Printer i set up the printer exactly the way the directions said and yes it does work ,it's brand knew i just can't print anything from my computer to the printer!!
  • rezgrlps5 Aug 28, 2007
    i already did that
  • 640 Answers
Make sure all the drivers for the printer are installed.if using xp goto contol panel and then printers make sure that printer is listed and enabled.
Posted on Aug 28, 2007
  • anthony james
    anthony james Aug 29, 2007
    ARE YOU USING USB OR PARALLEL CABLES?ARE YOU GOING THROUGH A ROUTER?IF SO MAKE SURE THE PORT IS OPEN WHERE YOUR PRINTER IS LOCATED.LET ME KNOW
My lexmark x3470 wont recognise compatible ink Cartridges any know of a way round this
If the ink cartridges you purchased are not Lexmark - that could be the problem. I used to have a Lexmark printer and I did the same thing - I purchased ink cartridges that were compatible but not Lexmark brand. Everything seemed fine until I tried to print and then I would get the same error sign and low ink message and it would not print. I kept thinking I was doing something else wrong and tried everything. In the end I broke down and got ink cartridges from Lexmark and that solved the problem. Now I have a Brother printer and I never buy anything other than Brother ink cartridges because I'm always afraid of that same thing happening again. I wish I knew which printers WOULD accept those non name brand ink cartridges, but thus far I do not know of any printers that do. Hope this helps you.
Mar 24, 2012 | Lexmark X3470 All-In-One InkJet Printer
Hi, I am very new to this but i currently have a designjet 5000 and after printing at any given time the image would turn black or just stop. now it says replace all printheads could that be right that...
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Nov 04, 2010 | HP DesignJet 5000 Printer
Printer give me erroe 57 and icannot working test for printer
  • Connectivity :
Oct 28, 2010 | HP LaserJet 2420 Printer
Describe your hp business inkjet 1200 dn driver Problem I couldn't find an exact driver match for my iMac with OSX 10.6.4. Now it won't print on both sides and the tools don't work (such as cleaning the...
  • Connectivity :
Oct 26, 2010 | HP Inkjet 1200dn Printer
Problem with HP F4240. Won't print anything from Quicken Home Business Premier 2005. Just updated to Windows 7.
  • Connectivity :
Oct 26, 2010 | HP PSC 2355 All-In-One InkJet Printer
Lexmark t630 error says remove paper standard bin. Never knew anything about standard bin -- can't get it to print, and yes, there is a connection to the computer
The Remove Paper Standard Bin error can be possibly caused by the exit flag that is out of position, stuck or broken. Follow troubleshooting steps found at http://bit.ly/dhOTEo. If any part of the flag or holder appears to be broken, contact Lexmark technical support or a local authorized service provider.
Sep 20, 2010 | Lexmark T630 Laser Printer
HP DESJET 694C - NO LONGER PRINTS IN COLOR - TRIED SEVERAL CARTRIDGES, CLEANED PINS, ALIGNED AND REALIGNED - NO CHANGE.
Did you checked Printer Settings? May be option is check Marked that "Always print in Gray Scale" if yes then remove check mark.
Disconnect printer from computer and Try to press resume copy or start print button for 5 seconds to start Test Print directly from printer. it prints in color then there definaly a setting problen in your computer printer settings.
Last Option is to check or replace print head.
Mar 09, 2010 | HP Office Equipment & Supplies
I have to restart the print spooler, deleat the printer and re-install the printer in order to get it to work. This is after I turn the computer off and back on. This is the only way I print anything.
check your settings both in the computer and software in the printer properties. Turn off the spooler setting and have the printer print directly to the computer.
Jun 27, 2008 | Office Equipment & Supplies
Printing
Hi Hot,
It would be a BIG help if we knew the brand, model, and any little ole' bit of info you might feel like sharing. The commands and prompts that would be helpful for one item can totally screw up another.
Apr 21, 2008 | Office Equipment & Supplies
What brand of print server would be compatible with a linksys broadband router and the HP printer?
You asked for any advice. If you want to use a server, you must already have at least a home network set up (it could be wireless or hard-wired). Yes, stand-alone "print servers" are notorious for only supporting certain printers. If you don't know this before you buy, you may find yourself returning your print server to the store. However, instead of a standalone print server, have you considered setting up one of the computers in your network as a "print server"? That's the way it used to be done. That's the way my own network is set up. You would set up your multifunction printer as connected directly to one of the computers in your network. Enable "printer sharing" on that computer. Then do the following on all other computers in the network for which you desire access to the printer: Add a network printer. If asked for drivers, get them off the printer's installation CD.
Mar 30, 2007 | HP PSC 1410v All-in-One Printer
491 people viewed this question
k24674
Marvin
Marvin
