Question about Toro Garden
Tie rod dislocation
Toro wheel horse 8-25. in need of replacement steering rods, for turning mechanism. 9-10 in in length, tie rod like. where can i purchase. 5 speed rear motor!
  • 4 Answers
SOURCE: 2005 Toyota Corolla - steering column crunches
the reason why your hearing this noise is because your CV joints on your car is bad. CV joints go bad when the CV boots have a rip or a tear in them and little pebbles and debree from the road get into the bearings of your axle. Dont worry its not like this big expensive ordeal. What I do suggest is dont even ask about replacing the CV joints because it usually costs the same or even more than just replacing the axles. I know it sounds horrible expencive but its not. When you take your car in tell them you want to replace your front right and left CV axles, because there are two of them in the front. Most people think you only have 1 axle in the front but you technically have two. I find the cheapest way to do it is ordering the axles online. Then finding a job with the cheapest labor rate to put them on.
Go to www.autopartswarehouse.com. Select the year, make and model of the car. Then scroll down to the Driveshaft and Axle section and click on Axle Assembly and order the parts from there. I made it a little easier on you, I already looked it up for you and the price
right axle is $99.95
left axle is $99.95
Now you say you get the crunching when you turn left and right so you will need both the left and right axles. Remember that the longer you take to replace them, that crunching noise will continue to get louder and louder
Posted on Jan 12, 2009
  • 4369 Answers
SOURCE: How to change inner tie rod ends?
if fluid is flowing out the bellows, you need to replace the steering rack assembly. There is no fluid in the area of the inner tie rod. The seal is just before the tie rod.
Steering Gear
The power rack and pinion steering gear is serviced as a power steering short rack (3L547). The front wheel spindle tie rods (3280) and tie rod ends (3A130) are serviced individually. -------------------------------------------------------------------------------------------
  • The power rack and pinion steering gear incorporates quick connect fittings for the power steering pressure hose (3A719) and power steering return hose (3A713) that allow the lines to swivel. This is normal and does not indicate loose fittings.
  • If the fittings leak, check to make sure they are tightened to 14-20 Nm (10-14 lb-ft). Do not overtighten.
  • If the leak is not corrected, replace the fitting seals.
Section 11-02: Steering System, Power 1997 Windstar Workshop Manual
REMOVAL AND INSTALLATION Tie Rod End Steering Gear Installed
Removal
  1. Remove and discard cotter pin and nut from worn tie rod end (3A130).
  1. Disconnect tie rod end from front wheel knuckle (3K185), using Tie Rod End Remover TOOL-3290-D or equivalent.
  1. Hold tie rod end with a wrench and loosen tie rod end jam nut.
  1. Note depth to which tie rod end was located by using the jam nut as a marker. Grip tie rod end with a pair of suitable pliers and remove tie rod end from front wheel spindle tie rod (3280).
REMOVAL AND INSTALLATION Steering Gear Removal
  1. Raise vehicle on a twin post hoist and remove wheel and tire assemblies. Refer to Section 00-02 .
  1. Support vehicle with jackstands under front jack pads.
  1. Remove tie-rod end cotter pins and nuts and remove tie rod ends (3A130) from front wheel knuckle (3K185). Refer to Section 04-01 .
  1. Remove front stabilizer bar (5482). Refer to Section 04-01 .
  1. Disconnect heated oxygen and catalyst monitor sensors.
  1. Support flex pipe.
  1. Remove bolts and disconnect flex pipe from the converter.
  1. Raise dash opening steering column opening weather seal (3513) (secondary) above the steering gear housing (3548).
  1. Remove pinch bolt retaining steering column intermediate shaft coupling (3A525) to power steering gear input shaft and control (3D517) and disconnect the shaft.
  1. Remove nuts from steering gear-to-front subframe retaining bolts. Remove bolts.
  1. Remove rear subframe-to-body retaining bolts.
  1. Lower twin post hoist carefully until rear of subframe (5R003) separates from body, approximately four inches.
  1. Remove heat shield band and fold shield down.
  1. Rotate power rack and pinion steering gear to clear bolts from front subframe (5C145) and pull left to facilitate line fitting removal.
