Question about Jenn-Air JCD2389G Side by Side Refrigerator
Clicking noise Jenn-air JCD2389gES stopped cooling in both the refrigerator and freezer. I hear a click sound every now and then. It sounds like it is clicking on but then nothing happens. The clicking sound is coming from the area where the round egg shaped thing (maybe compressor). The fan is also running in the back.
2 Suggested Answers
omaharox
  • 166 Answers
SOURCE: Jenn-air JCD2389DES stopped cooling in both the
2 things may cause this condition.
1. The relay and overload which starts the compressor has failed.
This is an easy fix.
2. The compressor has failed.
The compressor can be replaced and is worth doing if the unit is in good shape.
Posted on Jan 15, 2010
The refrigerator and freezer are not cooling on my Jenn-Air JCD2389GES. I have checked the cooling coils and they are dry no frost. I cleaned out the coils in the back. The fan in the lower back runs fine...
Check compressor is running with exact current (Amps). Keep your hand on discharge line on condenser coil to feel warm. If no warm means no gas in the system. If warm and no whistling sound in freezer means system under chocked.
If no gas, find leak an arrest it. Vacuum and do gas charging. If chocked, release all gas, flush out the system, replace filter drier, vacuum and recharge gas. Helpful?
Jan 26, 2011 | Jenn-Air JCD2389G Side by Side...
I have a Jenn Air side by side refrigerator that started making a humming and clicking sound last night and this morning it stopped cooling on both sides. What could it be?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 24, 2010 | Jenn-Air JCD2389G Side by Side...
I have a jenn-air jcd2389ges that is not getting cold.it runs and works but is not getting cold ..
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
May 20, 2010 | Jenn-Air JCD2389G Side by Side...
Buzzing/humming noise with jenn-air bottom freezer
i have this problem too on my GE Profile. A youtube video seems to suggest a compressor problem. Turn off the fridge for a while and let it cool down and try again? I tried but to no avail. Would someone answer this? Please :)
Mar 21, 2010 | Jenn-Air Refrigerators
Jenn-air JCD2389DES stopped cooling in both the refrigerator and freezer. I hear a click sound every now and then. It sounds like it is clicking on but then nothing happens. The clicking sound is coming...
Jan 15, 2010 | Jenn-Air Refrigerators
Freezer not working , clicking noise coming from fridge
Clicking was a relay. Replaced relatively inexpensive relay and now working fine.
Jan 17, 2009 | Jenn-Air JCD2389G Side by Side...
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Maytag refrigerator clicking noise and stopped working
How long a period of time have you noticed this noise? If it just started and the refrigerator just stopped it could have entered its defrost cycle. When the defrost heaters come on you may hear the heat causing some expansion. After a few minutes(18-22) the defrost cycle ends and the refrigerator will restart.
May 30, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
Jan 03, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Jenn-Air JCD2389G Side by Side Refrigerator Logo
67 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
