Question about Cell Phones
I recently purchased a power pod 360 vibration speaker, when tryng to play music from my sd card it will not play.
Powerpod 360 will not play music when have the micro sd card in. I have right clicked on the sd in my computer and formatted to fat and then downloaded the music to it. I can play the music on my tablet from the card however not from the speaker. Please help.
ipodfreek
  • 64 Answers
SOURCE: Transfer music from computer to phone
When you put the SD card into your laptop, it should show-up as a hard drive (one of your drive letters on a Windows machine).
Copy or drag your music files from your computer's hard drive to the "music" folder (it might be named "audio", I can't recall) on the SD card. This folder should be there if the card was previously in your phone. Once the files are copied there, they should play on the phone.
If you still have problems, try reducing the bit rate on the music files. I'm not sure how high of a bit rate this phone can handle.
So, for example, if your music is encoded at 256kbps, try reducing them down to 192kbps. I'm not 100% on this, but it's worth trying.
Good Luck!
Posted on Feb 01, 2008
SOURCE: memory card micro sd cannot format
i found something to fix it. or at least it worked for me
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
Install that, then run the program and CAREFULLY select your card from the formatting list
then do a low level format
Then format it on windows or phone or whatever
PLEASE BE CAREFULL NOT TO SELECT YOUR HARD DISK IN THE PROGRAM. IT WILL VAPORIZE ALL YOUR DADA
Posted on Nov 03, 2008
  • 365 Answers
SOURCE: Put music on micro sd card for boulder
your phone may not support the uploaded format.try to convert it ot the supported format and upload
Posted on Dec 02, 2008
marked
  • 6487 Answers
SOURCE: need to format micro sd card
It will be better if you use a card reader and put the SD card on it and format it using your computer so you can set it to FAT and that should do it....
Posted on Dec 28, 2008
SOURCE: microSD does not contain supported music files
1. Install the sd into the phone.
2. Go to Menu > Settings > USB > Mass Storage
3. Connect the MotoVE240 to your PC via USB
4. Under My Computer open drive (E:).
5. Find the folder that has your music in it. Example: My compter made a folder called Music.
6. Drag music from that folder to the my_music folder. (the phone will only read music that is in this folder.)
7. remove your phone from the usb
8. press the music note on your phone and enjoy your music
Posted on Aug 08, 2009
The charging port hole was loose when purchased will not charge.
The product can be replaced by the manufacturer by going to the Mighty Dwarf website. If you purchased an authentic product from an authorized retailer then you are going to be well taken care of.
The best thing to do is open a support ticket on the Mighty Dwarf website and begin the process.
There is no user serviceable parts in the speaker. Opening the speaker will void the manufacturer warranty.
Jan 17, 2013 | Mighty Dwarf Black Authentic Vibration...
Dwarf 360 omni directional sound manual
how do i get the music to play do i have to download anything to the speaker there is music on the sd card but wont play
Aug 30, 2012 | Mighty Dwarf Black Authentic Vibration...
I tried hooking up a laptop to powerpod mixer it shows music is playing but nothing comes out of the speakers
Which inputs are you using? If you are using the 2T RTN, you will need to engage the 2T RTN button under CONTROL ROOM SOURCE and engage ASSIGN TO MAIN.
Sep 27, 2011 | Phonic Powerpod 820 / S712 PA Package
When i put music on the sim card and then put the sim card in my phone it say there was a problem cannot play and for file size it says 0 when there are songs on the sim card
To my knowledge, music and other media must be stored on an SD card. SIM cards are used to store contacts and connect your mobile device to the mobile network of your carrier. I would check your phone's manual (if you still have it) and see what it says about storing and playing music. SD cards are quite cheap. I recently purchased an 8 GB card for $25.
Feb 23, 2011 | LG RUMOR Cellular Phone
What is the ideal speaker specification to match the 8 channel Phonic Powerpod 820. is it possible to play live gig using this set up ? what is the maximum possible set-up ?
to get the best from this mixer output wise, you need to use 4ohm speakers rated at 150watts each. The 200 wat rating is at 4ohms. You can use 8 ohm speakers, but they recomend speakers at 70watts.
Gig wise, you could do a small location that will cater for about 40 people, but that would be pushing your system to the max.
Maximum possible set up? well there is a way to work most scenarios you are given, but it is not best practice.
Ideally, you know what instruments and vocals you want to go through the system, a rough idea of the size of venues you wil play and then ask questions on a system to suit.
Jan 12, 2011 | Phonic Powerpod 820 / S712 PA Package
Hi. I have power and my i pod charges, but no sound is transmitted even though the i pod indicates it is playing whilst connected to the Zeppelin. Any ideas.
could be the arm, or the interface from the arm to the pcb. if you can play via the aux input it is the arm, if that fails then it is one of the boards inside, contact place of purchase or b and w service.
Jan 02, 2011 | B&W Bowers and Wilkins Zeppelin iPod Music...
I pod nano
My ipod nano won't play music just through my headphones- it also plays through speaker and it makes the music sound like you are in a tunnel. How do I turn off the external speaker?
Jun 16, 2008 | Audio Players & Recorders
Cell Phones Logo
1,103 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
