My ge spacemaker portable washer will not spin out
My ge spacemaker portable washer will not spin out on either cycle. Completes all other cycles just fine, makes a clicking noise while agitating, and it is not a balance problem. I went to slightly move it while on spine cycle and it jolted pretty hard, has not worked right since it gives me an error code u6 and clothes are soaked, just need help figuring what it might be and how to fix!!!!
2 Suggested Answers
SOURCE: Washer not spinning right and not completing a cycle
Sounds like you need to replace the carbon brushes on your washing machine motor
Posted on Mar 16, 2007
Could this be a bearing issue, or more of a clutch issue?
definitely not a clutch issue because a bad clutch or issue with it will not allow it to go into full spin!!!
May 25, 2014 | GE Spacemaker Washer and Dryer Electric...
Know when clutch going bad
Needs agitator dogs in agitator.
Mar 13, 2014 | Whirlpool Washing Machines
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Chugging like noise during certain cycles
your clutch need to be replaced as does the tub shaft bearings i;m sorry this is not a do-it-yourself job, try to make a deal to trade in your washer
Apr 22, 2009 | GE Washing Machines
Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Feb 13, 2009 | GE Spacemaker Washer and Dryer Electric...
GE Washer Knocking During Spin Cycle
remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
Feb 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Or, you have coins in your pump casing. Look on the back of the washer, and unscrew the circular port in the bottom right corner. (Keep an 8x13 baking pan underneath, water will escape once you open the chamber). Remove and change/objects from the chamber and replace the port. You should be good to go. This is actually very common for this model washer.
May 17, 2008 | GE Spacemaker WSLP1100D Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
