Question about Dell Studio 1737 Laptop
Need wireless properties wifi set protocol
What is the best protocol for above laptop
  • Official Brand Answer
  • 560 Answers
Ritesh,
Click the link below for information and step by step instructions setting up your networking and wireless connections.
Dell Networking and Wireless Support Center
http://dell.to/15yuglg
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Posted on Jul 22, 2013
Can't set up
if your trying to set up the router-- make connections first with the wire(ethernet) directly to the closest pc and then run and install the software cd that came with the router (self guided) then after that you can set up for wireless
If your trying to get on the internet with a wireless connection.and running WINDOWS, .and all set up and configured to broadcast the signal (not hidden) ....
--be sure the wifi switch is enabled on the netbook---next---go to CONTROL PANEL>NETWORK CONNECTIONS--right click oin your wifi card and choose properties--highlight INTERNET PROTOCOL and choose properties and be sure "OPTAIN IP ADDRESS AUTOMATICALLY" is checked--Does the laptop "SEE" the router?
You will need your SSID to logon to the router(internet)
this is a link to a troubleshooting flow-chart
http://www.daileyint.com/hmdpc/laptop/wireless.gif
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this.
Dec 30, 2010 | Linksys WRT160N Wireless Router
Tip
How to Connect a Laptop to a Wireless Router
  • 1 Purchase a wireless router that fits your needs and price range.
  • Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
  • Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
  • Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
  • Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
  • Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
  • Click on "Properties."
  • Select the "Wireless Networks" tab.
  • Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Avable Networks" section.
  • Click on "Configure" when you see your network's SSID in the "Available Networks."
  • Enter your network's SSID and WEP key.
  • Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
  • on Oct 08, 2010 | Computers & Internet
    Cannot get wireless network for medion laptop MD 96630
    If your trying to get on the internet with a wireless connection..and I am assuming you DO have a wireless router all set up and configured to broadcast the signal (not hidden) ....first we have to determine if the problem is at the router or at the laptop AND at what point its getting stuck ... so first try this
    try resetting the router (unplug for a few minutes) try --be sure the wifi switch is enabled on the netbook---try---go to CONTROL PANEL>NETWORK CONNECTIONS--right click oin your wifi card and choose properties--highlight INTERNET PROTOCOL and choose properties and be sure "OPTAIN IP ADDRESS AUTOMATICALLY" is checked--Does the laptop "SEE" the router?
    Dec 28, 2010 | Medion Computers & Internet
    My wireless will not connect or recognize my wireless network.
    If your trying to get on with a wireless connection..and I am assuming you DO have a wireless router all set up and configured to broadcast the signal (not hidden) ....first we have to determine if the problem is at the router or at the laptop AND at what point its getting stuck ... so first try this
    Dec 28, 2010 | Computers & Internet
    Can get internet
    If your trying to get on with a wireless connection..and I am assuming you DO have a wireless router all set and configured to broadcast the signal (not hidden) we have to determine if the problem is at the router or at the laptop AND at what point its getting stuck ... so first try this
    Dec 28, 2010 | Dell Computers & Internet
    How to connect new laptop to router
    Hello
    Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
    Hope it helps, if so do rate the solution
    Good luck
    Dec 24, 2010 | Linksys Wireless-G WRT54G Router
    How to install my router for wireless internet on my laptop.
    1. Purchase a wireless router that fits your needs and price range.
    2. Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
    3. Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
    4. Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
    5. Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
    6. Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
    7. Click on "Properties."
    8. Select the "Wireless Networks" tab.
    9. Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
    10. Click on "Configure" when you see your network's SSID in the "Available Networks."
    11. Enter your network's SSID and WEP key.
    12. Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
    Thanks.
    Have great day.
    Oct 01, 2010 | Computers & Internet
    I dont know to use wifi in LENOVO 3000 Y410
    Hi. First things is you should have a wireless router there or you are at a certain hotspot where there is a free wireless internet access e.g Starbucks. Procedure below:
  • 2 Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
  • 3 Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
  • 4 Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
  • 5 Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
  • 6 Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
  • 7 Click on "Properties."
  • 8 Select the "Wireless Networks" tab.
  • 9 Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
  • 10 Click on "Configure" when you see your network's SSID in the "Available Networks."
  • 11 Enter your network's SSID and WEP key.
  • 12 Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
  • Sep 05, 2010 | Lenovo 3000 Y410 Laptop
    I dont know how to connect it to my laptop wireless
    Aug 01, 2010 | Computers & Internet
    Internet access with wireless
    Assuming that your laptop has a built-in WiFi Networking card (or even a USB or PCMCIA WiFi adapter), normally its a matter of setting your Network configuration to "Auto obtain IP address automatically". This could be done in your Control Panel/Networking Connections, right click on your wireless Networking, click on Properties, highlight Internet protocol (TCP/IP), click on the Properties button and tick "Obtain...".
    In some instances you might need to key in the WEP or WPA security key if it has been enabled and set in your WiFi router, though it has been known to slow down connections. If on the otherhand the router has its MAC filter enabled, then you would need to add your laptop's WiFi MAC numbers to the list that the router would allow access to.
    Should the above be not corrective of your concern, pls post back with the make & model of your router, laptop, and the WiFi adapter if external/add-on. Knowing your Operating System would also help.
    Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
    Good luck and kind regards.
    Thank you for using FixYa.
    Apr 09, 2008 | Computers & Internet
    Dell Studio 1737 Laptop Logo
    Alun Cox
