The display keeps going off on my asus laptop about every 2 minutes or less, even when all my settings are set for never go off.
    New Friend:
    Problem Solver:
  • 12 Answers
To isolate your laptop problem, first thing you should do is use an external monitor to check if the video chip is OK. You need to press Fn + F4 or F5, F6 depends on your laptop model to activate the display on your external monitor. If your laptop works fine with the external monitor, then your laptop LCD or the inverter(small board that controls the voltage that is sent to the LCDs backlight) went bad.
Inverters is the problem that is easy to fix, you just have to get the correct inverter for your laptop model and your problem is fixed. One way to test inverter is to check it with voltage meter if it is giving the correct voltage.
To check your LCD, use a flashlight. Shine it to your LCD, if you see a faint image then in most cases it is the backlight that needs to be replaced. If you don't see an image even when shining the flashlight then it is most likely the inverter and it should be an easy fix.
Posted on Jul 18, 2013
Lenovo yoga pro 2 keeps going to sleep without prompting.
Check the laptop battery settings. Right click on the battery icon and check the settings.
Nov 11, 2015 | Lenovo Computers & Internet
My screen keeps going black, how do I correct it?
I'm guessing your power options are set very low. One minute is the least you can set, but it may seem less. Try going to Control panel, Power Options and click on "Change when the computer sleeps" and select a time of several minutes for "Turn Off The Display" and see if that helps.
Good luck.
Feb 25, 2015 | Lenovo Computers & Internet
How do i stop military time on my asus pc? or change it
You need to go into your control panel, find the regional settings. There you can set the correct time zone, display of numbers and degrees.
The way in there varies from windows to windows, but usually you can do a run/search in the start menu and it will pop up (searching for the control panel).
You need to be administrator for the changes to be permanent.
Feb 21, 2015 | ASUS Computers & Internet
Touchscreen does not display
YOU DROPPED IT, THAT EITHER BROKE THE MONITOR OR THE CONECTION TO THE MONITOR BUT YOU SAY THAT WHEN YOU HOOK UP TO A MONITOR IT WORKS OK.YOU CAN FIX THE PROBLEM YOU GO TO E-BAY AND TYPE THE NAME AND MODLE NUMBER ONCE YOU ARE IN E-BAY LOOK FOR THE ASUS Q200E AND YOU ARE LOOKING TO BUY ONE FOR PARTS WITH A GOOD SCREEN...[REMINDER IT WOULD HELP IF YOU GET A PAY-PAL ACCOUNT.AND MAKE SURE YOU HAVE A MINI SET OF PHILIP SCREW DRIVER AND A MAGNET TO KEEP SCREW TOGETHER.
AND PAY CLOSE ATTENTION WHEN DOING THE REPAIR
PLUS YOU'LL HAVE EXTRA PARTS.
GOOD LUCK.
Feb 08, 2018 | ASUS Q200E 11.6" Touch- Laptop Computer
My asus laptop screen is divided into diffrent desktop
Right click on the main screen, go to properties, go to display options, change the display settings so number 1 box is bigger and to the left of number 2 box, all other settings should be set to default.
Jun 09, 2012 | ASUS Computers & Internet
ASUS monitor is plugged into MacBook Pro. Has worked fine over the last 12 months with both screens working independently. Recently unplugged for 2 months. Plugged ASUS back in. After approx.5 minutes, the...
(1) If you have connected windows cpu to monitor then when you power up the computer press F8 key then enter in enable vga mode then go to control panel ->display property -=>settings change screen resolution to 1024*768.
then check .
(2)But if you are not able to see any display on screen then open cpu cabinet and refix ram memory pull cmos cell from motherboard for 10 minutes ,if there is any pci card or vga card installed on motherboard reattach it into motherboard.Then check.
If you have mac book then follow my second solution.
Let me know if you need further assistance.
Thanks for using Fixya.
Apr 07, 2010 | Computers & Internet
Amana model LGA30AW automatic setting doesn't shut the dryer off
You can make adjustments to your Automatic Cycles by adjusting the Factory Dryness Level:
Changing the Automatic Cycle settings to increase or decrease drying time:
If all your loads on all Automatic Cycles are consistently less dry or more dry than you would like, you may change the default settings to increase or decrease the default dryness
level.
Your automatic drying settings can be adjusted to adapt to different installations, environmental conditions, or personal preference. This change is retained and will affect all of your
Automatic Cycles, not just the current cycle/load. There are 5 drying settings, which are displayed using the time display:
0 Much wetter clothes, 30% less drying time.
1 Slightly wetter clothes, 15% less drying time.
2 Factory preset dryness level.
3 Slightly drier clothes, 15% more drying time.
4 Much drier clothes, 30% more drying time.
TO CHANGE THE DRYING SETTINGS: NOTE: The settings cannot be changed while the dryer is running or paused. The dryer must be in standby mode (power is off) to adjust the default settings.
  1. Before starting a cycle, touch and hold DRYNESS for 6 seconds.
  2. Touch DRYNESS to select the dryness level shown in the time display: 0, 1, 2, 3, or 4.
  3. Touch START/PAUSE to save the new dryness level setting.
Oct 05, 2017 | Amana ALG331RAW Gas Dryer
Asus computer password reset.
To unlock a forgotten Windows password on Asus, there are several free methods:
1. With another admin account.
2. With Windows password reset disk.
3. From Safe Mode.
4. With CMD.
5. Using "lusrmgr.msc"
More details you can found on other sites, it is easy to find.
Another tip: Unlock forgotten Windows password with Windows Password Recovery Tool.
1. Install this program on another computer and create a password recovery disk with USB
2. Insert the disk to your laptop and set your laptop to boot from it.
3. All user accounts will be loaded, then you can reset any user password.
Apr 02, 2009 | ASUS Eee PC 900 PC Notebook
Invalid format when conected to laptop
Go into your control panel. Select display. There will be a picture showing 2 screens. Select the 2nd screen, and lower resolution to it's minimum. Apply and test. Slowly increase till you find what your happiest with. Worked for me using a ASUS laptop and LG60'plasma.
Jun 29, 2008 | LG 42LC2D 42 in. LCD HDTV
Back Light
Go to your control panel then click on the POWER icon, Change your settings in the general tab... set to always on in battery mode/..
Jun 05, 2008 | ASUS L3 L3562 Notebook
Computers & Internet Logo
David Payne
David Payne