  1. Place a drain pan under vehicle and remove line fittings.
  1. Remove power rack and pinion steering gear through LH wheel well.
  1. Remove and discard the O-rings.
Installation
  1. Install new Teflon® O-rings on line fittings as outlined.
  1. Place steering gear retaining bolts in steering gear housing.
  1. Install power rack and pinion steering gear through LH wheel well.
  1. Install power steering line fittings to power rack and pinion steering gear.
  1. Position power rack and pinion steering gear into front subframe.
  1. Install ******** heat shield.
  1. Install tie-rod ends to front wheel knuckle. Install nuts and new cotter pins. Refer to Section 04-01 .
  1. Install LH front stabilizer bar. Refer to Section 04-01 .
  1. Install steering gear to subframe mounting nuts. Tighten to 115-135 Nm (85-99 lb-ft).
  1. Raise hoist until rear subframe contacts body.
  1. Install rear subframe to body retaining bolts. Tighten to 113-153 Nm (83-112 lb-ft).
  1. Install exhaust system flex tube to dual converter Y pipe (5F250) and remove flex tube support.
  1. Connect heated oxygen and catalyst monitor sensors.
  1. Install tire and wheel assemblies. Tighten lug nuts (1012) to 115-142 Nm (85-104 lb-ft).
  1. Using a new pinch bolt, install the steering column intermediate shaft coupling on the power steering gear input shaft and control and the lower steering column shaft. Tighten the pinch bolt to 34-46 Nm (25-33 lb-ft).
  1. Position steering column opening weather seal (secondary) over the steering gear housing. Tighten nuts to 4.5-6.3 Nm (40-55 lb-in).
  1. Remove jackstands and lower vehicle.
  1. Fill power steering oil reservoir (3A697) with Premium Power Steering Fluid E6AZ-19582-AA or equivalent meeting Ford specification ESW-M2C33-F. Refer to Section 11-00 .
  1. Check system for leaks and proper operation.
Posted on Apr 15, 2009
SOURCE: Need torque spec for 2000 Cirrus outer tie rod ends
45 Ft-lbs Tie-rod balljoint stud-to-steering knuckle nut, and 55 Ft-lbs Tie-rod (outer)- to- inner jam lock nut
Posted on Apr 21, 2009
  • 68 Answers
SOURCE: steering wheel hub off steering rod
The shaft and hub are probably a taper fit & will require a steering wheel or gear puller to get them apart.
Posted on Apr 26, 2009
  • 67 Answers
SOURCE: wheel rear wheel removal on a toro riding mower
take the bolt out of the center or the e clip off and the wheel should slide off but dont loose the key
Posted on Sep 01, 2009
My golf turn sharp at right side an not at left side the tie rod ends is not screw in deep is there a differensce in lenght of tie rod 1.3 or 1.4 and 1.6 vw golf thanks
Yes u need to center your steering wheel..then loosen both track rod ends then straighten your wheels with out turning ur steering wheel
after you have done this make sure u tighten the nuts up tight as this is your steering ...next u will have to go to tyr bay and get ur wheels adjusted with a laser alinement gauge so u get the correct toe in other wise u will wear ur tires out
Oct 08, 2013 | Armstrong Adjustable Face Spanner Wrench,...
What's a tyre rods?
I'm thinking you're referring to "tie rod". The tie rod transmits force from the steering center link or the rack gear to the steering knuckle. This will cause the wheel to turn. The outer tie rod end connects with an adjusting sleeve, which allows the length of the tie rod to be adjustable. This adjustment is used to set a vehicle's alignment angle.
Dec 23, 2012 | Chevrolet Cars & Trucks
Have anyone out there ever change inner tie rods on a1995 honda odyssey?,if so simply explain,THANKS
Procedure on replacing the inner tie rod ends:
1) Raise and safely support the vehicle.
2) Remove the front wheel/tire assembly.
3) Clean the steering rod between the steering boot and outer tie rod end lock nut with a suitable penetrating lubricant and a clean cloth or shop towel.
4) Loosen the outer tie rod end locking nut 1/8 turn.
5) Loosen the steering boot clamp(s), and slide the small clamp off the boot.
6) Carefully loosen the boot and slide outward off the steering rack and onto the shaft to expose the inner steering rod mounting fastener.
7) If necessary, position the inner steering rack shaft in or out to allow for additional access.
8) Relieve the steering rod nut locking tab from the inner steering rack shaft, then loosen the steering rod ball socket nut 1 turn.
