Question about Kitchen Ranges
I am getting an E1 error on my WaterBoss 900 softner
2 Suggested Answers
SOURCE: Waterboss water softner. E1
THis has happened to me a couple of times and i have fixed it by doing the following:
1. slide the electronic display unit off its base
2. spray a bit of WD 40 on the 2 gears right next to each other (they are gold and black on my unit)
3. spray a bit of WD40 on the large grey wheel on the other side of the 2 gears. The 2 gears are supposed to turn the grey wheel, which in turns pushes a little black plunger in with one of its three little prongs. Use a screw driver to make sure that the plunger is moving freely - push it in and out a few times and put a bit of WD40 on it.
The whole error code is about that large grey wheel not moving - it is the "magnetic disc" that the owner's manual refers to.
Finally, reposition the elwectronic display unit - make sure it is tightly secured in its original position, or it will not work.
Unplug the power to the display unit and then re-plug it back in. The unit should go through its cycle on its own then...assuming you don't have any damaged parts. Hope this helps!!!!
Posted on Feb 17, 2009
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Grohe Blue - Error E1
    You have to disconnect the power supply for more than 30 sec
    Nov 03, 2015 | Grohe 31251 Blue Chilled & Sparkling Dual...
    Waterboss 93000 water softener
    It most likely is due to a plugged eductor/injector assembly which pulls the salt brine out of the tank to regenerate softener. If it is plugged no brine will be pulled from salt tank during regen but it will keep filling the salt tank and eventually overflow with each cycle. Or there could be a leak in the valve causing the tank to overflow.
    Here is the owners manual for your model.
    http://www.waterboss.com/media/WB_Softener_V1_Manual.pdf
    See page 23
    RJ
    May 05, 2014 | Water Dispensing & Filtration
    Waterboss 93000
    Chances are if your water boss 93000 overflows after a regeneration cycle, the piston in the brine valve housing is sticking due to corrosion. The replacement part is over $40 so my suggestion is to remove the brine valve housing assembly, clean the end off of the piston are best you can, then lubricate it with lithium grease or spray, push the piston back and forth a few times with a screwdriver, and then reassemble. I would suggest lubricating the piston annually, and all you have to do to do that is remove the control panel temporarily and underneath it you can see the end of the piston that needs to be lubed.
    May 05, 2014 | WaterBoss Water Dispensing & Filtration
    My water softener is inoperative and is displaying ''E1'' in the status window.
    Two possible ways to resolve this:
    1. (the easiest to try first) - Unplug the unit from the electrical supply for 20-30 minutes and then restore power. This may clear the error code.
    2. The error normally means that the motor has encountered some form of resistance - i.e. a blockage of debris in the piston seal inside the valave or possibly it could be due to a microswitch not activating correctly which could cause the piston to stop in an incorrect position. This would normally be a job for the service team; however if you are feeling that you want to tackle this yourself you could refer to the diagram in the user manual to disassemble the unit and investigate further. In all liklihood a clean may well fix the issue
    If this helps, please leave feedback
    Feb 07, 2010 | Culligan Sediment Water Filter
    Error E1 mean?
    An E1 error message usually indicates that the thermistor (see the following link) is defective and needs to be replaced.
    http://www.appliance411.com/data.php?rc=548392
    pls rate my suggestion...
    Jun 26, 2009 | Whirlpool Washing Machines
    Error message E1
    hi there we have an E1 error after 7 seconds of operation??
    Apr 09, 2009 | Exercise & Fitness
    Waterboss water softner. E1 error message with water running right through system.
    Nov 05, 2008 | Bushnell Optics 2x24 262024W Prowler...
    Kebc207 oven error code E1 F2
    This is information from the Tech Sheet.
    Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
    Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
    E1 error code on air conditioner
    I called haier about this error code. E1 indicates that a button on the control panel or the reomote is stuck. I was instructed to unplug the unit and push each button at least 5 times, one at a time. Plug the unit back in, and this fixed my problem with error E1 and the unit works fine.
    Jun 23, 2008 | Haier HWS08XC1 8,000 BTU Window Air...
    Kitchen Ranges Logo
    65 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
