Question about RCA Televison & Video
Rca led 2431a flat screen tv
Only 9 volts coming from power supply,tv keeps going off, wth...frustrated
leorcid
  • 281 Answers
SOURCE: Sony wega model: kv-32FS120 doesn't turn on
Check your power supply board and resolder the pcb, check the switching diodes and zeners.
Posted on Jan 30, 2008
SOURCE: polaroid FLM-2601 power supply board
The part number is 6LM00220G0 and is priced at $80.54 at circuit city repair. It is easy to install once you remove the cover from the back of the TV and the housing for the power supply.
Posted on Apr 08, 2008
mediarich
  • 188 Answers
SOURCE: Tv not coming on
Your TV will probably not work on 95 volts. It may even damage your set. To see if your TV is still working properly you need to find a source of 108 volts at the minimum. Why is your voltage so low? Are you using a meter to check it?
Posted on Sep 18, 2008
Matampong
  • 153 Answers
SOURCE: RCA 37" Flat panel TV
The inverter might be cause of this problem, theres some components defective at the inverter section, bring to repair shop for repair.cheers.
Posted on Nov 10, 2008
  • 83 Answers
SOURCE: Power supply unit, TV cuts off after 20 seconds
i would recommend ebay, they usually have lots of parts for lcd tvs
Posted on Jan 25, 2009
Sanyo DP46142 TV comes on for approximately 30 seconds and then screen goes black. Power LED stays on.
Sounds like a backlight problem to me. If you input a signal to the HDMI or Composite input and then it goes black have you tried taking a flashlight to the screen to see if the picture is still there but just dark? That would indicate a backlight issue. That model appears to be an LED edge lit backlight, so if the picture is still there after going black your going to have to trace out the backlight circuit and see whats going on. Usually with LED backlighting if it comes on at all then the LED's are good, its just the driver supply thats failing to keep them on. Some TV's have a small separate board that provides the backlight control, but i suspect with this model its on the power supply board and not the motherboard. Have you checked that board? It could be bad caps on the power supply board, check the voltages to the backlighting when it lights up and then when it goes dark. It could just be some failed capacitors on the power supply causing that voltage rail to drop off.
May 04, 2017 | Sanyo Televison & Video
How do I fix my LCD TV?
If you hold a flashlight up to the screen do you see any image or video
May 13, 2016 | LG Televison & Video
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Oftware upgrade application RO.8L12.8.01 keeps coming on cant get it to leave for hrs. sometimes cant view programs while its in this screen mode
Noise in 5 volt standby voltage may have already corrupted eeprom. Change the two 680uf/16 volt and other bloated caps in power supply to see if tv is still salvagable.
Jun 24, 2014 | RCA L42WD22 42 in. LCD Television
RCA LED42C45RQ 42" LED LCD HDTV Shutting Off by itself
These flat panel tv's from china have cheap capacitors. Check to see if any capacitors have pushed up top, this indicates blown or dry capacitor. Replace with exact value, in the power supply area (is where they go bad). TV has a monitoring circuit, and if standby (or ready voltage) is not adequate, tv will shut off or stay in standby mode. Little tired today, so hope that gives you an adequate answer.
Feb 14, 2014 | RCA L37WD12 37 in. LCD HDTV
Rca 32hd31 tv light comes on but the screen is black,no sound,no pic. it has been working fine for 21/2 years . no storms lately. any help would be great
There are 3 option:
a. power supply no 5 volts and 12 volts
b. Main board defective your can replace it will new board or repair
c. Check the fuse of 5 V and 12 V.
Your LED light voltage is fine. These are only the option i could suggest....
Aug 16, 2011 | RCA L32HD31 32 in. LCD HDTV
Rca remote control CRK76TA1 has problem w/ sending signal to tv. if i wiggle the eye, it will work for a while. now, no amount of wiggling will work. i have tried removing batteries and pushing every...
Remote is broken.Replace it.
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Jul 06, 2017 | RCA Televison & Video
Polariod flat screen tv when powered up power
your right there will be a bad caop in the power supply the can will have a domed or puffed top the value is printed on the side replace it and it will all set to go
Dec 23, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
RCA 32 in TV no picture no sound just a beeping noise TV power is on
the tv has one part of the power supply working this is needed to have the microcontroller ready to work. But the tv needs more than that for work im talking 'bout the high voltage power supply who is now damaged. the parts required depends on the diagnosis in the bench but at least two are needed. the cost of this repair of course depends in how many parts are going to be replaced, but i concider this repair kind of average in this technology.
Apr 13, 2009 | RCA 32V524T TV
42FD9954 philips plasma TV flashing LED it wont come on
The problem is in the standby power supply. the standby power supply generates the 9 volts and the 5 volts requird by the tv. If you measure the 9 volts source, with only the red light on, the correct voltage is 9 volts. However if the 9 volt measures 6.5 to 7 volts it is too low and the startup relays cannot operate. My set is a model 42FR9954/17S. In this set if capicator, 2603, is heated the voltage climbs to 9 volts and the relays work. If cold air is applied to the capicator the relays fail to operate. Replace capacitor 2503 and the problen is fixed. This capicator is: 47 Ufd, rated @ 450 volts, and is 20%.
Nov 08, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Televison & Video Logo
32 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
