Question about Refrigerators
Kenmore side by side refrigerator 1991 model
I have a 1991 kenmore side by side refrigerator. Model 106.9505582. Can I get new handle covers for it. They are falling apart.
fridgetech
  • 473 Answers
SOURCE: Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Posted on Oct 05, 2007
SOURCE: kenmore side by side refrigerator model 106.56532400
Thanks for taking this question.
Kenmore 22 cft side by side does not have air circulation. Freezer is cold at the bottom (ranges 5-45 deg from bottom to top). Refrigerator section is 30- 60 deg from bottom to top. Thermostat is good; compressor is working; no ice deposit on the evaporator coils; condenser coils have been cleaned; defrost heater is working. I do not feel the air draft I used to notice whenever opened refrigerator door. Is it possible that the air recirculation fan not operating. Location of this fan in the refrigerator? Regards, Prem
Posted on Feb 19, 2008
  • 1462 Answers
SOURCE: side by side kenmore refrigerator
defrost system not working. take back plate off freezer. checkdefrost heater and any stats mounted on the pipework
Posted on Sep 10, 2008
  • 14 Answers
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Posted on Apr 04, 2009
aasc
  • 1606 Answers
SOURCE: I need to take the handles off on my kenmore side
Try sliding them upwards ( the top ones ) , downwards ( for the bottom ones ) , as far as they will slide , then remove .
Posted on Nov 13, 2009
I need exterior dimensions of old Kenmore side by side model 10656234000
Dimensions for a 17cft model!
Dimensions and Capacity:
Depth w/ Handle (In.): --------- 30.375
Depth w/out Handle (In.):------ 30.375
Height to Top of Case (In.): -- 67.375
Height to Top of Hinge (In.): -- 68
Width w/ Door Closed: --------- 28
Jul 23, 2016 | Kenmore Refrigerators
Replace dooor handle side by side kenmore coldspot 10656833602
There is a cover on the handle. Remove with a screwdriver by gently prying...careful not to break the plastic clips. Once removed, unscrew the main handle & replace.
Dec 17, 2013 | Kenmore 18.3 cu. ft. Top Freezer...
Have a Kenmore model 596.51673100 and the handle is loose how do you tightne it?
see if the plastic part of the handle will snap off, then you can get to the bolts
Oct 28, 2010 | Kenmore 57029 Side by Side Refrigerator
Freezer handle falls off on one side , kenmore elite - pull drawer freezer
Mine does that too. I've simply accepted the fact the the screw holding the handle on just loosens over time. Periodically, when I feel the handle becoming loose, I tighten it with an allen wrench and go on.
Feb 21, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
How do you replace the light switch?
Unplug the refrigerator.Take a small skinny flat screw driver and pry the switch out. You can unplug it once you have it out but hold on to the wire so it does not fall into the refrigerator. Have the new switch ready to install or tie or tape the wire while you go get the new switch.
Oct 27, 2009 | Kenmore 57029 Side by Side Refrigerator
The handle on my Kenmore Elite Side By Side Refrigerator is breaking. How do I replace it?
Hi, first you should get a handle at your nearest appliance store. The easiest way is to see how that one fits. This will give you an idea of how the other one comes off. But is should have 2 cover plated on the handle. One on the top and the other at the bottom. This can be taken off with a very small flat point driver.
Sep 18, 2009 | Kenmore 53642 / 53644 Side by Side...
Replace Refrigerator Handle
should have screw covers to remove. then remove screws. cover are at top and bottom of handle. push up at top one and down at bottom.
Jun 21, 2009 | Kenmore Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
