Portable air conditioner 14,000 btu ky-36 forest air
LCDI trips after few minutes
SOURCE: portable air conditioner. no users manual
Managed to contact Chinese Firm who will send me Users Manual printed in English
Thankyou for your trouble.
Sincerly J Darren.
Posted on Jun 25, 2009
greenspan
  • 1734 Answers
SOURCE: sunbeam 9000 btu air conditioner
Ask here, they can get virtually every Sunbeam manual
Posted on Jul 28, 2009
  • 5 Answers
SOURCE: i have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
Posted on Aug 03, 2009
cshubart
  • 146 Answers
SOURCE: Need a new window kit adaptor for 9000ah
you should be able to find that through a heating and air condition company they should with all the model and searial numbers be able to order it for you
Posted on Aug 23, 2009
  • 9 Answers
SOURCE: Sharp 10000 BTU 38db portable air conditioner
sounds like the unit has a low charge and is cutting out on a low press safety. This is more then likey not something you can fit yourself most of this units are not really serviceable with out cutting the lines open and adding a valve. If the unit is still somewhat new you can try for a warranty repair, if not you are better off to replace it.
Posted on Aug 30, 2009
Air conditioning air is not cold enough
Add a pressure tap if there is no access to the refrigerant loop & check pressures... sounds like it is a little low on refrigerant.
Jun 20, 2016 | American Exchange Comfort 14,000 BTU...
How do I recharge unit
call a service repairman probably needs the recharge fitting added as they do not come from factory with them on
Jul 20, 2015 | Amana 14,000 BTU Portable Air Conditioner...
Excess water prodution in portable 14000 BTU unit. See below
all a/c units remove moisture from air with cooling coil being cold and room air blowing across coil - depends how humid it is - i have used several different portable units and this seems to be a common problem if it is humid
Jul 03, 2014 | Commercial-Cool 8,000 BTU Portable Air...
My braker keeps tripping with only the tv on and electronics that barely use a lot of juice. it doesn't seem like it pumping out enough cool air for 14,000 btu's either
14,000 btu is a very large unit it should be on a dedicated cuircut of either 15 or 20 amps all by itself.check the rating plate for correct amperage
Jul 21, 2011 | Soleus LX-140 Portable Air Conditioner
Compressor comes on for about a minute then kicks off. Wait a few minutes kicks on for a minutes then kicks off.
If the fan is running pull it out of the case and clean the outdoor coil use a soap like 409 let it soak then hose it off, use a much water force as not to damage the fins, keep the water a way from everthing else and you should be cooling again. The outdoor coils get very dirty and then the water off the evap. drains there and then the fan throws in into the coil and makes a mud, no heat rejection.
Jun 30, 2011 | Goldstar LG LW1400ER 14,000 BTU Window Air...
I have an amana portable electronic air conditioner wont turn on
Jun 30, 2009 | Amana Portable Air Conditioner
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
