Question about Frigidaire Affinity FAFS4474LW
Affinity Washer Stuck In "Sensing" Mode
Front Load Affinity Washer Stuck in "Sensing" Mode. Seems to have stopped working on the last load, however, as it stopped with 1 minute remaining in the spin cycle. It allows me to press cancel and it does allow me to pick a cycle and press start but it just stays in the "sensing" mode. Any suggestions?
My affinity washer door wont close. Seems the door lock is not working or something is stopping the door from latching
you may have broken off a piece of the latch
(hook portion) either on the door or the receiver portion on the machine. check for diagrams online using model #
Apr 04, 2016 | Frigidaire Affinity FAFW3577KW 3.5 Cu. Ft....
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity Washer making clicking sounds after power outage.
Sounds like either the control board or the timer is faulty at this point. Contact a professional so they can diagnose the unit fully and repair where needed.
Jul 28, 2012 | Frigidaire Affinity ATF7000E Front Load...
Fabric softener will not drain
Try cleaning out ..this should cure . the other thing that can cause this is a faulty solonoid valve as some machines have a seperate valve for this action....
Nov 25, 2009 | Frigidaire Affinity ATF7000E Front Load...
The washer is stuck in pause mode. How do I get
Control Lock To avoid having someone accidentally start or stop the washer, press Options and Select at the same time and hold for 10 seconds until “LOC” is displayed alternately with the estimated cycle time. To unlock the controls, press Options and Select at the same time and hold 10 seconds until ”LOC” is no longer displayed.
Sep 18, 2009 | Frigidaire Affinity ATF7000E Front Load...
How to diagnose
Sounds like your motor is blown. That's going to require a repairman.
Mar 31, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Error messege, front loader wont start.
my name is joyce
first try the simple step, unplug unit for 60 secounds, then replug unit back up. reset load and see if that works. let me know if I can be of further assistance.
joyce
Feb 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Aug 25, 2008 | Frigidaire ATF6000ES Front Load Washer
Machine stuck on pause/err
un plug the washer for 5 minutes and re try
May 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity FAFS4474LW Logo
169 people viewed this question
Top Frigidaire Affinity Washing Machines Experts
Are you a Frigidaire Affinity Washing Machine Expert? Answer questions, earn points and help others
