One InkJet Printer
    It stopped faxing through the feeder and said feeder errror. its a HP j4680 all in one office jet
    Hello, Brittany.
    Give this a try (from HP Support):
    Complete the following steps to check the condition of the paper, reload the original, and then open and close the Automatic Document Feeder cover.
    The main reason for this issue is that the ADF rollers that pick up the papers might not grip the paper because dirt sticks to the rollers.
    Step One: Check the paper and reload the original
    The condition of the paper, or the amount of paper, might prevent the ADF from picking it up and feeding it through the product.
    1. Make sure that the ADF tray contains fewer than 25 sheets of paper.
    2. Make sure that the ADF tray contains no photo paper or carbon paper.
    3. Make sure the paper in the ADF tray meets the following criteria:
    * No curls, folds, creases, or tears
    * No staples or clips attached
    NOTE: Folded paper, torn paper, or paper with rough edges might not feed correctly. If your original is folded or damaged, either reprint the original or try to smooth out the damaged portions.
    4. Reload your original, with the print side up, into the ADF tray. Place the pages so that the top edge of the document goes in first. Slide the paper into the ADF tray until you hear a beep or see a message on the display indicating that the loaded pages are detected.
    * If still a problem, go to the next step.
    Step Two: Open and close the ADF cover
    NOTE: Remove all originals from the ADF tray before you open the ADF cover.
    1. Open the ADF cover, and then close it again.
    2. Press the OK button.
    Follow these steps to turn the product off and then on again.
    1. Press the Power button to turn off the product.
    2. Wait 15 seconds.
    3. Press the Power button to turn on the product.
    Hope this helps.
    Feb 26, 2010 | HP Office Equipment & Supplies
    How topaper load cannon mp 160 pixma
    Loading Paper into your Canon MP 160 Pixma.
    A) Loading Paper :
    Follow this procedure:
    1) Open the Paper Support, then pull out the Paper Support Extension.
    2) Place a stack of paper (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
    * Set the Paper ThicknessLever to the correct position for the paper.
    Note : Set the Lever to the left for most paper. When the Lever is set to the right, the confirmation message appears before the machine starts printing.
    Important : Make sure the stack does not exceed the Load Limit Mark.
    B) Loading Envelopes
    Follow the following steps:
    2) Prepare the envelopes for loading.
    Important : * Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
    * Remove any curling by holding the edges diagonally and bending them gently.
    * If the edges of the envelopes are inflated or curled, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
    * Ensure that no curl or puff exceeds 1/8 in. (3mm).
    3) Place the stack of envelopes (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
    * Load the envelopes in the Auto Sheet Feeder with the short side down.
    * Set the Paper Thickness Lever to the right.
    Important : Make sure that the stack does not exceed the Load Limit Mark.
    Hope this helps. PLease rate my response.
    Thanks
    Have a good day.
    Dec 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    Will not print
    Cleaning the Interior of the Machine If the interior of the machine becomes dirty, paper printed onto by the machine may get dirty, so we recommend performing
    cleaning regularly.
    Note: Ensure that the Inner Cover is closed.
    1. Press <ON/OFF> to turn on the machine, then remove any paper from the Auto Sheet Feeder.
    2.Press the Open button to open the Paper Output Tray, and open up andset the extension by pressing down the hollow on the front side.
    3.Prepare a single sheet of A4- or Letter-sized plain paper. Fold it inhalf along the long edge. Unfold the paper, then load it in the AutoSheet Feeder with the open side to the front.
    insertfoldedpaper.gif 4. Start bottom plate cleaning.
    1. Press <COPY>.
    2. Press <Menu> repeatedly to select [4.MAINTENANCE].
    3. Use [left.gif ] or [right.gif ] to select [BOTTOM CLEANING], then press <OK>. The sheet of paper is automatically fed in and then out of the machine.
    Ifthe printed paper is smudged, clean the inside of the machine again. Ifthe problem remains after performing cleaning again, the protrusionsinside the machine may be stained. Clean them up.
    Note:Even if the Cassette is selected as the paper source, paper will be fedfrom the Auto Sheet Feeder. Do not perform any other operation whilethe bottom plate is being cleaned.
    Cleaning the Protrusions inside the Machine
    If protrusions inside the machine are stained, wipe ink off the protrusions using a swab or the like.
    I hope it helps!!!
    Nov 13, 2008 | Canon PIXMA MP530 All-In-One InkJet...
    Paper twists when feeding
    there is something stuck in the feeder.place one thick paper and help it with your hant to pass into feeder.anything is inside will unstuck
    Nov 04, 2008 | Epson Stylus Photo 950 InkJet Printer
    Aug 08, 2008 | HP LaserJet 4350 Printer
    18 people viewed this question
    jasbo
    jasbo
