Question about RTO Oar Sockets
Jlo rockwell 4hp outboard
Hi there would like to know how to cheak oil in bottom leg
1993 Suzuki 4hp 100.1 how much oil per gallon
the manual shows for a 100 :1 mix the ratio is 4 ounces of oil to 3 gallons of fuel
there are two engines and one is 50: 1 ratio so that would be 8 ounces of oil to 3 gallons of fuel
there is a pdf version workshop manual at www.motoren.ath.cx and it gives the ratios for all of the 4hp suzuki outboards and the oil to use
Oct 01, 2016 | Clymer Suzuki 2-225 HP Outboards Includes...
How do I free up a frozen outboard shifter
Hi Rick:
Don't know what unit you are dealing with, but stuck in my memory is the way the old Merc used to work.
There was a rod that rotated, and the shift mechanism slid into a slot. We only tilted removed the bottom end with the shifter in the forward position.
You may need to drop the bottom end to allow the shifter to be placed in the correct position.
I'm hoping that you are using the term "frozen" to describe "blocked", as another total PITA can happen when portions of the assembly become corroded. Loosening them up requires tha delicate balance of heat, penetrating oil, and brute force. Bearing in mind you don't want to set it on fire or break it.
I'd try dropping the bottom end, engage it in forward, place the shifter in forward, and carefully slide the bottom end back on.
Hope this helps.
cheers
Jun 30, 2016 | Cars & Trucks
How do you change the gear lube in a Evinrude Triumph 70 hp outboard motor?
Hi .
There should be two flat screws on the lower leg, remove the bottom one and then the top.have the motor fully down position to drain, when filling with new oil it has to be done from bottom to purge the air out, Gear box is full when foil comes out top screw, install top screw and then bottom, you'll lose a bit of oil when bottom is removed install . if not sure have a look on YouTube, it should help you out.
Good luck.
May 28, 2016 | Boating
Steering wheel wont move right or left engine wont move don't want to force it
inboard or outboard motor ??
unbolt the steering cable from the steering point of the engine or leg unit , then try turning the wheel and if it moves then try moving the engine or leg unit and see if it moves !?
Mar 27, 2015 | Boating
How to find model number on mariner outboard 4hp 2stroke engine
Mariner 4hp are identical to Yamaha engines.
You should find a sticker on the port bracket with serial and model number.
If that sticker has disappeard, an aluminum piece is stamped in the side of the cilinder. The numbervstamped in that round pieceis the serial number. I can convert that serial number in a year/model number...
Feb 27, 2015 | Mercury Marine 4hp & 6hp Stroke Outboards...
Water pump
The water pump is a flexible impellor located in the top of the bottom section of the leg of the outboard. It is driven by the drive shaft to the prop that is spinning all the time the motor is running. You will find it behind or near the water inlet slots at the bottom of the leg
May 14, 2013 | Seloc Mercury Outboard Engine Repair...
Johnson 235HP Outboard - oil leaking from bottom leg - dark black so picking it is the two stroke oil
most 2 stroke motors will not burn all the oil in the mix and that unburned oil coats the exhaust leg and leaks out the thru hub exhaust and parting line of the lower to the housing. so keep some windex handy and clean it up.
Oct 09, 2012 | Clymer EvinrudeJohnson Outboard Shop...
How to change gearbox oil on a seabee tempest outboard motor the gearbox is on the leg made by ocean outboards of southport england what i want to do is drain it then ship it jamaica the gearbox oil...
These I think you will find were made in Yugoslavia by the Tomos company and sold under the "sea Bee " brand in the UK for some reason.
I may be stating the obvious here but usually outboard gearboxes have 2 plugs one top and one bottom. Take out both to drain the oil and then fill from the bottom hole forcing in the oil till it comes out of the top hole, then refit the top plug followed byt the bottom one.
Jun 02, 2010 | Boating
What is the correct fuel/oil mix for evinrude 4hp ?
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
Jan 04, 2009 | Boating
RTO Oar Sockets Logo
78 people viewed this question
Top RTO Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a RTO Boating Expert? Answer questions, earn points and help others
