Question about Lands Phones
CHANGE TIME ON OPTICON SWITCHBOARD - Lands Phones
On the IP1NA-12TXH, pressed the call1 button and now the screen says switchboard. how do i go back to the regular name display?
If your phones says "switchboard" that is the name assigned to it. in idle condition you should have a name and an extension number as well as the time and day showing on your Aspire phone.
Oct 02, 2014 | NEC Lands Phones
Error - 8 on Opticon PHL 2700
It happened to me once. I basically reboot the opticon. and upload the data to the opticon again. and problem solved.
Apr 16, 2013 | Opticon PHL 2700
Is there a way to check the configuration of a OPTICON OPI 2201?
usually there are no settings as most computers see the barcode and crdit card scanners as keyboard/input devices. unless the manufacture has additional software and drivers the device is simply an input capture device.
Mar 23, 2011 | Opticon Computers & Internet
Windows 7 cannot detecct my OPN-2001
It seems that this only has drivers for Windows XP, but you can try installing the XP drivers on windows 7.
http://old.opticon.com/uploads/Software/USB%20Drivers%20Installer.exe
Here is the link to download the drivers, make sure the scanner is not plugged in until after the drivers are installed. This may not work, but i have had to do this with other hardware and sometimes it does work.
Feb 28, 2011 | Opticon OPN 2001 Mobile Data Collector...
How to download service manual for lge cdma model
This is the Opticon website:-
http://www.opticonusa.com/solutions/tech-support
The only manual they have is the Universal menu manual.
If you can't find the manual you need here, I suggest you contact their tech support guys and ask them to point you in the right direction.
Apr 13, 2010 | Opticon LGE1105RHHS-000 Handheld
Opticon OPR-3201-USB computer does not recognize scanner.
get your manual and scan in the appropriate "host" option. You will have to scan in the "USB host" barcode. There may be more than one. Your scanner should be set to the HID usb Keyboard option. Or contact the Opticon Help Desk. You can download the manual at http://office.manualsonline.com/manuals/mfg/opticon/opticon_scanner_product_list.html
Oct 30, 2009 | Opticon LGE1105RHHS-000 Handheld
How do you set the time
To change time on the KX-T7630 switchboard (using the TDA 100).
Press Progam or pause
Enter **
Enter your system password.
press cursor down one level - you will then see set date and time.
To exit the programming mode at anytime, lift the handset.
Hope this helps.
CM
May 19, 2009 | Panasonic KX-T7630 Corded Phone
How do you change time and dat on lg lkd-30d phone
Depends on what system you are using. The time is taken from the system, different systems have different programming codes.
Dec 03, 2008 | Lands Phones
How do I reset the time on our Mitel 5220 IP Phone?
What Mitel phone system do you have. 3300ICP you can change it in programming same with a 200ICP.
Dec 01, 2008 | Mitel 5220 IP Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