9) Matchmark the tie rod end to the threaded shaft.
10) Remove the cotter key and castle nut from the outer tie rod end threaded spindle, and using a tie rod end removal tool, remove the tie rod from the steering knuckle.
11) Hold the tie rod with a wrench, and remove the outer tie rod end from the threaded rod, counting the number of complete turns it takes to remove the tie rod end from the shaft. Write the number of turns on a piece of note paper.
12) Remove the tie rod end lock nut from the threaded steering shaft.
13) Slide the steering rack boot off the shaft.
14) Remove the inner steering rod ball socket nut from the inner steering rack shaft.
To install:
1) Inspect the tie rod end for looseness, and the steering rack boot and tie rod end boot for cracks deterioration or damage and replace as necessary.
2) Clean steering rack shaft and apply a light coating of Genuine Honda Power steering fluid as necessary.
3) Apply a medium strength locking agent to the threads where the inner steering rod ball socket mounts. Use a new locking washer and a new stop washer, and install the inner tie rod onto the steering rack shaft.
4) Tighten the inner tie rod end fastener by 58 ft. lbs. (78 Nm)
5) Peen the lock washer over the nut or onto the flat surface of the steering rack shaft.
6) Apply silicone grease to the outer circumference of the inner tie rod end ball socket, and onto the groove just outside of the socket.
7) Apply silicone grease to the inside of the small end of the steering rack boot, and slide the boot over the steering shaft and onto the rack and install the boot clamps. If the boot has air hose fittings make sure they are installed as removed.
8) Apply a light film of an anti-seize compound onto the threaded tie rod end, and install the tie rod end lock nut.
9) Install the tie rod end onto the tie rod, turning it in exactly the number of turns it took to remove it.
10) Install the tie rod end following the tie rod end installation procedure.
11) The balance of installation is the reverse of the removal procedure.
12) Check the front end alignment and adjust as necessary.
Sep 10, 2012 | 1995 Honda Odyssey
Can someone tell me what Tie Rod Ends are? I've been told by my mechanic that I need to replace them. Why does the car need to be realigned when I get this service?
The tie rod is part of the steering mechanism. If you replace these they will not be exactly the same as the old ones which may have changed shape over time etc... Here is a very good site for info relating to your car and helps with all the technical stuff... http://news.carjunky.com/how_stuff_works/what-is-a-tie-rod-abc170.shtml
Apr 23, 2010 | 1992 Ford Explorer
Any info on tie rods
You have left and right inner tie rods and outer tie rods on your car.
You also have lower ball joints which can wear loose too....not to mention the left and right struts and upper strut bearings.
A cheap (China) tie rod may last only a year.(plastic inner wear points)
A good quality tie rod may last 10.(nylon and/or metal wear points)
Oct 09, 2009 | 1991 Ford Escort
Replacing tie rods for a 2000 ford escort ZX2
The tie rod ends are at the inner wheel of your steering rack.
Loosen the road wheel and jack up the car, then put the car on an axle stand.
Now remove the wheel.
There is a locking nut on the steering arm locking the tie rod. Slacken this nut and replace it finger tight.
Undo the nut holding the tie rod to the hub assembly.
Using a ball joint splitting tool, loosen the tie rod ball joint and lift it clear from the hub assembly.
Now unscrew the tie rod and count how many full turns it takes to come of the steering arm.
Refitting is the reverse of the dismantling proceedure. However count the turns as you put on the tie rod, the same way as you did when you took it off.
When all the work is done. You will have to get the tracking checked out by your local tyre centre.
