Question about Radio Communications
What passkey would i use for a mt-4000 bluetooth headphone
Connected my phone to the headset, but can't remember the passkey to confirm? any help?
SOURCE: Lost Passkey
0000 worked for me
Thank you
Posted on Sep 05, 2008
  • 3 Answers
SOURCE: Passkey for H700c
The default is simply 0000. That is zero, 4 times.
Posted on Sep 24, 2008
boopleloo
SOURCE: Connect trueblue bluetooth headset to Samsung Eternity cell phone
I had the same poroblem. I turned the phone off and then restarted it. That worked for me. Try to make a phone call and see if you can hear it on the Bluetooth.
Also... compliments of Best Buy Troubleshooting -
Bluetooth Troubleshooting: Phones & Headsets
Problem #1:
Headset and phone are turned on, but you don't hear anything in the headset, i.e., there is no dial tone.
Action #1: Make sure your phone is Bluetooth-capable. If it is not: A. Buy a new Bluetooth-capable phone. B. Purchase a Bluetooth adapter for your non-Bluetooth phone. The adapter will allow your phone to interact with a Bluetooth headset.
Problem #2:
It's a Bluetooth-capable phone and Bluetooth headset, both are turned on, but you still don't hear anything.
Action #2: Make sure your phone, headset, and, if necessary, adapter are fully charged before attempting to synch the Bluetooth connection between the two devices - in many cases a blinking blue light will indicate the headset is charged.
Problem #3:
Everything is charged, but still not working.
Action #3:Before two Bluetooth-enabled devices can communicate with each other, they need to be initially synched up to each other - also referred to as linking or pairing.
A. Find "Communications" or "Connections" on your phone's menu screen and explore within to locate "New" or "Bluetooth."
B. Push the main button on the headset until the light shines solid blue and is NOT blinking. C. Select Bluetooth on phone menu. Within Bluetooth you may need to select and highlight "Devices" or "Find Devices" (depending on where you are, there may be other Bluetooth devices available).
D. While the headset light is solid blue, open the Bluetooth link (or Find Devices) on your phone's menu screen and scroll through until you locate the headset you wish to synch up to. Your phone will automatically begin searching for Bluetooth devices within 30 feet of itself.
E. After a short period of time, your menu screen should say "connected" or "devices paired". Make sure you click or select the device name to finalize the connection. If you have successfully paired the two devices, you will hear a dial tone in the headset. Congratulations! You've joined the Bluetooth world.
Note: After a couple of minutes showing solid blue, the light on the headset will start blinking; you want to pair up the phone and headset while the light is still unblinking. This is important. If the light starts blinking before you can complete the connection, you will need to turn the headset off and on and start over.
Problem #4:
You've followed all the instructions in this guide, and your Bluetooth connection is still not functioning properly.
Action #4: Take out your manual and carefully reread the section on synching up Bluetooth devices. If you still can't get things properly connected, we suggest you call the manufacturer regarding this issue.
Motorola: 1-877-MOTO-BLU for troubleshooting, or www.hellomoto.com
Jabra: 1-800-327-2230 from 8 a.m. to 8 p.m. EST for technical support; or www.jabra.com
I hope this helps.
Posted on Dec 19, 2008
SOURCE: Motorola H800 Bluetooth pass key
Motorola pass key is 0000
Posted on Dec 23, 2008
SOURCE: LG HBS 200 connection to the computer
the default passkey is 0000. try it and see if that works.
Posted on Mar 03, 2009
While i connect my wire less headset it ask passcode
1 Set your Bluetooth phone to discover the headset by following your phone's guide. Typically, the steps involve going to the Settings, Connection, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices. Your phone will find the Samsung WEP200 headset. 2 Select Samsung WEP200. 3 When the phone asks if you want to pair with it, confirm by selecting Yes or OK. 4 Enter the headset passkey or PIN, 0000.
Regards MaTi_FleSh
Jul 03, 2011 | Samsung WEP200 Wireless Headset
My jabra blue tooth asking for pass code , i tried with 0000 and 1111 and 1234 and 9999 but no use please help me
1. Put the headset in pairing mode
Make sure that the headset is on.
