How can I fix a vibrating sound on a ecox mini split A.C
How can I fix a vibrating sound on a ecox mini split. A.C Open Question The a.c makes this loud vibrating sound that comes I think from the motor. Can help me on some info on how to fix this problem before I get it nd break it in pieces.
    Top Expert:
  • Heating & Co... Master
  • 51,198 Answers
IT depends on how old the unit is and the conditions in your area but in split systems the motor is connected to a blower that produces the air flow. This blower is cylindrical in shape with a number of bars that produce the air flow. Over time this blower builds up with debris from the air in you building ( cooking fat--smoke -moisture- etc and is like what collects on the filter. This is what unbalances the blower and has to be removed first. Look up under the opening where the air comes out of and you will see the blower and you will be able to see if it has a build up on the blades. There are ac cleaning products on the market that you can spray in while the unit is operation but be prepared to have to catch the dirty air and bits that will come out. If you have no experience it may be best to get an ac mechanic to come and clean the unit for you.
Posted on Jul 18, 2013
How do I silence clicking sound from a a Fujitsu Mini-Split Wall Mount?
Try taking it off the swing function. Only clicking I can think of, louvers getting jammed???
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Sep 20, 2017 | Heating & Cooling
Mini split drain trouble
There is a temp. probe on the inside unit.(evaporator). If you open the front panel you should see 2 white air filters. With the right side one removed you should see a black probe on the coil. Possibly that probe needs replacement. Very possible there is also a defrost sensor connected to the outside condensing unit. That sensor is connected via a white plug in connector.. Replace that one too if possible.
Jan 20, 2013 | Daikin FTXS12LVJU/RXS12LVJU 12000 BTU...
Help my sons mini pocket quad is making a ringing noise and I don't know what it is. Please Help
open the clutch case there will be a bolt came loose. the clutch is behind the chain drive bolts can come loose from vibration buy lock tight for bolts from halfords do not run untill you have fixed this will rip the clutch apart
Mar 31, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
My LG mini split want cut off. I can cut it off on the unit but it still runs wide open it will not cut off by the remote either. any help appreciated.
This sounds like a faulty thermostat (indoor unit), or a welded (shut) set of contacts in the condensing unit (outdoor unit)
Aug 09, 2011 | LG LS-K2430HL Heat Cool Mini Split Air...
Noisy vibrations heared from the fan
Foundation Bolts are loosed. Or. The Bearings of motor are faulty.
Try tight and fix replace the bearings.
Goodluck :)
Sep 20, 2010 | LG LS-K1830CL Cool Mini Split Air...
When hp netbook is on it makes a vibrating sound
open the cd drive, if the vibration stays, then one of the fans is either clogged or needs replacement
Dec 30, 2009 | HP Mini 1000 Netbook
Vibration under passenger side floor board during acceleration
sounds like a bad cv joint to me. may need a halfshaft. check cv joint boots for being split open and leaking grease.
May 24, 2009 | 1995 Volkswagen Jetta
Friedrich Mini-Split blowing fuse
Low voltage shorts can be a real pain to find!!! i would try a process of ellimination: first i would try to elliminate the thermostat. then id look for a wire that is vibrating on something in the cabinet.
Oct 11, 2007 | Friedrich M18CE Air Conditioner
Heating & Cooling Logo
149 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
