Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
Picture and sound problem at 21" sony waga color tv
In my tv set, after running some time, total screen became out of picture but some colors are visible, and after that the tv black out i.e no sound and picture present. At that time the power indicating LED shows red,orange, light green etc. color and after sometime color change off but the power light blip four times after every four seconds. My English is not so good if you need more explanation, please ask me.
  • Anonymous Mar 12, 2014
    I have 4 tv and a amp for all of them and two of the tv i have a in line amp. Sometime i cann't get one or two ch. that I can get on the other two... I change in line amp. out and still doesn't work all the time sometime it works
    New Friend:
  • 76 Answers
This is due to problem in deflection area and power supply section malfunction. Make one general service by technical person immediately to avoid major transformer failure problem. Since this is initial stage, the cost of repair is probably less.
Posted on Aug 28, 2007
    New Friend:
SONE TV WAGA 14INCH KV M142 M70 MODEL NO LED 2 ON OF LED 2 TIME ON OF THEIS WARK
Posted on Oct 04, 2010
SOURCE:
Geek Squad broke my Television
Try these settings:
Picture Mode: Movie
Contrast: 100
Brightness: 44
Sharpness: 20
Color: 50
Tint: 50
Backlight: 7
Color Tone Warm1
Digital NR Auto
Detailed Settings
Black Adjust Low
Dynamic Contrast Low
Gamma -1
Color Space Auto
Edge Enhancement On
xvYCC Off
White Balance
R-Offset 21
G-Offset 20
B-Offset 21
R-Gain 0
G-Gain 21
B-Gain 26
My Color Control
Pink 20
Green 15
Blue 15
White 15
Auto Motion Plus 120hz: Low
Feb 28, 2014 | Samsung UN55C6500VFXZA 55in Led Hdtv 1080p...
My sony flat screen works but when I turned it on the colors are blue and purple. Picture not clear but sound is ok. Colors are off.
Press "Input Select" on the remote control and select "TV Mode."
Press "Menu."
Press "Enter" to select "Picture."Use the arrow buttons to select
"Picture Setting."
Press "Enter."Use the arrow buttons to select "Color."
Press "Enter."
Use the left and right arrow buttons to adjust the color settings. When you are pleased with the color setting, press the "Exit" button on your remote to exit the menu screen.
Hoped this helped
Mar 18, 2011 | Televison & Video
How do i get my tv back to home mode when it is in retail mode
Hello
[1] Press the green color button on your remote control to enter the Settings assistant menu.
[2] Select your Location with the cursor up/down and press the green color button.
If you choose Shop it will skip the Settings assistant. The TV parameters for Picture and Sound will then be set to predefined fixed settings.
Press the green color button again to proceed.
If you choose Home it will display the Settings assistant.
[3] Use the cursor left/right to each time select your preferred screen.
[4] Press the green color button to each time confirm your selection and to jump to the following screen.
The following items will be presented sequentially. In the header it is mentioned how many screens have been completed and how many
screens there are in total. The Settings assistant will step sequentially through the following settings: Picture and Sound.
[5] Press the green color button once to store all the settings and to return to the TV installation menu.
Note: When you skip or stop the Settings Assistant, then the Standard settings
Philips selected for you will be chosen.
[6] Press the red color button to finish the First time installation procedure and to display the first stored TV channel.
OK.
Feb 22, 2011 | Philips 42PFL5332D 42 in. LCD Television
The picture on our Sony TV Model KP-43HT20 recently became distorted, concaving at top and bottom. If I use reset the Flash Focus, the picture will return to full screen side for awhile but the colors do...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergene board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 15, 2011 | Sony KP-43HT20 43" Rear Projection...
My bottom part of tv to the left side became a little wavy and it's showing double and you can see also letteing in red color.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 07, 2009 | Panasonic PT-53TW53 53" Rear Projection...
This is not a simple question to answer without looking at it, my recommendation is to call a service center in your area. That's my professional opinion.
Feb 04, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Colors Faded in my sony KV-HA21M83A 21''
Its magnetic effect on picture tube. Power Off TV for 20-30 minutes then turn it On, hope problem will be resolved. Please also check and remove any speaker or some thing have magnet near by TV.
If color spots are still there, picture tube need to degaussed / demagnetized.
Nov 10, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Hitachi Projection tv
*Screen Looks 3-D
*Colors wont align
Jul 17, 2008 | Hitachi 43F300 43" Rear Projection...
Sony TV KP-46WT500, 46" Rear Projection TV , colors mixed up
You have a pair of Bad STK392-560. replacing these will definitely fix the set.
Best regards
CircuitCity
Dec 19, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony KF-42WE610
Sound but no picture, tv will not turn off. Light goes red but a dim overall blue screen remains and fan is still running.
Nov 15, 2007 | Sony XL-2100U Projector Lamp for...
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
279 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