Press the answer/end button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to 'discover' the Jabra BT130
Follow your phone's instruction guide. This usually involves going to a 'setup,'
'connect' or 'Bluetooth' menu on your phone and selecting the option to 'discover'
or 'add' a Bluetooth device.
3. Your phone will find the Jabra BT130
Your phone then asks if you want to pair with it. Accept by pressing 'Yes' or 'OK' on
the phone and confirm with the passkey or PIN3 = 0000 (4 zeros).
Your phone will confirm when pairing is complete. In case of unsuccessful pairing,
repeat steps 1 to 3.
Jun 21, 2011 | Jabra BT130 Wireless Headset
How do I acitivate it
Charge your headset
Charge the headset's battery fully before using the headset for the first time.
1 Put the headset in the supplied charging case and close the cover.
2 Plug the travel adapter into the case's charging socket.
Put your headset in pairing mode
1 Ensure that the headset is off (see Turn headset on/off below).
2 Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Turn on Bluetooth on your phone and pair with headset
headset.
Your phone and headset are now paired and ready to make and receive calls.
1 Place the headset over your ear.
2 On your phone, make a call to the number you want.
3 If your phone and headset are successfully paired, you will hear ringing on the headset
After you have successfully paired your phone and headset, you do not need to repeat these initial setup steps each time you use the headset.
To turn the headset on
Press and hold the Multi-Function button for4 seconds until you see 4 blue flashes on the indicator light, then release.You will hear a tone and see the indicator light flashes while the power is on.
To turn the headset off
Press and hold the Multi-Function button for 4 seconds until you see 2 blue flashes on the
indicator light, then release.You will hear series of 2 tones and see the indicator light stops flashing.
http://ars.samsung.com/customer/DownloadAnsTempl?AT_ID=70171&SEQ_NO=2
Jun 07, 2011 | Samsung Bluetooth?® WEP200 Headset...
How to pair phone to samsung bluetooth headset wep301? I do not have my user guide.
Bluetooth Headset
Pairing Instructions
1. When you turn on your Samsung Bluetooth
headset for the first time, it proceeds into pairing
mode immediately.
2. If you have paired the headset with other
Bluetooth devices, make sure that the headset
is off. Press and hold the Multi-Function button
until the blue indicator light stays solid blue after
blinking.
3. Set your Bluetooth phone to discover the headset
steps involve going to a 'Setting', 'Connection',
or 'Bluetooth' menu on your phone and then
4. Your phone will find the Samsung headset and
ask if you want to pair with it. Confirm this by
pressing the Yes or OK key.
5. Enter a passkey or PIN, 0000 (4 zeros), then
press the Yes or OK key.
6. If pairing was successful, the indicator light will
flash in blue 10 times rapidly before going to
flashing every 3 seconds. If unsuccessful, the
light remains on, and you will need to re-attempt
pairing.
7. When you turn on your headset after pairing
with the phone, the headset is automatically
connected to the phone.
8. When you turn on your phone after pairing with
the headset, the phone is connected to the
headset by pressing the Multi-Function button.
Jun 01, 2011 | Samsung SGH-U600 Cellular Phone
Bluetooth headset won't connect in Vista
I had a similar problem. First part of the solution is to disable the headset profile for the headphones. These headphones can't handle both headset and headphone profiles at the same time. Second part of the solution is to make sure that your headphones are on when you activate bluetooth on the computer. For some reason, Vista doesn't like setting up the initial connection on-the-go, so it will just act like its connected and move on. Hope this helps!
Dec 07, 2008 | Insignia Bluetooth Wireless...
Passkey
The passkey is 0000. If you have a problem, reset the headset. Turn the headset off and hold down the call button for 8 seconds until the headset flashes blue and red signaling that it is in pairing mode for the next 120 seconds. While the headset is in pairing mode, use the phone menu to search for Bluetooth devices and select "220Plantronics." (If the headset is already listed in the Bluetooth menu, delete it before searching to pair the device.) When prompted for a passkey, enter 0000. Headset will falsh blue when paired successfully.
Nov 14, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Radio Communications Logo
22 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
