Question about National Little Tikes Talking Train With Track
Gear our train will only drive in reverse and the noise makers on the steering wheel will not work. What could be our problem?
We have the same exact problem with ours, I went online looking for help, and came across this post so apparently it is a common problem. We haven't fixed it yet have you had any luck?
Posted on Aug 24, 2013
Heard a clunk while driving diesel ford excursion now when drive and reverse don't work....any ideas what problem is?
If it is a four wheel drive check your tail shaft or drive line by securing the vehicles front wheels jack up the rear tires and in park try to rotate the drive line if you can hear the transmission sound like it is going into gear the transfer case could be damaged! If not a four wheel drive pull the transmission dipstick and look to see if the fluid is dark red or metallic grayish color if so then you're clutch disks inside the tyranny have been worn out and it needs to be rebuilt!
Oct 05, 2014 | Cars & Trucks
Grinding sound from rear while driving
Run vehicle while on hoist/Listen w/Stethoscope.....Sometimes the 'sound' travels throughout the drive train components & can be tough to pinpoint...Time for a pro !!
If you need further help, reach me via phone at https://www.6ya.com/expert/ralph_2f0886b7d6af32ce
Mar 25, 2014 | 2003 GMC Sierra
Knocking noise when reversing
check your lug nuts. also check the axle shaft joints.
Jan 02, 2012 | Nissan N Z 38 POWER CAT Cars & Trucks
I got a few questions i got a 1992 gmc serria sle model with a 5.7 th700r4 tranny and is 4 wheel drive the first question i have is if u go to put in in reverse with it in 4lo and turn the steering wheel...
Trnasmission going out, Did you know that reverse is the same as second gear. Does it slip in second gear are should I say have a hard upshift like around 20mph. Got a friend have them drive it in reverse and see how fast the drive shaft is turning also do you hear a whinning noise.
Apr 21, 2011 | 1992 GMC Sierra C3500
2006 2 wd grand vitara. I went to the store and when i came out i tried to reverse my suv but the steering wheel hardly turns and the suv makes a screeching noise. The wheels refuse to turn. I can drive...
the belt will make a screeching noise for the power steering if it is loose or worn out. check out the belt, or the power steering pump front bearings failed and will not let steering pump to spin. have a good day !!
Nov 15, 2010 | 2004 Suzuki Verona
The wheels on my son's train only makes clicking noises
wheels are stuck and the gear drive is jumping over the gears
Feb 09, 2018 | Toys
Torque coverter, Transmission question
No.It does not effect anything,the vehicle is designed to function under these circumstances,the noise is normal in the brakes.
Mar 05, 2010 | 2008 Ford Fusion
Front drive noise when turning left/right
the C V JOINTS have hadit.that is the constant velocity jointsare badly worn and need replacing youdoit
Jul 27, 2009 | Hyundai Excel Cars & Trucks
Telescopic Steering wheel won't move down - I hear a gear spinning
Open the gear motor on the left hand side of the telelscopic assembly. Take the plate off held by 4 philips screws. Using a 10mm socket, remove the bolt holding the platic gear. Remove plastic gear and insert the reverse way. Over the years, one side of the gears get worn out.
Oct 27, 2008 | 1997 Lexus LS 400
National Little Tikes Talking Train With Track Logo
Top National Toys Experts
Joseph Hoffmann
Adam Fjeld
Adam Fjeld
Vernon Taylor
Are you a National Toy Expert? Answer questions, earn points and help others
