Does the Acer Aspire 5733 support dual-band technology
Thinking of upgrading my router to a BT Home Hub 4,but don't know if my laptop supports dual-band technology, or if I need to buy the BT dongle which is available to purchase as an extra to the Home Hub 4.
mtspace
  • 103 Answers
SOURCE: cd drive for acer aspire 5610
Wow, Acer sure doesn't make it easy for you to reach live support.
When I requested the phone number for support, this was the information I was given.
Locating Support Information
Click on Start, Control Panel
Double click on Performance and Maintenance
Double click System.
At the bottom of the System Properties window, click on Support Information.
Posted on Dec 23, 2007
pankaj_dic
  • 1250 Answers
SOURCE: Wireless never worked in Acer Aspire 3000 notebook ..help!
you have to install the wireless drivers, check it on cd
Posted on Oct 26, 2008
frankzjm
  • 191 Answers
SOURCE: Acer Aspire 7730 UNABLE TO GET WIRELESS CONNECTIVITY
you need to try
1) check bios aetup screen thereis setting wireless enable/disable
and check xp control panel--system--device manager wireless driver no yellow triangle mark( which need update driver)
2) check wireless switch at laptop frront or right side, set to "on" to make sure the wireless light not on. if wireless indicate light still black means your wireless card out of works, check wireless card by open small back cover clean pins and reinstall it again
3) finally you might need change a wireless card.
Posted on Feb 09, 2009
Lepcha
  • 25 Answers
SOURCE: Acer Aspire 5735 Laptop Webcam operating instructions needed
Try going to the "start button" then> "control panel" and then> "scanners and cameras". Open it and you might find your device and click on it.
If that is not you r problem then reply
Posted on Jun 09, 2009
  • 30 Answers
SOURCE: my acer aspire 5535 wont connect to wireless
Most Acers use an Itel form of IPN2220 Wireless card. If yours does, your using XP and your router is using WPA or WPA2 (TKIP or AES) security then you'll need to update the driver by searching for it manually using the Custom button (Hardware) in Windows update (instead of Express). This driver is not part of XP service pack 2 or 3. In my experience if you don't update to the newest common form of home wireless security (WPA2 AES) then the older formats seem to become unreliable in the way you describe
Posted on Mar 25, 2010
Hi, I have an acer aspire 5535 and I am experiencing problems connecting to my TP-LINK router. After resetting the router and my laptop I can occasionally connect to the internet, however after a period...
Had similar problem with a kindle and BT home hub - had to manually change the wireless channel on the router but couldn't get a channel that worked when the microwave oven kicked in.
I had two kindles and 2 home hubs and came to the conclusion that some devices must be slightly our of calibration and will struggle to connect on certain channels especially if there are near by routers.
In the end I changed my BT router for a Linksys and its been fine since.
Feb 25, 2013 | Acer Aspire 5535-5050 Notebook
Recovery disc for aspire 5733
You can download a recovery CD for your model Acer from this WEB site.
http://www.user-guides.co.uk/acer/acerrecovery/acer.asp?keywords=acer+aspire+5733+recovery+cd&recor=1
Apr 07, 2012 | Computers & Internet
Acer Aspire9301 AWSMi Laptop will not work
Dear sir
good day
this problem can be solved if Acer company installed
a new firmware for the lab top .... to upgrade the Main
board as many computers company do
thanks
Dec 18, 2009 | Acer Computers & Internet
Acer wireless dirver for XP
This model has one of two makes of Wifi card/chip installed its either;
1 Intel® Wireless WiFi Link 4965AGN (dual-band quadmode
802.11a/b/g/Draft-N) Wi-Fi CERTIFIED® network
connection, supporting Acer SignalUp™ with InviLink™
Nplify™ wireless technology
or
2 Intel® PRO/Wireless 3945ABG (dual-band tri-mode
802.11a/b/g) Wi-Fi CERTIFIED® network connection,
supporting Acer SignalUp™ wireless technology
If you have the incorrect driver it wont install
Hope this helps
here are the links for you to download the correct ones
http://global-download.acer.com/GDFiles%5CDriver/Wireless%20LAN/Wireless%20LAN_Atheros_%207.2.0.215_VistaX86.zip?acerid=633639023394558300&Step1=Notebook&Step2=Aspire&Step3=Aspire%202920&OS=V10&LC=en&SC=PA_7
and
http://global-download.acer.com/GDFiles%5CDriver/Wireless%20LAN/Wireless%20LAN_Broadcom_%204.170.25.19_VistaX86.zip?acerid=633639023397522319&Step1=Notebook&Step2=Aspire&Step3=Aspire%202920&OS=V10&LC=en&SC=PA_7
Aug 10, 2009 | Computers & Internet
Which HDD Supported To Acer4710z Laptop
Acer Aspire 4710 General
  • Built-in Devices Stereo speakers , Wireless LAN antenna
  • Width 13.5 in
  • Depth 9.7 in
  • Height 1.7 in
  • Weight 5.7 lbs
  • Color Black/light gray
  • Localization United States
  • Notebook type Thin-and-light (4-6 lbs.) , Budget
  • Screen type Widescreen
  • Wireless capabilities IEEE 802.11b , IEEE 802.11g
Processor
  • Processor Intel Pentium Dual Core T2080 / 1.73 GHz
  • Multi-Core processor technology Dual-Core
  • Data bus speed 533.0 MHz
Cache Memory
  • Type L2 cache
  • Cache size 1.0 MB
RAM
  • Installed Size 1.0 GB / 4.0 GB (max)
  • Technology DDR2 SDRAM - 667.0 MHz
  • RAM configuration features 2 x 512 MB
Storage Controller
  • Storage controller type Serial ATA
  • Storage Controller / Serial ATA Interface Serial ATA-150
Storage
  • Floppy Drive None
  • Hard Drive 120.0 GB - Serial ATA-150
  • Storage Removable None
  • Hard drive type Portable
May 30, 2009 | Computers & Internet
Can i upgrade my processor from 1.9ghz to 2.8ghz?
According to Acer's website sepcifications, that Laptop is only upgradeable to 2.3GHz:
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=606&formid=3404&website=AcerPanAm.com&siteid=7117&words=all&keywords=&areaid=2
AMD Turion 64 X2 dual-core mobile technology TL-66/TL-64/TL-60/TL-58/TL-56 TL-52 (2x 512 MB L2 cache, 2.30/2.20/2/1.90/1.80/1.60 GHz, 1600 MHz HyperTransport Bus),
AMD Turion 64 mobile technology MK-36/MK-38 (512 KB L2 cache, 2/2.20 GHz,), supporting AMD PowerNow! technology and AMD HyperTransport technology or
AMD Athlon 64 X2 dual-core mobile technology TK-53/TK-55 (2x 256 KB L2 cache, 1.70/1.80 GHz), supporting AMD PowerNow! technology and AMD HyperTransport technology
Apr 17, 2009 | Acer Aspire 4520 Notebook PC
Acer problem
You will need to see if ACER has the software in question for Vista. You can find this on acer.com in support > drivers
Feb 27, 2009 | Acer Aspire 5315 Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
