Question about Garden
Stanley lawn mower
How do I replace the belt on the bottom.. And i can get it out of gear to mow?
SOURCE: BOLEN RIDING LAWN MOWER 13AN683G163 TRANSMATIC
Either the belt routing is incorrect or there is a tensioner which needs adjusting. Recheck your belt installation. Oh, it could be the wrong belt, too.
Posted on May 01, 2009
  • 376 Answers
SOURCE: MTD Lawn Tractor problem
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
Posted on Jun 28, 2009
mhamlin63
  • 138 Answers
SOURCE: Self propelled lawn mower inside of drive wheel gears stripped.
Check the drive shaft bearing closest to that wheel.
Posted on Jun 29, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
  • 78 Answers
SOURCE: blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Posted on Oct 29, 2009
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
Why does my toro model 74301 keeps dieing
There are many reason a lawn mower dies in gear. Buildup of grass on the underside of the deck, mowing in too deep or thick lawn causing too much load on the blade, or the air filter needs cleaning.
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_843b43f7ebebd3f5
Jul 19, 2014 | Toro Garden
Why won't my 22 in. Kohler Low Wheel Variable Speed Self-Propelled Gas Lawn Mower self propel anymore?
i would guess that the belt is'nt tight enough when engaged. when you press the drive bar on the handle it should make the belt really tight if not it will need replaced. sometimes the gears in the wheels will mess up. there are videos on you tube that describe that and also the belt.
Apr 22, 2017 | Garden
Won't move in any gear
did the belt let go?is it a auto trans and the lever on the rear is pulled out that allows you to push it?
May 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I put a new belt on my Troy Bilt Lawn Mower and I used it to mow lawn and it chewed the new belt up
Is belt routed correctly.
Check pulleys for wear and if they spin freely
Check belt tension. Lack of sufficient tension will throw belt and destroy it
Aug 18, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Slow Mow
Try fixing this problem by making sure the belt is installed properly.. Whenever you install a drive belt it needs to be "seated". Make sure the belt is on correctly and the first time you try it out to see if the mower will move, start out in the highest gear. Hang on as it may ****, but this is the proper way to replace and seat a drive belt.
Jun 21, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Belt slipped on the poulan self propelled lawn mower
The belt hopped off likely due to grass or other things getting in-between the belt and pulley near the blade. You should be able to remove the cover on the top of the mower deck, remove the belt from the pulley under the cover, place the belt back on the pulley near the blade and then on the pulley under the cover. If the belt is shiny on the sides or you see black powder caking the inside of the cover or area's around the pulleys or the belt looks like it has chunks missing from any part of it the belt should be replaced. local hardwares, automotive and DIY centers that carry outdoor power equipment parts can match it up with the one the manual recommends using.
Tip: Keep the blade sharp, I recommend buying a couple blades so that you can always have a sharp spare installed while the other is being sharpened, change the blade as soon as the sharp edge is gone and becomes somewhat rounded on the cutting edge. If the lawn produces a lot of dust or there are lots of bald patches this will dull the blade quickly as will chopping up stick with the mower, if this is the case take steps to improve the lawn and keep the sticks picked up before you mow.
Change the oil before using it in the spring and after each 50 hours of use (more often if its used in a dusty area).
I recommend using a synthetic oil unless the manual specifically states not to.
When mulching mow in counter clockwise circles, when bagging mow in clockwise circles and in either case overlap about 1/4 the width of the mower for a complete smooth cut. after each mowing allow the mower to cool then tilt the mower on its side opposite of the carburetor (where the air filter is) and wash off the stuff stuck to the bottom, you may have to use a putty knife on the real thick or stubborn stuff. This will reduce corrosion over the years and keep the mower running and mowing efficiently not mention it avoids blowing into the air backteria produced as the clippings of past mowing decay (it makes me sneeze).
May 14, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
