Question about Garden
My riding lawn mower slips in and out of gear while going forward
Why is my lawn mower slipping in and out of gear while I'm going forward? What do I need to adjust? Thanks!
  • John Stahler Jul 18, 2013
    It's a 2010 Troy Bilt Riding Mower, 17.5 hp with a 42" cut.
    Problem Solver:
  • 17 Answers
Sounds like your transmission is shot if its a geared mower. If its a belt driven hydrostatic mower the belt is slipping and needs to be replaced.
Posted on Jul 20, 2013
Yardman riding mower no reverse forward jerking motion
It sounds like you either have a lose belt that is slipping or the fluid in the transaxle is low, or the transaxle is going bad, if it is a hydrostatic transaxle, drain and replace the fluid first, if that fails, you may have a bad seal in the pump or a worn gear
Oct 16, 2013 | Yard Man Garden
Mower slips in and out of forward gear but rides perfect in reverse;What do I need to adjust?
Reverse is a different gear set than forward gears. Sounds like forward gear set has a broken tooth. Not an easy fix.
Jul 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Weedeater we261 riding lawn mower
Check your drive belt on the bottom of the engine.. that is what drives the machine forward.. if it has slipped off or broken, it will not go.
Apr 27, 2013 | Weed Eater WE-ONE 26-Inch 190cc Briggs &...
Drive belt slips on Husqvarna YTH21K46 riding lawnmower, installed new drive belt and it slips. mower is 2 years old
I had this same issue. New belts and correct routing did not solve the problem. The issue with my mower was the tabs that come off the frame that you bolt the transaxle (the drive for the rear wheels and axle) had almost completely torn/cracked away. This allowed the transaxle to tilt forward under a load and slip the belt off the rear drive pulley. You see no mention of this at the dealer or company sights. The tabs are so thin this is going to happen, in my opinion, in time. I reinforced this area with 1/4 inch angle iron and have had no further belt issue.
Apr 21, 2012 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
After I apply the brake going downhill, etc., the mower jerks severely and repetitively in forward gear like the transaxle is slipping and catching. Any ideas why?
I believe when you push in the brake you remove tension from the drive belt and engine. Their is a spring that pushes back on the brake pulley and your peddle. check this for wear
Feb 23, 2011 | Yard Man Yardman Riding Lawn Mower 38in...
Nylon gear is worn, slipping under the slightest stress! Need replacement parts.
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Aug 21, 2010 | John Deere Gilmour Traveling Sprinkler -...
All gears appear to be good ,but tractor just slips and doesn't move
heatman101
Aug 05, 2010 | Nelson Sprinkler: Traveling Tractor
Older model Ariens ride around lawn mower - drive belt slips off
it could be the belt has streched
check tensioner if has one and check all nuts and bolts tight
Jun 21, 2009 | Ariens 34 In. Zoom Series Riding Mower
Will not move runs great mower blades ingage but does not respond to forward or reverse.
the belt running to the back tires has either slipped off r broken off. to get to it you simply go to the back and remove the plate in between rear wheels.
Jun 14, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
141 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
