Question about Car Audio & Video
Pioneer gm 900 manual - Car Audio & Video
Diagram for pioneer gm-34a
Here is the manual for the GM-3400. 34 "A" does not exist. Here you are:
http://retro-caraudio.servehttp.com/guide2/images/Brukermanualer/Bilstereo/Pioneer/Amps/GM3400.pdf
Jul 13, 2014 | Pioneer Car Audio & Video
Alpine 6x9 speakers 90 watt rms.Are they compatable with a pioneer gm 3000 amp
the alpines will take every drop of power from that pioneer and smile... it will sound quite good,and if you ever want to you can actually put about 2x that much power to them 1 of those amps per 6x9 would rock
Apr 08, 2013 | Pioneer GM-3000T Car Audio Amplifier
I have a Pioneer GM-X862 when i have it
make sure you do not have the ground and power crossed or touching if that dont work then you have ground problems hope that helps if not your amp is at fault(replace it)
Nov 03, 2009 | Pioneer GM-X862 Car Audio Amplifier
I have a pioneer gm 800 amp. was wondering if you had the color code for the harness
Red is B+, Blue is remote turn on, Black is Ground, Speaker wires green, Brown , Gray and white. Strip notes polarity. You can download the owners manual from Pioneer web site.
Oct 30, 2009 | Car Audio & Video
Pioneer GM-7300M 800 Watt amp will not power on
This may have a different type of triggered turn on wire. On some of the older Pioneer amps (and maybe some new ones) the trigger wire would SUPPLY B+ TO THE RADIO and when the radio was switched on the amp would sense a current draw on that wire and would then switch on. Unlike most common amps which sense the presence of B+ on the trigger wire supplied by the radio and then turn on. Look in your owners manual to see kind of turn on system you have. If you don't have an owners manual then perhaps you can download one from Pioneer support. good luck
Aug 23, 2007 | Pioneer GM-7200M Car Audio Amplifier
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