Ray
Aug 30, 2009 | 2000 Ford Escort
REPLACING LEFT TIE RODS
Genreally speaking the outter tie rod is only worn. The inner connection to the rack is more of a coupling than a rod end. You will need a 22 mm openend wrench and probally a 16mm and a 18mm opened wrench. A set of pliers to remove the old and bend the new cotterpin. Remove wheel cover and loosen the wheel nuts. Jack up the car and place jack stand or wood blocking, (or as a minimum place the wheel you removed) under the car to prevent the car from falling on you while it's in the air. Do not rely on the jack to keep the car up. Cars are heavy. remove wheel Loosen jam nut that locks the tie rod end to the connecting rod of the steering rack, spray adjustment treads with penetetrating oil to help it spin free. You may have to lock the adjustable shaft by the placing wrench on the hex portion of the shaft just inwards of the tread. Remove the cotter pin from the tie rod end. Remove nut. Take hammer and drive the tie rod from the steering knuckle. To help with the alignment of the front wheel try not to move the the steering knucle brake assembly. Unscrew the tie rod , lubricate the tread and in stall the new one. adjust the treads so that the tie rod slides back into the steering knuckle without turning the knuckle. Install the tie rod nut, tighten and secure with new cotterpin. Do not tightnen the jam nut that locks the tie rod nut to the inner adjustment rod for the steering rack, instead place the wheel back on the car, lower car and finish tightnen. with the car lowered, position the car steering wheel straight. Look at right side wheel. You should be able to line the the edges of the front wheel with your eye's with the outside edge of the rear wheel. if this doesn't line up check steering wheel postion. Now after seeing what the wheel alaignment looks like on the right side, go to the left side. If you look along the outside of the left ire and you see the tread of the rear tire , you have to muckh toe out. Lenghten the adjustmne t rod by turning it clockwise. If when you look along the edge of the tire and you don't see the rear tire, turn the rod counter clockwise. Adjust slowly and always check that the steering wheel is in the straight position. Once you have it fairly close to straight, lock the jam nut on the tie rod and take to a wheel alignment company for finishing adjustment. Good luck.
Jul 14, 2009 | 2001 Chevrolet Malibu
How do i change outter tie rod
Prepare your tie rod and install the grease fitting provided with it. 1. Jack up vehicle and secure on jack stand 2. Remove wheel 3. Turn steering wheel so that access is best to the tie rod assembly. 4. Loosen jam nut on tie rod.Do not disturb or turn this more than what is needed to make it loose from the tie rod as this will be your rough reference point and at least close when installing new tie rod. 5. Remove cotter pin from castle nut where tie rod attaches to spindle assembly. 6. Remove castle nut 7. Remove tie rod from spindle assembly - Free with a hammer striking it on the castle nut shaft to drive it out of the hole. 8. un-thread tie rod from tie rod shaft holding the shaft still with vice grip or other pliers. 9. Install tie rod on shaft until it meets the jam nut. 10. Insert tie rod to spindle, tighten, and install new cotter pin in castle nut. 11. Tighten jam nut 12. Grease tie rod assembly 13. Install wheel and have aligned. Do not skip having this aligned regardless of how it drives, post repair as tie rods absolute length can vary from manufacturer to manufacturer. Your final alignment will not be accurate until it is set on a rack with an alignment machine.
Jun 04, 2009 | 1999 Ford Windstar
BMW e30 tierod replacment
This job is normally done in a shop however it can be done in the driveway as well but not as easily.
I assume you are replacing all four rod ends.
Before removing the tie rod assemblies, First loosen the adjusting nuts on the sleeves that lock the assembly adjustment length. Free up but do not change the adjustment of the sleeves.
The tie rods have a tapered portion that goes into the track rod and the wheel steering knuckle that need to be split apart after removing the retaining nut. This splitting can be done with a puller made for the job or something called a crows foot which is a wedge shaped fork that you hammer on to split the tie rod end taper from the track rod or knuckle. These tools can be rented. The fork is about $12
Once you have the tie rod assemblies off and on the bench, carefully measure the total length of the tie rod assemblies. Screw out the tie rod ends counting the turns and screw in the new ends the same number of turns. You will see that one of the ends is right hand thread and the other a left hand thread. Install the assemblies back on the car, first making sure the tapered area of all parts are very clean. Pull the nuts up to at least 30 foot pounds of torque ( 1 foot wrench pulled to thirty pounds force) or best to the manufacturers specification. Now measure the total length of the tie rods. and make them the same length as those you took off. If there is a difference in the lengths, split the difference in the numbers and make the lengths exactly equal. Lock up the adjusting sleeve nuts. Make sure the tie rods are locked in a position that they are free to swivel their full rotational potential. You are now finished except for alignment. Take the car immediately to an alignment shop and get at least the toe in set. This is what changes when doing this job. You must get this done or you will wipe out your front tires very quickly.
Good Luck
Feb 09, 2009 | 1994 BMW 3 Series
Garden Logo
74 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
