Question about Puma 3-HP 60-Gallon Belt Drive Single-Stage Air Compressor
Pk6060v parts list
Parts list
How do you set what pressure you want on Puma Air PK6060V? Have a sprayer that says do not exceed 50 PSI (in CAPS).
There is an adjustable valve at the outlet of the compressor pump that has a handle or knob on it, turn it to adjust line pressure
Nov 20, 2016 | Psi Air Tools & Compressors
Tip
McCulloch Chain Saw IPL (Illustrated Parts Listing)
Looking for a McCulloch Illustrated Parts Listing (IPL), Try this:
McCulloch Illustrated Parts Lists:
IPLs (exploded parts lists) are fairly simple, on the underside of McCulloch saws is a small black and yellow tag; the upper number (“Power Mac 320” 600021H or -8 if European) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H or -8). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Utilize the IPL number you just created here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
There are many suppliers of McCulloch parts, some with a better selection than this one. Once you have identified your part try an Internet search for "McCulloch YourPartNumber"
Lou
on Dec 02, 2009 | Garden
Is there a parts list to repair
Search Results
    Parts list ' TV-B-Gone Kit ' Adafruit Learning System
    https://learn.adafruit.com/tv-b-gone-kit/parts-list
    Apr 21, 2013 - This is the parts list for v1.2 ONLY! If you have a v1.0 or v1.1 kit thislist will be incorrect! See below for the v1.0/v1.1 parts list guide. Check to ...
    Samsung Television Replacement Parts & Accessories ' Sears
    www.searspartsdirect.com > All Brands > Samsung Parts
    We carry manufacturer approved replacement parts and accessories for 1165 ... Samsung Television Parts .... Join our email list for updates and exclusive offers.
    LCD ' LED TV Parts And Accessories for Samsung, Vizio ...
    www.tvtechparts.com/lcd-led-television-parts-accessories.html
    The best TV parts on the market that are 100% tested by experienced TV techs. ... on each part and do not relay on pictures or model number alone as there is ...
    TV Boards, Parts and Components ' eBay
Jan 04, 2016 | Televison & Video
Where can I get a new pressure switch for my puma 6060 air compressor
Replace the pressure switch with generic switch available on ebay. You only need the port sizes and pressure cut in/out. If your switch cut out at 150psi or higher, you might consider replacing it with one that cuts out at 125psi to increase the life of the compressor (assuming that you can get by with pressure range of 90 - 125). Good luck
Feb 26, 2015 | Puma Air Air Compressors Puma Air PK6060V...
How do I fix my pressure switch on my puma 6060 compressor
Need some details, exactly what is it doing or not doing incorrectly.
I need to fix a leak in my pressure switch
You don't repair a pressure switch, you replace it.
Nov 28, 2014 | Puma Air Air Compressors Puma Air PK6060V...
Need part # for LTF2140E53oor handle for
The model number for your washer is actually LTF2140ES3. Parts can be purchased at any of the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The door handle part number is 134412860 and is listed as item 46 under the "Cabinet/Top" parts listing. If you are referring to the door LATCH (vice the handle), the part number is 131763202 and is listed as item 8 under the same parts listing.
If you need further guidance, please post back and let me know. I hope this helps you.
May 05, 2011 | Frigidaire Washing Machines
Lookin for manuel for riding lawn mower model # 917.254410
Are you looking for a user's manual or a parts manual?
If your looking for a parts maunal you can go to this page and enter your model number: http://www.searspartsdirect.com/partsdirect
your model number
917.254410
They usually have user's manuals there that you can order. The manuals are listed in the parts list. Sometimes it is the first item on the parts list. Other times is is the last item on the parts list.
The Sears Direct site is currently down for weekend maintenance or I would list both of the manuals for you.
May 30, 2010 | Garden
Find a parts list book for yamaha 600 diversion
I am assuming you are not familiar with Babbitt's Sports. Their web site has the entire parts list in exploded diagram format and also lists prices. No need to download. The lists are available 24/7/365. Go to www.babbittssports.com/parts/viewbybrand/parts.aspx Please rate my answer.
Jan 12, 2010 | 1994 Yamaha XJ 600 Diversion S
Need Grill manual and parts list with pictures for for Char-Broi
Ordered part from manufacturer. Help was in the form of being able to download the assembly manual and identify the part number for the electrode (my original manual was missing). The part list for the grill listed two electrodes? and was confusing.
Jun 24, 2009 | Char-Broil 463232103 Grill
Puma 3-HP 60-Gallon Belt Drive Single-Stage Air Compressor Logo
65 people viewed this question
Top Puma Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Puma Tool and Hardware - Other Expert? Answer questions, earn points and help others
