SOURCE: I press the power on and the lamp led not the
Hello :
Try to change the bulb .
Here is how :
1:Make sure that your power switch is off and that the power cord
is unplugged from the electrical socket.
It is also wise to unplug
any other cables and label them in order to restore them in the right
way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the
outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro
fiber products and not paper.
Please note that in some projectors a
small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding
touching the glass of the lamp itself.
Touching the lamp will deposit
skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, replug the cables and power up the
projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp.
please rate !
SOURCE: Projector will not turn on. The blue light stays
Hi, you need to see the maintainance and troubleshooting section of the user manual so as to know the cause of the problem and how to fix it.
You can see the maintainance section that deals with your particular problem on page 46 of the user manual on this LINK......
SOURCE: I have a Viewsonic PJ558D
You need to reset the lamp timer. This is likely your problem since you changed the lamp.
Turn the projector on. open the menu. Go to advanced. Scroll down to the first option which should be auto source. Make sure this option is checked. While on this option press right once, left twice, right 3 times, then left 4 times. Another menu will appear. Scroll to lamp time and push enter. This will take it back to zero.
SOURCE: when turn on projector the
The control processor of the projector has failed and the firmware was corrupted.
The only way to fix that is by replacing the mainboard - that will cost you around $400. You now must decide if it's worth paying so much money for a repair or if it would be better to just get a new projector for a little more money.
hi,Navin I have a view sonic projector that used for my church. The problem is it runs for just a minute it will suddenly shutoff by itself.Please help me how to fix it thanks.
