Question about Dometic Rooftop RV Air Conditioner
Coleman ac manuals 7333c886 - Dometic Rooftop RV Air Conditioner
What refrigerant is in a Coleman 7300 Series AC Unit, on a 1995 Wilderness Camper?
This unit uses R-22. Here is a link to the service manual:
www.bryantrv.com/docs2/docs/rvp/rvp6789mech.pdf
Jul 17, 2015 | Coleman Heating & Cooling
No fan when ac kicks on Ihave a eb15b funace with a coleman ac
The heat will normally use a low speed on the fan, & the AC along with the fan switch on the thermostat will use the high speed. The thermostat turns that high speed on when there is a call for cooling & is the same switch if you were to manually turn the fan from auto to on. Try turning the fan on @ the thermostat. If it works, then replace your thermostat. If it doesn't, it could be a bad fan speed, a bad fan relay on a control board or external relay, or a loose or broken green thermostat wire.
Apr 14, 2014 | Coleman Home Electric Furnace Eb15b/Eb15d
I have a 2000 36' Winnebago Adventure that got a power surge and burnt out the circuit board and capacitor in the coleman Central Mach ac and Furnace can someone send me in the right direction for
Check here and find your service manual as well as parts. If not 100% sure on what you need, call, or e-mail them, or get back to me with more info on who diagnosed problem, and more on symptoms you are experiencing.
http://www.rvcomfort.com/rvp/tech_info/manuals.php
Sep 13, 2012 | Coleman Heating & Cooling
I have a roof top ac unit Model #7333C886 and someone is telling me that it cannot be recharged. Is this true cause it seems to be working fine other than not getting real cold. It is an older model I know...
It is a closed system, which normally they don't require recharge. It can be done but it is more or equal expense as buying a new unit. A lot of times a real good cleaning by someone who knows how to do it properly is all that is needed in cases such as yours.
Aug 23, 2011 | Coleman Mach 15 Air Conditioner
Changing filter on coleman AC located under RV. 2005 Dolphin . I don't know the location of the filter on my Coleman RV AC unit located under the RV. Also, I would like a maintenance and operation manual...
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Aug 22, 2009 | Heating & Cooling
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
Need to find schematic on coleman 7333c886 ac
This is the web site for Coleman AC's from RVP. Go under the service manual for the 6700, 7000, 8000 and 9000 series air conditioners and they should have everything that you need.
Hope this helps,
Jeff
Jul 15, 2008 | Coleman Mach 15 Air Conditioner
Thermostat probe position for a 7000 Coleman AC
You should be able to ask the customer support at Coleman, as hey can send you the instalation manual for future reference -
Just click HERE or Email to
consumerservice@coleman.com
Thanks for using Fixya!
Jun 30, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
90 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
