Question about Acer Aspire Computers & Internet
Mouse working backwards
My touchpad on my acer is working backwards. right is down,left is up,up is right,down is left. how do i fix this maddening mouse?? ps i accidentlly lightly stepped on the computer but it was enough to break the screen. i replaced the screen but when i turned it on the mouse was broken
  • brenton Jul 18, 2013
    figured it out. uninstalled the mouse driver then reinstalled
    Problem Solver:
  • 9 Answers
Go into setings and there will being a setting that says vertical change it to horozontal sorry about my spelling
Posted on Jul 18, 2013
SOURCE: Touchpad has no tap, left key not working.
I had this issue and resolved it by doing the following:
-Open the start menu by using the windows button
-Use the arrow keys to highlight run and press enter
-Type 'control panel' and press enter, find the mouse properties and enter
-From the buttons tab in mouse properties, go to double click speed and change to slow and confirm the changes
-At this point it probably still wont work, so do the above again but change the double click settings to fast and confirm.
-Restart your PC and this should resolve the matter. you can alter the double click speed again if you wish :)
Hope this helps,
tbo
Posted on Jul 18, 2009
ta_mcguire
  • 125 Answers
SOURCE: acer d150 left trackpad button not clicking/working
go to control panel click on mouse and set for right handed
Posted on Jul 30, 2009
martyshaw152
  • 157 Answers
SOURCE: I've had the acer one for 2 weeks. While using it
Hello cskpuels,
It sounds like the touchpad is working ok but probably needs some setting(s) adjusted. The touchpad settings can be accessed through the windows control panel. But before going to the control panel it's useful to review the touchpad basics for single and double clicking. They are as follows:
•Tap once on the main touchpad for single click.
•Tap twice for double click.
•The lighter the touch, the better the response.
•Tapping harder will not increase the touchpad's responsiveness.
•Opening the Control Panel
The Windows Control Panel can be opened by:
Selecting *Start > Control Panel (on Windows Vista)
- OR -
Start > Run > Type 'Control' and select OK (on Windows XP)
*The Enter key may be used on the keyboard in place of touchpad clicking*
In the Control Panel, do the following:
•Select Mouse [Enter] (Brings up the touchpad properties sheet)
•Look at the Buttons tab in the touchpad properties sheet.
•Adjust the settings and test the touchpad until you get the response you desire.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Posted on Aug 01, 2009
  • 14 Answers
SOURCE: My touchpad right and left click button stopped working
is there a touch pad lock button, that locks the pad? if there isn't then there is most likely excess debris or dust or something under there that needs to be blown out with airisol can. If both of those solutions don't work then i would check to make sure the driver is installed for the touch pad. Good Luck. and i hope it works out.
RATE THIS SOLUTION
Posted on Aug 24, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: acer touchpad not working
Hi thre can you please check the touch pad mode? May be its disable some how. Or try to press FN+ F7 key for enable / disable touch pad. What is happend please let me know. Thanks.
Posted on Mar 18, 2010
Testimonial: "perfect--you are wonderful--bless you"
Touchpad, mouse and keyboard not working
Try installing the touchpad driver from here http://www.helpjet.net/files-Acer-Aspire-4810T.html#ATouchpad
Once you are done restart your Acer and see what happens.
If this doesnt resolve the issue it may be a problem with the hardware in which case you may need a new touchpad. otherwise just use a mouse as a fix either temporarily or if it turns out to be to expensive to fix.
Aug 17, 2014 | Acer Aspire 3810T 4810T 5810T
TOUCHPAD MOUSE ANS KEYBOARD NOT WORKING
Try these steps.. Click start button, type "mouse" on Search Programs and Files, click "mouse" under control panel. In mouse properties options....as you an see the touch pad driver tab? click it. Choose or click option button and you can enable the right and left click button. About the keyboard problem,,,,,go to device manager, right click the standard PS/2 keyboard..uninstall it. Windows restarting and the keyboard driver will re install automatically.. check if the keyboard works fine.
Acer mouse disassemble ???
The Acer Aspire is a laptop model that has a built-in "mouse pad," also called a "touchpad." The user runs his or her finger across the mouse panel to move the cursor. If your mouse pad no longer responds to your touch, it may be due to a build-up of dirt and grease. Another common problem is having an outdated or damaged mouse pad driver. These problems can be quickly resolved without having to take apart the laptop.
Hold down the "Fn" key, which is found at the bottom left corner of the keyboard. Press the "F7" key once while holding the "Fn" key. Look for a message that says "touchpad enabled." b> Update the Drivers Go to "Start" > "Control Panel" > "System and Maintenance" > "Device Manager." Double-click on "Mice and other pointing devices" to expand the options. Right-click "Synaptics Touchpad" and then click "Search automatically for updated driver software." Wait for the computer to scan and install new drivers. Restart your laptop.
http://www.youtube.com/watch?v=oUyxhcQk6G4 Acer Aspire 5738 7736 Touchpad Mouse Replacement
Jan 30, 2013 | Acer Computers & Internet
My acer aspire 5742Z touchpad is too sensitive or I don't really know how to use it. Every time I touch it something stupid happens on screen. Now it has turned my screen dispay side on and I have to use...
Definitely your touchpad is TOO SENSITIVE!
To modify the sensitivity just go
START > CONTROL PANEL > MOUSE/TOUCHPAD and adjust there the sensitivity by dragging the cursor to the LEFT until it reaches the middle.
In PROPERTIES just re-invert the functions of your touchpad to get rid of the mixed axes.
Mar 03, 2011 | Acer Aspire 5742Z-4200 Notebook
Acer aspire one netbook touchpad wouldnt work could only use with left click - trying to fix managed to disable touchpad by mistake now curser wont work how can i enablei it when cant use curset? please
If possible try to connect a USB mouse and use that to enable the touchpad...
After that reinstall the drivers for the touchpad the issue should be fixed... Even if you still have the issue then call the computer manufacturer.
If you dont get a USB mouse.. Then turn on the computer get into safe modem by tapping F8... Try to check in safe mode whether the touchpad is working.. If its working reinstall the drivers the issue will be fixed
Oct 14, 2010 | Acer Netbook
My acer notebook right click wont work. can you fix it? thanks
Re-installed your Touchpad driver.By default,it shoud work otherwise use an external USB mouse and check your Right-Click. If it work then the notebook Right Click Touchpad mouse has some faulty.
I think you won't be able to find spare in any sites even Manufacturer sites,you have to carry on with an external USB Mouse.
Jan 02, 2010 | Acer Computers & Internet
Acer d150 left trackpad button not clicking/working
Jul 29, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire one touchpad mouse does not work. USB mouse works. Also FN F5 stopped working
Aspire D250.....
Hold down function key fn (lower left on keyboard) and tap F7 key once..
May 02, 2009 | Acer Aspire One PC Notebook
Typing problem with keyboard
the easy method would be to hook up a USB mouse and disable the touchpad to see if that works. Control Panel -> Mouse (or Printers and other Hardware), then click on the mouse and then click on Advanced or Hardware tab to look at the options. You might be able to have it disable the touchpad when a mouse is present.
Feb 26, 2009 | Toshiba Satellite M55-S329 Notebook
I have an ACER ASPIRE 4315 laptop. For some unknown reason the right mouse pad button no longer works. Can you please advise me how this might be fixed. The left mouse pad button works fine. When I say...
you may wish to go to the acer website and look up that model... download the driver for the touchpad and buttons again. reinstall that and see if it fixes the issue
Robert
Aug 29, 2008 | Acer Computers & Internet
Computers & Internet Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
