Question about Garden
Carb on sears edger model 536870542 - Garden
2 Suggested Answers
digritz
  • 530 Answers
SOURCE: this is on a trimmer edger model # 536.796536
You can get rebuild kits from just about any lawn mower/small engine repair shop around. However unless your trimmer has had harsh treatment it most likely only needs a good cleaning. They are pretty simply to disassemble.
Remove the carb from the motor and get a clean spot on a bench or work table. You will need some solvent to soak it in, lacquer thinner works great because it will take care of any gas that may have turned to varnish during storage.
Remove the bottom float bowl attached by the four screws. Inside you will see the float. It is held in place by a pin that can be pushed out. Be careful not to lose the small wire clip that holds the valve pin to the float. After you have the float and valve out let everything soak over night. Using a small screwdriver (cheap jewelers drivers work best) wrap a piece of scottch pad or fine steel wool around the end and twist it into th port where the valve was. If you have a compressor blow it out the other ports and holes or a can of brake clean if no compressor and reassemble. It's also a good idea to clean out the fuel tank.
This will take care of 80% of problems with small engines. Any other trouble is most likely an issue it being worn out.
Hope this helps.
Posted on Sep 28, 2009
Remove all gas lines. remove screw mounting carb to block. Remove mechanical connections. Sears parts website shows you a blown up view of this product. This is also sold as a Troy Built. Normally a 3.5 hp B&S engine.
Jun 03, 2015 | Craftsman Sears Edger Manual Model...
Why is gas leaking from the air filter
This is a carb flooding issue, there will be a rubber tipped needle in the carb, if this is not seating properly fuel will leak through the air filter, you need to go into the carb, check the metering lever height and replace the needle, unfortunatly it is not possible to replace the needle seat so if it continues to leak after fitting a new needle it will be a replacment carb.
Jun 01, 2013 | Garden
Need a diagram for a craftsman model 79103
Go to any small enj / lawnmower shop and they can help you as far as ordering carb parts, doesn't have to be
Sears. Prob has a zama carb, you can go to zama.com and look up your own carb kit # and then proceed to your local dealer, Not lowes or menards,walmart, has to be a true repair shop, I hope This helps you, also your carb will have a stamped number on it and that is your reference number
Oct 03, 2011 | Craftsman 25cc Gas Line Trimmer
I have a 1999 sears edger # 536-796525 model but wonder what Make engine is it? Bought it used so no manual and no engine name on it, small about 3 HP. Spark plug on top of old fashioned looking motor...
That is a sufficient amount of oil. Even the more modern horizontal crank engines have no dipstick and are checked that way. Anywhere in the threaded area and up is considered sufficient. It is great fun trying to find a manual from just 11 short years ago! The sites have manuals for almost all their current equipment, no luck finding yours yet. I am including a parts breakdown with diagrams, pricing and availability for your convenience from Sears. The manual is no longer available (part #73)
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Edger-Parts/Model-536796525/0247/1503400?pathTaken=
Mouse over the images to get detailed parts list.
Nov 29, 2010 | Craftsman Gas Mini - Tiller/Edger
Craftsman 25cc weed eater carburetor need order of gasket and diaphram from the push bulb down
You just need your model # . You don't have to buy the diaghragm kit you need from Sears. You will need to know the manufacturer of the caburetor. Then, the model # of the carb. Then you will have all you need to order a diaghram kit, and they are not expensive. They normally don't include the bulb, but it can be purchased separately. Or you CAN go the Sears route if you like. Go to www.searspartsdirect.com and type in your info to see if they have the carb kit and part you want.
Oct 01, 2010 | Craftsman 25cc Gas Line Trimmer
Fuel bulb is not bringing in fuel when pushed
The larger line connects to the primer and returns fuel to tank. The smaller line has the fuel filter connected to it in the tank and connects to the small fitting on the side of carb.
Sounds like your problem is in the carb. You need to look your model up in Sears Parts because some models require replacing the entire carb.
May 01, 2010 | Craftsman 25cc Gas Line Trimmer
I have a sears gas weedeater wii start then quits?
OK,could be several things. First Im assuming you have the right mixture in. The two fuel set screws on the carb may need adj,one is for high rev the other is for low end,this should be done by a proffesional. The carb could also need rebuilt and cleaned,it is deffinately in your carb though.
Aug 09, 2009 | Garden
Weed wacker wont start
You do know my neighbor took her sears craftsman edger in and got a new one after a year. TAKE IT BACK!!!!!!!!
Jun 09, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
91 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
