Question about Garden
Iz4821 will not discharge
My iz4821 zero turn constantly get choked up with grass. The grass is dry except for natural moisture in the grass. When only cutting about 2 inches off, it constantly cloggs, and I have to stop and clean it out every few minutes. I am not using mulching blades
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Aside from removing the grass that recently clogged the machine have you gotten under it with a spackle knife and really cleaned the old moldy grass that is stuck to the entire deck?
Posted on Jul 21, 2013
  • 376 Answers
SOURCE: What is the difference in a regular blade and a mulching blade?
A regular blade has a straight cutting edge, a mulching blade is bent to have a high and low cutting edge. Even if you have a mulching blade on, if the grass is too high or wet or you're cutting too low, it won't do a good job and may require a second pass.Raising your cutting height can help. Hope this helps. Dwain
Posted on May 17, 2009
  • 1114 Answers
SOURCE: Can a mulching blade work in a non-mulching mower?
True Mulching mowers have a specific deck design to them, but I would say yes to your question.It's been quite a few years, but I have done this little conversion myself - replace regular blade with a mulching blade. Just make sure the mulch blade does fit your mower. Also, use something substantial in terms of strength to close the discharge opening. There can be a good deal of force placed at the opening from flying debris. You'll also want to make the cover removable, so you can mow damp grass without the cover.
Posted on Jun 23, 2009
  • 59 Answers
SOURCE: Blades engage,but stop after running for a bit.
check the wire at the clutch on the crank shaft end try spraying the clutch with P B spry
Posted on Jun 26, 2009
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
  • 2926 Answers
SOURCE: to mulch my grass clippings, do I have to use the
Insert the rear plug if mulching is desired. The key to mulching is to mow the lawn frequently.You want to keep the mower deck height high enough to cut the grass and allow the mulching blades to work, but just low enough to actually cut the grass in a smooth uniform height. To low of a cut setting will clog the mower and create a mess. 2 times a week is a good frequency to start with.
Posted on Jun 10, 2010
Not drying clothes i notice moisture inside
Dirty lint filter.. clogged discharge vent.. faulty control or sensor.. faulty heating coil if electric or fuel issue if propane or natural gas. Provide the make and model if you want more help.
May 12, 2015 | Dryers
Tip
Usage Tips
<span> <li>Cutting the grass too short causes weak, thin grass plants, which are easily damaged by dry periods and pests.</li> <li>Letting grass grow a bit longer-especially when it is hot and dry-reduces heat build-up, preserves needed moisture and protects the grass from heat damage and other problems.</li> <li>A good rule of thumb is the one-third rule: to cut no more than one-third of the grass height, and never more than one inch at a time</li></span>
on Apr 02, 2011 | Garden
How to use mulch plug on cordless mower
Mulch plugs are typically a cover that is affixed to the discharge chute of a mower deck. As blades spin, they cut grass, and lift them up into the swirling air above the cut grass and below the mower deck. The clippings are suspended until they are blown out of the chute.
Mulching, is the process where grass clippings aren't simply discharged out of the chute after cutting; rather they are kept under the mower deck and spin around suspended in the blades resulting in repeatedly being cut. Instead of long clippings exiting the chute, much smaller clipping result from multiple cuttings and settle back on to the lawn under the deck. The smaller clipping allows them to decompose much quicker and return nutrients to the lawn.
Long clippings take longer to decompose and can turn into thatch on top of soil between blades of grass - effectively smothering the lawn. Long clippings can sit on top of cut grass and choke off sunlight, etc. and cause dead spots. Thatch can occur with mulching too - but takes longer to accumulate.
I nearly always mulch
Apr 17, 2015 | Worx Garden
Mower only runs with choke held open
Have you cleaned filter on carb unit? My filer gets plugged with dry grass and does this. I have to remove filter and clean out grass even though the cover is on tight, don't know why but it does. Hopes this helps.
Sep 23, 2014 | John Deere Tractor Starter 285 345 2243...
Have a Zero Turn mower (50 inch deck), engine will only run with choke full on and bogs down or stalls when demand put on engine ie. mowing in high grass. Changed filters (fuel and air) with no change in...
You have a lean fuel condition. This means your carburetor is clogged. By turning choke on you are changing the air/fuel ratio in the carb. You will need to bring this in to a good repair shop to have the carb cleaned.
Aug 01, 2013 | Garden
Troy Bilt XP self propelled mower
Normally an indication of poor air flow. Replace air filter. Clean outside of carb with carb cleaned to ensure choke is free to operate. Go real slow in tall grass, some mowers don't have the torque to do tall grass, only use 1/2 of the deck width and have side discharge open.
May 10, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Toro 20022 grass buildup
at tractor supply has a paint called slip
May 25, 2012 | Toro Power Lawn Mower
Zero turn cub cadet mower, deck keeps clogging with grass
do you have the right blades for bagging ?is the deck belt slipping?
Apr 22, 2012 | Briggs & Stratton Garden
Deck plugs up, will not discharge, especially in taller grass, tried different blades nothing works.
the one thing I have noticed with my swisher 60" is my grass have to be dry or the deck will clog and because of the mulching deck it is not recommended to cut tall grass.
Dec 26, 2009 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Grass trimmer cuts out unless choke is open
IF IT HAS A HIGH SPEED SCREW TURN IT COUNTER CLOCKWISE TO RICHEN THE HIGH SPEED CIRCUT. ONLY NEEDS TO BE TURNED A LITTLE AT A TIME TILL IT SOUNDS RIGHT.
Mar 14, 2009 | Garden
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
