Question about KitchenAid Superba KSRS27CN Side by Side Refrigerator
I have a KitchenAid Superba 48" built in refrigerator about 13 14 years old. what kinda freon did they have back then r12 or r138a?
While running high ride 150 psi low side -20 psi
  • 1314 Answers
SOURCE: Water Filter Kitchenaid Superba...Where is it??
look for a round peice on the kickpanel at the bottom of the unit it twists and slides out
Posted on May 13, 2008
mikedurland
  • 481 Answers
SOURCE: no ice
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 06, 2008
aasc
  • 1606 Answers
SOURCE: Refrigerator not cooling, clicking
Any parts house will have the part . If you had put the model number in , I could have given you the part number . When you go to get the part , take the model number with you . Only 2 or 3 wires connect to the overload/relay , so is very simple to replace . It usually 'breaks' due to dirty coils , power surges , power off then on at a rapid rate , or time .
Posted on Aug 09, 2009
  • 2330 Answers
SOURCE: Ice on coils on back of freezer on Kitchenaid superba side byside
you have a defrost problem,could be several things ,first when you open freezer door do you hear the fan blowing,if not bad evap fan motor,if it's good check t-stat and heater,you'll need a meter to read them out, or if the wires are the plug in type going to t-stat unplug the t-stat and plug wire dirrectly to heater bypassing t-stat and if heater comes on get a new t-stat,also there is an adaptive defrost board located in the fridge side,if you find your tech sheet,take off kick plate and you should see it under the fridge taped on the kick plate or on the side and it will tell you how to get the fridge into defrost,i think you click the light switches 4 or 5 times together and it goes into defrost,if that's what the sheet says and it doesn't go into defrost it's probably the adaptive defrost whenyou find the part that is bad melt out all the ice with hair dryer,hope this helps
Posted on Nov 10, 2009
  • 88 Answers
SOURCE: Superba KEBS277 broken door spring
go to appliancerepairpros.com or repair clinic .com..good luck...
Posted on Apr 03, 2010
Not cold,everything defrosted ,motor noise still there model superba 48
Most of the time, it's the defrost timer failing and ice building up behind the back panel of the freezer. Also could be the thermostat both are easily replaceable.
Jun 20, 2011 | KitchenAid Superba Architect KSCS25INSS...
Change water filter kitchenaid superba 48
The Kitchenaide is very much the same see if this is helpful. Sea Breeze
IF not then contact me, Thanks, Sea Breeze
SEA BREEZE APPLIANCE PARTS AND TECHNICAL SERVICES
Nov 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
My kitchen aid Superba 48 the meat drawer is broken and I need to replace it. Does anyone know were to buy the drawer?
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=KSCS25INBL01&productCategoryId=0165000&brandId=0593&modelName=COUNTER-DEPTH-REFRIGERATOR&diagramPageId=00003&componentDescription=REFRIGERATOR%20SHELF%20PARTS&documentId=W0606038&blt=06
Eric
Nov 21, 2009 | KitchenAid Superba Architect KSCS25INSS...
My Kitchenaid refrigerator stop freezing. It still gets cold on both sides. But the freezer does not freeze anymore. I was told that it was the coils need cleaning, so I blew them ouy with my air...
It could be a freon leak, or the compressor is not staying on.  If you can hear a clicking sound coming from the back every couple of minutes, your compressor overload is kicking off.  More than likely you either have a freon leak, or a defective compressor. Check the warranty on your machine as many manufactures warranty the sealed system for much longer than the rest of the refrigerator.
Nov 03, 2009 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba leaks from filter housing
i would definately change the filter
they are usually only good for 6 mos
or 400 gals
without knowing if its dripping from the housing
i would start with changing the filter and see if that takes care of it
AP3182816
i just checked and thesea re on sale
30.00 is pretty cheap
appliancepartspros.com
i used to sell these off my truck as a maytag guy
for 48
let me knoe
Oct 17, 2009 | KitchenAid Superba Architect KSCS25IN Side...
How do you take out and change the water filter on a kitchenaid superba refrigerator?
At the bottom of refrig , on the toe plate , press the button on the left kinda hard , and the filter should pop out .
Sep 24, 2009 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba 48 Refrig
hi, is the fridge cold enough.pull fridge from wall, remove back panel. clean all coils. this should solve the problem. thanks the appliance doc
Oct 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
KItchenaid Superba KSRB25QABL water dispenser
Chances are is a bad water valve.  The water valve is on the back of the fridge at the bottom.  You will see the water line going into it.
Oct 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba KSRS27CN Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
