Trimble juno sb won't turn on
The unit just turned off and won't turn back on, plugged the charger lead in and the led flashed orange and the unit still wound not turn on
Ol? Estou com um problema meu juno sb esta pedindo para reinstalar o OS??
Como fa?o se n?o tenho acesso ao juno pelo PC
Posted on Feb 14, 2015
I have the same problem with my Trimble Juno SB. It just happened today. But when I plug mine in to a power source the LED is green. But when I hit the power button it flashes red one time. I have tried soft and hard resetting it. And I even tried the 'restore factory settings' reset. Nothing works, It just stays off. The screen never comes on.
Did no one else read the question? It isn't for a laptop. It is for a Trimble Juno SB.
Posted on Jan 16, 2014
  • Ryan N
    Ryan N Jan 16, 2014
leecom72
  • 4806 Answers
SOURCE: Toshiba Satellite C655-S5082. Won't power
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Posted on Jul 16, 2011
  • 219 Answers
SOURCE: Hi my hp 6735s laptop has just started turning
Check the power cord at the connector. Hp has a problem with the cords breaking internally. I had a problem with mine and found that if I played with the cord then it worked for a while. I ended up buying a new power supply.
Posted on May 27, 2010
SamuRaiii
  • 130 Answers
SOURCE: Battery is not charging. When
This is a common problem with Batteries and AC Adapter you need to check, maybe your battery cells are dead or AC failing voltage
Posted on Dec 14, 2010
SOURCE: My laptop won't turn on,
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Posted on Sep 17, 2011
SOURCE: Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Posted on Mar 29, 2012
Orange light trying charge
I would try this:
take the battery out
unplug the charger
turn upside down
hold power button down for 1 min
keep holding power button down as you turn over the laptop
while still holding power button down plug in charger and try to power on
Jan 26, 2014 | HP Computers & Internet
Not charging
The chances are that the battery has failed. The age of the device would indicate that the battery is probably NiCd - these batteries have a memory effect that means after a while the battery thinks that "fully Discharged" would be the state that is the most usual for the charger to be used most often. You will need to open the device to get the battery out to find the part number. You will then be able to order on from an online retailer.
Jul 11, 2013 | Aluratek APMP101F Cinepal HD Media Player...
Sharp Mebius won't boot
I suggest that you remove the battery and use the charger only in turning on your computer. If it turns on just fine without the battery then you would need to replace the battery. If it doesn't then it's either the motherboard or the charger which has a problem.
David
Jun 10, 2013 | Sharp Mebius Computers & Internet
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
Power wont turn on..battery led flash orange
Remove battery. Maybe faulty? Try another cord/charger with the EXACT same specs. Reseat the Memory Mods. has the AC jack been damaged by pulling on the cord? Try plug in and at the laptop's AC jack "wiggle" the AC jack plug. Any change?
Jan 04, 2013 | Toshiba Satellite U305-S2804 Laptop
Mar 29, 2012 | Acer Aspire Computers & Internet
My sb-200 flash won't work with my d200
Go to menu then shooting and turn on ttl
Jan 17, 2012 | Nikon SB-400 Flash
Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Oct 20, 2008 | Compaq MV 540 15" CRT Monitor
Wont power on.
to/ Japiering
all you have to do is re-charger them with the plug.
p.s.the re-charger comes with a set.
from hannah .l
Aug 02, 2008 | Nintendo DS Lite Console
Replaced Bottom screen bypassed fuses still problems
the backlight or fuses are dead. Do not bypass fuses or you'll kill your system.
Jan 23, 2008 | Nintendo DS Lite Console
Computers & Internet Logo
703 people viewed this question
David Payne
David Payne
