Question about Pool & Spa
Aquadyne pool controls
Where can I get wiring schematic of a Aquadyne timer panal?
2 Suggested Answers
  • 45573 Answers
SOURCE: I need aquadyne replacement stems 20 year old three handle valve
you probably will not get the stem but it is possible to get a new insert which is the unit that the stem is in
go to a plumber supplies shop ( where the plumbers shop) and ask for a replacement insert for that tap
Posted on Oct 25, 2016
Oct 25, 2016 | Plumbing
Intermittent Intermatic Pool Timer T40003RT3 The pool timer is 220v but only one 110v 20amp breaker in the breaker box to the pool equipment and when it is off the pump will not run in manual mode.
http://waterheatertimer.org/How-to-wire-Intermatic-control-centers.html
http://waterheatertimer.org/Intermatic-control-centers-and-manuals.html#RT3
RT3 series has T104 240 volt timer -or- T103 120 volt timer, -plus- low voltage transformer for pool light.
The circuit breaker can be used for transformer, or another outlet or nearby light etc, or it can be used for a T103 120 volt timer.
To trace the wire back to breaker box.... open you main panel and start turning off breakers one at a time and label the panel.
See if you have single breaker or double breaker supplying power to pool equipment.
Gene
Water Heater Timers Save Money
Jun 10, 2015 | Intermatic Timer T40004RT3 300 Watt Pool...
Value position to heat pool
turn the valves so ALL the water goes through the heater and back to the pool
Apr 17, 2014 | Hayward Pool Products Pool & Spa
You can as long as you don't exceed the power specs for the controller.
Aug 04, 2013 | Hayward Pool Products Pool & Spa
I dont know how to set the timer
Question posted under Intermatic T104 series timer and pool control center.
Open following link to see how to set this timer:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Intermatic T12404R control center has 2 timers.
Each timer is set same way.
Timer must be reset after power outage. If time dial is not rotating correctly or is sticking at the tripper, then the WG1573 clock motor can be replaced by homeowner.
Both timers are 240Volts, and can be wired in variety of ways to control different voltages. For example 120Volt pool lights, and 240Volt pool pump and pool heater etc.
Each timer snaps out of control center using thumb spring located top inside box.
Each timer mechanism is sold separately. One timer is T104M. The other is T104M201.
The difference is that the 201 has a 'fireman's switch' that can be wired to pool heater, and the switch turns off heater 15-20 minutes before turning off pump.
Each timing mechanism can be repaired by homeowner using available clock motors and trippers.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 11, 2011 | Intermatic Timer T12404R Pool & Spa...
Can you send a scematic showing how to wire an intermatic pool pump timer to a polaris intermatic timer so that when the pool pump shuts off so will the polaris pump yet the polaris timer clock continues...
No. I don't have a wiring schematic without knowing what voltage you are using, specifically what Intermatic timer you have, specifically what wires you have coming from breaker box, what wires are on the pump, and what pump rating plate says, what the wiring diagram shows on side of pump, whether you are wiring a 2-speed pump to a single-speed timer, specifically what is the polaris timer clock, and why this pump needs two timers if that's what you mean.
Add a comment with specific information so electrician is not guessing.
http://www.poolcenter.com/polaris-booster-install-OM.pdf
Open following link for 240Volt T104 timer wiring diagram.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Aug 25, 2011 | Intermatic T104 24h 208-277v Mechanical...
My timer for my water feature looks like your Intermatic T101R3 timer. I do not have an instruction manual. Can you e-mail me some simple instructions for using this so I won't get charged an...
T101R3 is outdoor pool timer with fireman's switch.
Some are double-pole, some are single pole, some are 240V and others are 120V.
They each look like the other so eyeball identification is not enough information.
The model number should be inside door of timer.
http://www.poolandspacontrols.com/products/mechanical%20time%20switches/pool%20and%20spa%20time%20switches.aspx
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
I have been unable to locate manual specific for these products, and I have looked.
I was looking yesterday for this instruction manual.
Some wiring diagrams appear on following page, but again it depends on your specific model
The T101R series is designed to control pool pump and pool heater.
Fireman's switch automatically turns off pool heater 20 minutes before pool pump is scheduled to turn off.
So you set the trippers on dial, and then the fireman's switch does the rest automatically.
Add a comment with in-focus photo of inside of timer door and I can put together all the information and simplify instructions. Put your digital camera in 'macro' with the flower-symbol to take close-up photos. Photo has to be in focus so I can read information and see wiring schematic.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Apr 20, 2011 | Hardware & Accessories
Installing a outdoor timer t104m this is for the pool cleaner,need wireing instruction.next to pool pump timer.
Open following link for wiring diagrams and manual.
240Volt T104 can be wired many different ways.
What is the significance of 'next to the pool pump timer?'
Are you getting power off the 240V pool pump timer to operate the new T104? This is perfectly fine. The pool pump wires would bring power from the breaker box.
Is the new T104 going to control 120Volt lights? The timer can do that, it just has to be wired correctly.
In any case, the T104 has 240Volt (or 277V) clock motor, and clock will not operate with 120V
If you add specific details, I can help with exact wiring diagram for your project.
Apr 18, 2011 | Intermatic Hardware & Accessories
I am replastering my spa and want to put a new LED light in. Can I control the different light functions with th Aqualink and the button on the spa deck?
I have a Aqualink RS one touch control system, model 8157 RS6 Combo. The backlight in the control panal is out, the panal works fine, but does not light up, so it is hard to read. How can I replace the light? Do I have to replace the whole panal unit? Is there a bulb to replace? thanks, David
Feb 23, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
NOT WORKING AT ALL
whirl pool dryer's have a one time saftey thermo in them . when they fail they wll not start untill what caused the problem if corrected . (a ) maybe the vent needs to be cleaned . (B) dyrer is packed with lint . and must be cleaned out yearly to prevent lint fires . C if the vent tube on back is flex it may have kinked . after you find the problem replace the saftey thermo . mm
Nov 22, 2009 | Whirlpool LER5636P Electric Dryer
Pool & Spa Logo
199 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
