Question about Frigidaire Heating & Cooling
Frigidaire Air Conditioners make alot of noise when running
The second year we put the AC in the window it makes a really loud noise like it has a bad bearing. Model LRA127CT1.
  • Official Brand Answer
  • 4,342 Answers
Hi James - Thank you for your question! I am happy to assist you. I understand you stated it sounds like a bad bearing, however may you please describe or me more specific in the particular noise the air conditioner is making? Does the noise occurred at all times? With this information I can better address the issue at hand and provide you the most accurate information. Thank you and I look forward to your response.
Posted on Jul 18, 2013
22yooper
  • 828 Answers
SOURCE: Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
Posted on May 16, 2008
22yooper
  • 828 Answers
SOURCE: outside makes loud noise
I would take a very close look at every solder joint there is between the inside unit and the outside. If you observe oil at any point it indicates a leak at that point. That is an expensive price for what you say was done. Check your invoice for the amount of refrigerant they or he added to the system. Compare it with the amount stated on the outside unit nameplate. Check for frost on the suction (big line) by the outside unit. If there is frost your coil is frozen up. If this is the case turn the fan on and the cooling off. Allow it to run in this manor for about an hour to defrost the A coil. Then return to the cooling mode.
Posted on Jun 16, 2008
bobicehouse
  • 1524 Answers
SOURCE: Air Conditioner from upstairs neighbors condo makes water sounds
Time for a new unit. End of sentence.
Posted on Apr 26, 2009
  • 166 Answers
SOURCE: Loud Noise from 76081 AC
The chances are you are damaging your A/C with each use that makes that loud sound. What kind of loud sound is it? Is it like a rattling sound? Here's a great, handy diagnostic article on that, specifying probable causes of it:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Making_Rattling_Sound.htm
You also might want to take advantage of the text-link that offers up to four (4) free A/C contractor estimates from those in your area--you can "pick their brains" as to what they think is specifically going on with your A/C and attempt to then use their information to fix the A/C on your own, or, altogether, and for the better, pick the best-priced estimate and have it resolved this hot summer season before more damage is done.
Brad
Posted on Jun 26, 2009
  • 193 Answers
SOURCE: water doens't drain properly and sitting there,
that's fairly common for window units, it's ok to drill a small hole in the underside of the case to drain the water, just be sure you don't puncture the condenser in the process.
Posted on Aug 18, 2009
Compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
Aug 04, 2012 | Frigidaire FAH106N1 Wall/Window Air...
My window air conditioner is making very loud noises and it is not dripping water outside
No condensation means no freon flow in condensor which sounds like bad compressor which would account for the noise. Replacement would probably be most economical way to remedy.
Aug 12, 2010 | Goldstar KG6000R Window Air Conditioner
After compressor on,Sears/Kenmore ac makes a loud vibration noise
sounds like head pressure problem it is most likely clogged on condenser try washing out really good then try again
Sep 10, 2009 | Heating & Cooling
Water doens't drain properly and sitting there,
Aug 18, 2009 | Frigidaire Heating & Cooling
Way too loud
it is prob. a pipe vibration, window unit are not knowen for quiet running
May 02, 2009 | Goldstar KG6000R Window Air Conditioner
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Heating & Cooling Logo
170 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
