Facing windshield 350 chevy engine which cyclinder is which number on which bank righy or left? then i can set the plugs and firing order with 1 on top dead center
  • 180 Answers
SOURCE: firing order on the distribtor cap on a 1988 350 chevy engine
18436572
Posted on Jan 01, 2009
tripletauto
  • 1450 Answers
85904f6.gif HERE is your firing order. this truck did not come with vortec heads so either engine or heads ahve been swapped.
Posted on Jan 21, 2009
  • 1043 Answers
SOURCE: 1990 chevy 350 distributor wiring diagram and firing order
The firing order is 1-8-4-3-6-5-7-2.
The distributor rotates in a clockwise direction. The engine must be on the compression stroke on the #1 cylinder. Line up the timing marks. Remove the cap and the rotor should be pointing to approximately the 5 o'clock position.
Good Luck
Posted on Mar 06, 2009
motor1258
  • 6674 Answers
SOURCE: I KNOW THE FIRING ORDER OF A CHEVY 350 IS
d0f0bbd.jpgthis help?
Posted on Aug 27, 2009
  • 400 Answers
SOURCE: 96 Chevy Z71 with vortec 350, Code 1406.
Yep that is what the code is for. Make sure the passage is clean after you pull it off.
Posted on Oct 16, 2009
WHAT IS THE FIREING ORDER OF 1983 V8GASOLINE BENZ
The firing order for an '83 Mercedes-Benz V-8 is 1-5-4-8-6-3-7-2. And, here's some more information. If you are wondering which physical plug corresponds to the number 1, look at the engine's banks (it's a V-8, so there will be two banks for four cylinders). As you stand there -- you should be at the front looking toward the windshield -- the left-hand bank of cylinders are 1 to 4 (1,2,3,4) and the right-hand bank is 5 to 8 (5,6,7,8). I hope this helps.
Feb 02, 2015 | Cars & Trucks
Tip
What is the firing order for a Chevy 350?
The firing order for Chevy 350 is :--- 1-8-4-3-6-5-7-2.---------- 1,3,5,7 is on the left bank side and 2,4,6,8 is on the right bank side . The distributor rotates clockwise. This will help.Thanks.
on Mar 18, 2010 | Chevrolet Chevy Cars & Trucks
Need timing order for f350 7.5l
[95 f-350 Gasoline Engines ]
1 - 5 - 4 - 2 - 6 - 3 - 7 - 8 The distributor rotor turns COUNTERCLOCKWISE The marked # 1 position on the distributor cap faces to the REAR and slightly towards the drivers side of The engine
[97 f-350 Diesel Engine]
From front to back, the passenger-side bank is numbered 1, 3, 5, 7 and the driver-side bank is numbered 2, 4, 6, 8. The firing order on your 7.3-liter Powerstroke is 1-2-7-3-4-5-6-8.
hope this helps a bit.
Oct 23, 2013 | Motorcycles
Chevy 350 firing order diagrams
1-8-4-3-6-5-7-2
TDC on #1 compression stroke,not exhaust
Number 1 on the dist cap-- is at about 7 o clock,
as you face the motor from the front
2-4-6-8
1-3-5-7
1&2 are at the front-- as you face it
Sep 14, 2013 | Cars & Trucks
Firing order diagrams
Firing order is 1-8-4-3-6-5-7-2
Rotation is clockwise (left to right)
Jul 17, 2013 | Cars & Trucks
Yes i have a 96 chevy lumina i changed the plugs and i think i may have switch the wires but dont know where they go directly
From standing in front of car and facing engine:
3.1L and 3.4L OHV V-6: The cylinder location is from left to right (rear cylinders) 1,3,5
(front cylinders)2,4,6
The coil terminals from left to right: 5,2,3,6,4,1
Firing order 1,2,3,4,5,6
3.4L DOHC V-6: The cylinder location is from left to right (rear) 1,3,5 (front) 2,4,6
The coil terminals are from front to rear 5,2,3,6,4,1
The firing order 1,2,3,4,5,6
3.8L V-6 cylinders left to right (rear)2,4,6 (front) 1,3,5
coil terminals front to rear 1,4,5,2,3,6
firing order 1,6,5,4,3,2
Feb 08, 2011 | Chevrolet Lumina Cars & Trucks
Change plugs and wire and engine will not acclerate. This is a built 350 short block chevy with pro charger.
350 Chevy engine in what? 1990 Corvette? Who built it, did you?
Sounds as though you have plug wires wrong.
Distributor Ignition System:
Distributor rotates Clockwise. (Rotor)
Find Number 1 tower on distributor cap, go Clockwise with Firing Order.
Distributorless Ignition System:
VIEWING the engine from the Front of the car.
Spark plug wire connections along the back, starting from Left side going to Right side;
2-3-7-4
Spark plug wire connection towards the Front of the engine;
6-1-5-8
(To guess I would say you have 5 and 7 wires switched)
Left side cylinder order is 1-3-5-7, going from front to back.
Drivers side is Left side.
Right side cylinder order is 2-4-6-8, going from front to back.
Oct 13, 2009 | 1990 Chevrolet Corvette
Ignition firing order and cable position at the coils
The 3.5L (VIN H) engine's unique ignition system has the ignition coils directly over each plug. No spark plug wires are used.
3.5L (VIN H) engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
The firing order for the 3.1L VIN M, 3.4L VIN E, 3.4L VIN X and 3.5L VIN H engines is 1-2-3-4-5-6. The right bank cylinders are on the cowl side (rear) of the engine compartment and are numbered 1,3,5, left bank cylinders on the front side of the vehicle, are numbered 2,4,6.
3.1L (VIN M) engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
3.4L (VIN X) engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
3.4L (VIN E) engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
The firing order for the 3.8L VIN K and 3.8L VIN 1 engines is 1-6-5-4-3-2. Starting at the front of the engine, cylinders in the left bank are numbered 1,3,5 and cylinders in the right bank are numbered 2,4,6.
3.8L (VIN 1) engine Firing order: 1-6-5-4-3-2 Distributorless Ignition System
3.8L (VIN K) engine Firing order: 1-6-5-4-3-2 Distributorless Ignition System
I hope help you with this, remember rated this help. Good luck.
Sep 01, 2009 | 1999 Chevrolet Lumina
What is piston order on the left bank and right bank of car
not sure if you mean firing order or you want to know which cyclinder is which. to determine which cyclinder is which... look at the motor from the side... you will note one side is further (farther) forward then the other side. that's cyclinder 1. next across from it is 2 and so on.
Apr 11, 2009 | 1989 Oldsmobile Eighty Eight Royale
Timing on a 350 chey engine
take out number 1 spark plug and put your finger as to block the hole ,have a friend bump the starter till you feel air rush out real fast / called the compression stroke when it does stop and look down the top center for timing marks on the pulley and line them up on the timing cover then place the distributor in place as so the rotor is pointing at the #1 piston location, basically the dr. front corner and start there, timing order is 1..8..4..3..6..5..7..2.. now if you get all these in right 1..3..5..7 are on the drivers side front to back and 2..4..6..8 on the passengers bank front to back and the distributor turns clockwise .good luck hope this helps you.
Dec 16, 2008 | 1978 Chevrolet C1500
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
