Question about Linksys E3000 Wireless Router
Open tcp ports
I am trying to make my NAT on Xbox 360 OPEN. Its on MODERATE right now, I created a unique IP and everything, I just need to know how to open Port 88 (UDP) Port 3074 (UDP and TCP) Port 53 (UDP and TCP) Port 80 (TCP)
  • 345 Answers
Http://support.linksys.com/en-us/support/routers/E3000
This should have a manual for this router that will explain how to open ports on the router for game play.
Posted on Nov 03, 2013
3 Suggested Answers
JackHeath
  • 1049 Answers
SOURCE: cant create game server due to NAT settings
Make sure that you are using 1:1 NAT and not dynamic NAT, but more likely its a configuration issue. Some game servers like private WoW servers or Armagetron work better when the configuration file is setup with the computers IP and not "localhost" which is technically 127.0.0.1 and not Nat'd.
Posted on Jan 26, 2009
  • 52 Answers
SOURCE: How do i forward ports with an WRTSL54GS Linksys
open 192.168.1.1 in your web browser, the password is 'admin' when on factory settings (no username)
There will be a lot of options, You will want the Applications/Gaming section. Enter the ranges, set it to both for protocol, then enter the last number of the ip address of the device you want the ports forwarded to. For the port 47624 just enter that number in both the start and end section. Good luck!
Posted on Apr 19, 2010
Every time i try to join my friends game it says session is ureachable and it is really annoying. We live at different IP addresses and could connect before. We all have the same DLCs and it is only me...
make sure you and your friends have open NAT, you need to port forward certain ports for xbox live on your router, try to check if ubisoft also has specific ports need to be open. if still the same contact your ISP, they might be having problems.
Mar 23, 2011 | Ubi Soft Assassins Creed: Brotherhood for...
I have a ps3 and an xbox 360...when I have my nat type on moderate then i can sign on both of them no problem but have a time trying to connect to some other of my friends. when I make my nat type open I...
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Jan 06, 2011 | Arris SURFboard SBG900 Wireless Router...
Hello. I need to change my NAT type on my Xbox 360 from moderate to open using a Westell Versalink 7500 router.
Hello
Your router does not have moderate or open nat options.
Options that it does have are Public Lan - nat type and Private Lan -nat type.
Your router also has a DMZ feature and port forwarding options.
User manual for your router is available at http://www22.verizon.com/ResidentialHelp/HighSpeed/Networking/User+Guides/User+Guides.htm
To get your xbox live working properly, you can try using the public nat type, if that does not solve the problem, turn on DMZ for the address of the Xbox360. Now if that still does not solve the problem, then you would need to set up port forwarding for all the ports that xbox live uses.
I would personally recommend that you enable port forwarding for the required ports.
Ports that need to be open are
TCP 80 • UDP 88 • UDP 3074 • TCP 3074 • UDP 53 • TCP 53
Together with the user manual and xbox360 portforwarding guides that are available here http://portforward.com/english/applications/port_forwarding/Xbox_Live_360/Xbox_Live_360index.htm
You will be able to get it working.
But since that is a lot of information for anyone that has not used port forwarding before I'll write down step by step how to get started.
First get on your computer, You need to connect to the routers own configuration page. By default this is http://192.168.1.1
So, open your internet browser and write HTTP://192.168.1.1 and press enter.
Now you get a a user and password prompt. the username is admin and the password is password. all lower case.
Now on the top menu, click on Firewall settings.
Now select Port forwarding. more information and pictures on the user manual page 98 and forward. You need to create a new rule or rules that forward the above ports - allow them to be open to the internet for the xbox 360.
Looking at page 112. You would create a new port forwarding service, you need to add all the ports one by one. And the host device would be the IP address of the xbox.
Now the DMZ option will be simpler, that is on page 118. You just need to find the xbox ip address from its network options and put it there, and turn on the DMZ. That will allow all traffic for that machine.
Let me know how far you get. I'll help if you get stuck, sorry if this post is a bit unclear, this is a very small box to write in, I can't easily see everything I've already written here.
Sep 27, 2010 | Computers & Internet
My router is on, and is hooked up to my verizon modem. My xbox 360 and my computer are both hooked up to the router and all the lights are on but only my computer is working for the internet where my 360...
with verizon, you need to set the modem to full bridged mode so that the connection from your modem will be opened. This certain firewall is called NAT. Your modem and your router has this feature. To disable NAT on your modem, you need to set it to full bridged mode. To disable the NAT on your router, you need to open ports on your router.
You need to open this port on the router for Xbox live to work
TCP: 80, 3074, 53
UDP: 88, 3074
forward it to the ip of your Xbox.
this should set the NAT on your xbox to open, not moderate.
Sep 18, 2010 | Dell TrueMobile 2300 Wireless Broadband...
Hi i have a xbox 360 and i was wondering how i change my nat from moderate to open
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
Aug 08, 2010 | Microsoft Xbox 360 Elite Console
My ports are not open and my internet say you nat type is moderate
If you have a firewall or network hardware, such as a router, you might need to make a configuration change in order for your Xbox 360 console to communicate with Xbox LIVE. This configuration change is sometimes called “opening ports” or "port forwarding."
Xbox LIVE requires the following ports to be open: • TCP 80 • UDP 88 • UDP 3074 • TCP 3074 • UDP 53 • TCP 53
Jul 01, 2010 | Microsoft Xbox 360 Elite Console
NAT issues (moderate)
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
Jul 06, 2010 | Microsoft Xbox 360 Console
Xbox nat setting
Mar 07, 2010 | Microsoft Xbox 360 Controller
My nat is moderate. how do i fix it to make it more open
You can simply forward ports. I believe you are using XBOX 360. Here are the ports that you need to open
3074 TCP
3074 UDP
88 UDP
80 TCP
53 TCP
53 UDP
You can open those ports using your router's Port Forwarding feature. To know more about portforwarding, you visit www.portforward.com
Oct 23, 2009 | SMC Barricade SMCBR14UP Router
How to set my xbox360s NAT to OPEN Witha netgear WGR614v7 Router?
Basically you have to open the application port of XBOX on your router. To do that you have to access the router's GUI and forward the ports. To access the router go to http://192.168.1.1 username is admin and password is password by default, click the port forwarding tab and open this ports
  • TCP 80
  • UDP 88
  • UDP 3074
  • TCP 3074
  • UDP 53
  • TCP 53
  • Click add customer service and type xbox for service name and the IP address of the xbox.
    Jun 30, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
    Linksys E3000 Wireless Router Logo
    90 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
