LG lmu186hv mini split ac
This unit stopped working. I have replace the PCB and the transformer/ reactor. I get a code on the outside unit PCB of the green led stays on and the red one blinks 2 very fast. I have checked the inverter windings at 3 for all 3 wires and the ground shows good. what could it be? I get 3 clicking sounds and nothing else.
    Champion:
  • 247 Answers
Problem with the power supply board the vvoltages are not as per the factory values check the power regulator ic and ensure all voltages and gains are ok get a schematic diagram and check that all votages are the way they are on the diagram
Posted on Jul 18, 2013
ctf1800
  • 4402 Answers
SOURCE: Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Posted on Feb 26, 2008
SOURCE: jvc tv
when both the blue light and red light are blinking it means 1 of 3 things. 1. lamp replacement. This often works everytime for the repair. TIP!!! DO NOT USE ANY OTHER LAMPS OTHER THAN JVC AUTHENTIC LAMPS. ANY OTHERS AND YOU RISK DAMAGING YOUR TV FURTHER. 2. the fans are not working properly or need to be replaced. They need to be cleaned every so often and they will stop working from burn-out if not done so. This repair will cost you less than 100 dollars. 3. The ballasts are defective and need to be replaced. The ballasts themselves run about 150 dollars. I tell you I have fixed this TV more times than I care to count, not to mention the number of lamps I have gone through. The guy at the TV repair place now knows me by name when i come to buy lamps. :(
Posted on Dec 07, 2008
welcomejee
  • 10594 Answers
SOURCE: TV powers off after 10 seconds of powering on....
Thats great, Please rate solution.
Posted on May 19, 2009
rulds2008
  • 3866 Answers
SOURCE: I have a JVC HD52z575 that when I turn it on the
Power supply would be the issue the fix would be my good friends @ www.teexp.com I hope this helps.
Posted on Jun 13, 2009
tvtek
  • 1284 Answers
SOURCE: kdf-50a11e blink 3 time on red
Three flashes indicates either the lamp is not seated correctly or the lamp door is not on properly. I bet its the later of the 2 as THE most common issue is the lamp door has warped because of excess heat building up in the lamp cage. If this is the case follow the link I am providing as you are in luck as Sony is paying for those repairs. Please take a moment to rate my answer...Thanks
http://esupport.sony.com/US/perl/news-item.pl?&news_id=261&mdl=KDF50WE655
Posted on May 19, 2010
Testimonial: "thanks for your help now i have another code erreur 2 blink on red can you telme about this ereur thx ery mutch"
LG Inverter V model LMN096HVT air conditioner multi unit has error code 9. How can I fix this myself?
  1. How to fix lg with code CH05 - Fixya
    www.fixya.com/support/t12722126-fix_lg_code_ch05May 8, 2012 - Question about LG Air Conditioners. 2 Answers ... Hi, i've just moved into a house with a LG ART COOL C24AWR N80 inverter unit in it. Have just .... LG Inverter V model LMN096HVT air conditioner multi unit has error code 9.
Jul 12, 2015 | LG LMN096HVT WaMounted Mini Split Indoor...
My LG split Ac is running some times but some times not working and showing error code CH09
Split = Outdoor unit fan problem. Check Outdoor fan motor is plugged in, Electrically & Mechanically sound, if not replace motor, otherwise replace PCB.
Multi V= Indoor unit EEPROM error - Replace the indoor unit PCB, and then make sure to do Auto addressing and input the address of central control.
Jun 06, 2015 | LG Heating & Cooling
I have a Klimaire 16 Seer Dual Zone Mini Split Heat Pump AC and the outside unit fan/fan motor have stopped working where can I replace this at? I live near Dallas Tx surely there is something nearby?
You should check the fuses and breakers it might not be something that expensive, it could also be the controller for the outside unit that is bad. Google kllimare dealers and your zipcode.
Sep 02, 2013 | 18,000 BTU KSIM DUCTLESS MINI SPLIT...
I got a C9 error on a C12AWR artcool split ac which doesn't work anymore i replaced the mainboard of the outdoor unit which didn't help i replaced the fan motor which didn't help either does...
Split = Outdoor unit fan problem. Check Outdoor fan motor is plugged in, Electrically & Mechanically sound, if not replace motor, otherwise replace PCB. Multi V
= indoor PCB failure. Replace PCB.
Let me informed again if problem persists,.
Oct 25, 2011 | LG LA185HV Split System Air Conditioner
After lightning MW12C1E replaced burned fuse on power circuit unit satrt then flashing green LED then stop how to read error code ?
If you had a major surge then chances are the entire outdoor PCB and possibly the inverter transformer need to be replaced. I'm not as familiar with the Friedrichs but most mini-splits use flash code errors on both the outdoor and indoor units, occasionally with the common codes printed on one of the outdoor service panels, usually only in the service manual (supplied to authorized dealers and sometimes available from manufacturers websites).
Sep 22, 2011 | Friedrich Heating & Cooling
Out door is not working
Check for communication from indoor to out door.Check power in out door unit. If not, check the following.
Keep cool mode and temp setting minimum 3 degree less than room temp.
Check indoor unit return air sensor. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace air sensor
Check Indoor Pipe Sensor Disconnect from PCB and measure resistance. Pipe sensor = 5kOhm at 25C. If not replace pipe sensor.
Thanks and hope helpful?
Feb 04, 2011 | LG LS-L1210CL Mini Split Air Conditioner
There is nothing on the display,conditioner is death.The power is coming,fuse on the PCB is OK?
Check power to transformer (220volts---24/12volts Dc) which leads to function PCB. If 24 or 12 dc is o.k, then you have replace PCB only.If no output of DC, replace transformer. Thanks.
Jan 29, 2011 | LG LS-K1830HL Heat Cool Mini Split Air...
LG air conditioner 24awn error code message Ch 6 inside fan runs outside unit not working
CH-06 REFERS Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor. THANKS.
Dec 13, 2010 | LG Art Cool LA121HNP Split System Air...
My LG LAN125 mini split heat pump occasionally shuts down in cooling mode while displaying the code CA. The LG tech tells me there is no such code. When this happens, I have to cycle power off and back on...
Wash out your outside coil and monitor the outside fan. sounds like a lockout due to dirty condenser or intermittent motor operation. Could mean condencer air problem.
Jun 28, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Televison & Video Logo
Top Televison & Video Experts
