Question about Onkyo TX8050 Network Ready Stereo Receiver
Can you connect an eq to the onkyo tx8050 - Onkyo TX8050 Network Ready Stereo Receiver
How do I turn on the tape monitor on my Onkyo TX-NR901 to use the equalizer I hooked up?
I don't believe you can use the tape monitor (or any recording output) when using the optical inputs.
Apr 23, 2016 | Onkyo TX-NR901 7.1 Channels Receiver
Hook up eq to reciever
Hi Michael, the EQ would be connected to the Tape2 Monitors input/output, Thanks, JT
Apr 19, 2015 | Onkyo Quartz Synthesized Tuner Amplifier...
Onkyo tx8050 turns off with ipad 2
How are you connecting to the Onkyo? Wired or Bluetooth?
Apr 05, 2014 | Onkyo Audio Players & Recorders
How to hook up a DBX 231 to an Onkyo P301
you will need 4 1/4 inch male to rca male cables, use tape monitor (tape out to line in on eq, line out from eq to tape in on receiver, make sure both buttons that control line level on the back of the 231 are set for -20dbv press tape monitor to use eq, turn off to bypass it.
Mar 06, 2014 | DBX Audio Players & Recorders
Bose 901 hookup with Onkyo SR 805 and Onkyo M282 amp and 901 EQ/
The good news. I have a setup similar to what I think you're trying to do and it works great!
The Onkyo M-282 stereo amp for the 901's is the perfect solution. Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
**Onkyo SR805 Pre-Out Front >>> Bose EQ Amplifer IN
Bose EQ Amplier OUT >>> Onkyo M-282 IN
Set the Input Level on the back of the Onkyo to MAX. The receiver controls everything just fine after you run through your level setup routine again.
I was looking a the 12v triggers on both units and it looks like you only have a Zone 2 trigger so that wouldn't work for turning on your M-282. I guess you're going to have to turn it on and off the old fashioned way, like I do mine.
Mar 15, 2009 | Onkyo TX-SR705 Receiver
Gemini Sound Products EQ-3000 equalizer
please connect as the following-----1-mp3 out-----to cd in in your receiver.
2-receiver rec out (tape put)----to equalizer in.
3-equalizer out----to tape in in receiver.
Sep 17, 2008 | Gemini Sound Products EQ-300 Home...
Cannot hook eq to my receiver
The speakers will not sound right. You dont have two tape monitors on this receiver? You can simply use the tape otput to the EQ input, and then the Tape monitor input to the EQ output leads. Good Luck
Jun 09, 2007 | Bose 901 VI Main / Stereo Speaker
Onkyo TX8050 Network Ready Stereo Receiver Logo
70 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
